Anyone has user manual?
Cant remember how to set the parking position of loaded paper. Printer keeps printing 1 line on the next page of A4 paper. I presume it has to do with the parking position of the paper when paper load into printer.
Tried NEC website but all they have are normal settings but not how to manually set the auto load position.
  • 3 more comments
  • jquah Mar 12, 2009
    Ops, sorry. It's NEC Pinwriter P3200.
  • jquah Mar 13, 2009
    thanks for the tip sandmanmac. Unfortunately, it doesnt mention anything about how to do setting. sigh, i did the setting many years ago. just cant remember which button to press.
    hi Smithbrother. the printer is very old. NEC stop production & info on their website info is limited to breakdown problems. No manual :((
  • Thomas F. Schneider May 11, 2010
    Product not found on the NEC website?
    http://search.necam.com/query.html?qt=pi...
    Model number?
I didn't see a manual, but there is a faq page that may help you:
http://printers.necam.com/printers/printers/content.cfm?sp=343&section_id=302
Posted on Mar 13, 2009
Xerox 7760 Wrong paper size error when trying to print to A4
First your computer selects the printer to output to, so make sure your default printer is selected.
Next, within your printer you may have selected a different page size for output as a default.
The printer it self should allow you to load and auto detect paper size. If this feature is not enabled see if it is a choice.
Also whatever you are trying to print check page setup in the program you are using make sure to ensure they match.
Sep 16, 2016 | Xerox Phaser 7760DN Laser Printer
Error Message on Dell 5100cn
check the page setting in the printer as well as in the print dialog box in the, if the problem persists then you have to send it for servicing
Apr 29, 2008 | Dell 5100cn Laser Printer
Kyocera 2020d WONT PRINT Load Mp Tray
load a4 paper in bypass or the mp tray as it is also called
Jun 08, 2017 | Kyocera FS-2020D ECOSYS Monochrome Laser -...
Oki - how to print booklet?
The paper you have inserted into the printer, and your page size settings have to match. You can't load A4 paper and tell it to print A5 size. This is why it is printing so small on the A4 paper. It assumes you need to trim it down to A5 size after printing.
Jul 15, 2012 | Office Equipment & Supplies
I purchased my c4600 printer about 4mths ago and i have just replaced the ink cartriges and it keeps telling me to realighn cartriges how do ido that it is the first time i have needed to change them i...
Here's a support article taken from the HP website regarding alignment of print cartridges. Hope this helps.
Introduction This document provides steps to align print cartridges using the All-in-One control panel or the computer. The appearance of the product varies by model. Aligning print cartridges Follow one of these methods to align print cartridges. NOTE: If the same print cartridge is removed and reinstalled, the product will not prompt to align the print cartridges. The product remembers the alignment values for that print cartridge, so there is no need to realign the print cartridges. Method one: Print an alignment page using the All-in-One control panel When a new cartridge is installed, the product aligns the cartridge. The cartridges can also be aligned any time after you install the software. Aligning the cartridges helps ensure high quality output. Follow the steps to align newly installed cartridges.
  1. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  2. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 1: Alignment pagec01369744.gif
  3. Place the alignment page print-side down on the right front corner of the glass. Figure 2: Position the alignment pagec01369745.gif
  4. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Method two: Print an alignment page using the computer Follow these steps to align the cartridges from the HP Photosmart software.
  1. Double-click the HP Digital Imaging Monitor icon (c01367004.gif ) on the lower right side of the Windows taskbar. The HP Solution Center displays.
  2. In the HP Solution Center, click Settings . Then click Printer Toolbox . The printer Toolbox displays.
  3. Click the Device Services tab.
  4. Click Align the Print Cartridges .
  5. When prompted, make sure plain white letter or A4 paper is loaded in the input tray.
  6. Press the button next to OK on the control panel display. The product prints an alignment page. Figure 3: Printing an alignment pagec01369744.gif
  7. Place the alignment page print-side down on the right front corner of the glass. Figure 4: Positioning the alignment pagec01369745.gif
  8. Press the button next to OK on the control panel display. When the On button stops flashing, the alignment is complete. Remove the page and recycle or discard it.
