Question about Hitachi 46F500 46" Rear Projection HDTV-Ready Television
Shadowed colors inpicture
I have shadows in my picture. i tried the majic focus to no avail. then i tried to do a manual convergance, & the red lines will not line up with the other colors.
  • Hitachi Master
  • 3,459 Answers
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a commonshadowed colors inpicture - 2c07611.pngbr />
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 15, 2009
My 46F500 also had the same problem after 3-1/2 years. The convergence module was the culprit. The technician replaced the entire module at the cost of $550.00. If it happens again, I'll spring for a new tv. this is a common problem for projection tv's.
Posted on Mar 18, 2009
Magic Focus button will not line up picture. Red and green colors shadow images.
The tv have a problems known as a convergence picture problems it is dead.The tv have any colors lines like R,G,B mis alignments,tv have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead and the causes of these problems.The tv convergence board must have to repair like replacing like 2 STk covergence ICS and some or all of it resistors too.To fixed the tv convegence board to solved the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 02, 2011 | Hitachi 53SDX01B 53" Rear Projection...
Ghost image in red and alot of red color. This occurs all the time. I have tried magic focus and manuel focus. No change
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?This tv have a dead convergence board.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.Fixing the tv convergence board,will solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 09, 2011 | Hitachi 51F500 51" Rear Projection...
How do i fix a color alignment problem?
Tries push the button said FLASH FOCUS or manual + - convergence alignment adjustment?Yes,n o,used?The tv colors lines R,G,B mis alignments,have colors shadows pictures or 3D picture look alike?The tv have a convergence problems,it dead.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too on the convergence board,must replaced these parts to fix it.To solved tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 27, 2011 | Hitachi 46F500 46" Rear Projection...
Focus error 50h81 toshiba red line problem
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or have 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix it.To solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Jan 01, 2011 | Toshiba 50H81 50" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Shadow effect on picture. Picture is fine but there is a red shadow tint to everything (basically everything is written twice, but not in the same spot)
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look like.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts,must be replaced on the tv convergence board to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
Color shadowing on screen
I had similar symptoms about a year ago. Also came on sudden. The red convergence chip had burned out (poor heat sinking on this model Hitachi). Replacing the color convergence chips fixed it. ($50 for parts.) First, however, have you tried the "magic focus" function? That's explained in the manual, which is available online IIRC, but I'd have to look for the link if you need it.
Mar 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Picture has red and blue shadows
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red shadow
bad connections on the converganc ics just solder them this will fix the problem if not replace them
Nov 03, 2007 | Sony KP-46WT500 46" Rear Projection...
Hitachi 46F500 46" Rear Projection HDTV-Ready Television Logo
165 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
