Question about GRACO INC Ultra 395 Stand Airless Paint Sprayer 233960
Paint not pumping throughgraco 395 sprayer pump diagram
Paint not pulling through
Does a 2/3 HP .40GPM Campbell Hausfeld Airless Paint Sprayer require any kind of oil if so what kind and how much
airless sprayers have a pump that pumps the paint through a jet at pressure . there is no oil and it is vital that when finished that the pump be spotless after cleaning
Nov 12, 2015 | Campbell Hausfeld Air Tools & Compressors
Where can I find a schematic for the Krause & Becker paint sprayer? Mine is no longer working, and I noticed a disconnected set of wires hanging out the bottom of the pump casing.
[PDF]Airless Paint Sprayer - Harbor Freight Tools
manuals.harborfreight.com/manuals/68000-68999/68001.pdf
Airless Paint Sprayer. Item 68001. Read this material before using this product. Failure to do so can result in serious injury. SAve thIS mAnuAl. Notice.
Sep 26, 2015 | Tools & Hardware - Others
How much should I thin paint for pneumatc sprayer?
you did not mention what paint, you did not mention what sprayer.
remember, if you use solvent - opacity of the paint is sacrified, tints are less visible, metallic require more clear coverage.
for water based paints - except airbrush, usually no thinning is required, but you need to first stir it well (at least 3min on manual or 1min 30sec if mechanical stirer is used) strain it, i am using old stockings for that purpose in single layer, works very well for me and if nozzle is above 1.4mm up to 2.8mm there is no problem whatsoever. if this is splatter paint (nozzle 4.5mm or greater) do not even think about thinning it...
for acrylic - if nozzle is between 0.8mm and 2.8mm, procedure as above and you need to add specific thinner, usually up to 20% albeit in some cases up to 40% per volume) so paint will be about like ight cooking oil - water.
for oil paints and enamels - solvent should be not more than 20%, albeit you can increase it up to 40% in rare circumstances, if you are using hvlp gun, you can, if you yousing hp gun - no! it will disperse too much.
for two packs and urethanes - not more than 20% better keep between 5% and 10%
for latex - in rare circumstances you are allowed to use very, VERY specific solvent, and ususally not more than 10%, nozzle usually is 8mm or greater in these paints.
Oct 19, 2014 | Air Tools & Compressors
Does a Wagner Paint Crew sprayer take lubricant?
The Wagner Paint Crew airless sprayer does not require oil for its operation like full professional sprayers. The piston is off-set from the pump chamber with the inlet and outlet valves opposite each other, however you need to protect the parts from corrosion between use and Wagner recommend running some light oil through it after cleaning. If you will be using it in a day or so for water based paint, you could run a 10% solution of their EasyGlide through it.
Sep 30, 2014 | Wagner Spray Tech Wagner Paint Crew 2750...
Pump will not prime after cleaning with paint thiner
Could be that your were using water based paint, so if there was any in the sprayer when you cleaned it out with thinner, this could cause the latex to become a rubbery mass that then blocks up the passage ways. If so you'll need to strip the pump and clean it out.
Oct 04, 2013 | GRACO INC TrueCoat Plus II 16N659
Paint sprayer won't pump
Ok, go to campbel hausfeld web site and download a manual for your sprayer : http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?langId=-1&storeId=10051&catalogId=10001
Find your model number and look at parts view. Pay paticular attention to the inlet and outet valves. They must be absolutely clean to function. These pumps must be thoroughly cleaned when finished.
May 15, 2010 | Campbell Hausfeld Airless Spray Guns &...
Need to repack pump on graco gm5000 gas paint sprayer
http://www.graco.com/
you can put your model in or if you have a part # you can enter it into one of the fields eventually you will fing a parts diagram for your unit.
Jun 02, 2009 | Air Tools & Compressors
GRACO INC Ultra 395 Stand Airless Paint Sprayer 233960 Logo
Top GRACO INC Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a GRACO INC Air Tool and Compressor Expert? Answer questions, earn points and help others