Apr 19, 2011 | HP Office Equipment & Supplies
Hello sir, how to take print on A4 page? please help me
Hi The A4 paper size is an internationally used paper format. Although not often used in America, it is by far the most commonly and widely circulated paper size. At 8 1/4 inches by 11 3/4 inches, it is similar though not quite identical to the American standard U.S. letter size, which is 8 1/2 inches by 11 inches. Because of its ubiquity, all printers and programs have the ability to handle the size, and getting a printer to print to it is a matter of adjusting the settings.Put the A4 sized paper into the automatic feeder in the printer. You may have to adjust the tray guides to fit the paper in snugly. Close the tray firmly when finished.
  • Step 2.Set the printer to register the A4 sized paper inside the the tray. This varies from printer to printer but generally involves going into the print menu, scrolling to the automatic feeder and designating the tray as an A4 tray.Step 3.Select "File" and then "Page setup" in the program you are using.Step 4.lick on the drop down menumag-glass_10x10.gif next to paper size and choose "A4.Step 5.Select "File" and then "Print." Click the "Print Summary" button to ensure the file is set to print to the A4 size.
  • Step 6.Press "Print" to print the photograph.
  • Jul 31, 2010 | Toshiba e-Studio163 Copier
    How do I realign my hp photosmart c4480 printer?
    To align the print cartridges from the HP Photosmart Software
    1. Load letter or A4 unused plain white paper into the input tray.
    NOTE: If you have colored paper loaded in the input tray when you align the print
    cartridges, the alignment will fail. Load unused plain white paper into the input
    tray, and then try the alignment again.
    2. In the HP Solution Center, click Settings.
    3. In the Print Settings area, click Printer Toolbox.
    NOTE: You can also open the Printer Toolbox from the Print Properties dialog
    box. In the Print Properties dialog box, click the Features tab, and then click
    Printer Services.
    box. In the Print Properties dialog box, click the Features tab, and then click the
    Printer Services button.
    The Printer Toolbox appears.
    4. Click the Device Services tab.
    5. Click Align the Print Cartridges.
    When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
    press the button next to OK.
    The product prints a print cartridge alignment sheet.
    7. Load the page print side down on the right front corner of the glass, and then press
    the button next to OK to scan the page.
    When the On button stops flashing, the alignment is complete and the page can be
    removed. Recycle or discard the page.
    Jul 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
    Hpphotosmartc4380 the printing is badly out of line .How do yoy align the cartridges?
    You may want to run the alignment program again. Below are the steps as found on page 84 of the manual found here.
    1.
    In the HP Solution Center, click Settings, point to Print Settings, and then click
    Printer Toolbox.
    box. In the Print Properties dialog box, click the Services tab, and then click
    Service this device.
    2. Click the Device Services tab.
    3. Click Align the Print Cartridges.
    The HP All-in-One prints a print cartridge alignment sheet.
    4. When prompted, ensure plain white letter or A4 paper is loaded in the input tray, then
    The HP All-in-One prints a test page, aligns the print head, and calibrates the printer.
    5. Load the page print side down on the right front corner of the glass, and then press
    Oct 07, 2008 | HP Office Equipment & Supplies
    Banner Printing
    Hi Thank you so much for the best information wth banner design. i got my banner design method on here http://www.thewebpole.com/ @ from the domain name processing, with the free services of hosting, and mosr services like, * Photo Album
    * Quick Blogcast
    * Hosting with site builder
    * Personalized Email Account
    * Starter Web Page
    * "For Sale" Page
    * Parked Page w/ Domain
    * Domain Forwarding & Masking
    * 100-Pack Email Forwarding
    * Total DNS Control
    * Change of Registration
    * Status Alerts
    * Domain Locking
    Jun 18, 2007 | HP Deskjet 6940dt InkJet Photo Printer
    138 people viewed this question
    jasbo
    jasbo
