Question about Gatehouse Hardware & Accessories
Gatehouse doorknob parts - Gatehouse Hardware & Accessories
Removing an exterior doorknob with no screws. I can get the lever part off but can't remove the backplate by just prying. Appears to be a tiny "spring" holding it on.
Look for a little divet to pry if not its most likely joined internally try un screwing the actual backplate itself
Sep 02, 2017 | Cars & Trucks
We have a gatehouse model # pl110s10 and are unable to program a code because we got rid of the box. Can you help us program a code?
the programming instructions are inside the battery cover. instead of Enter click the Gatehouse button in some cases. also, to actually USE the thing, you just enter your code and hit Gatehouse/enter to unlock, and just hit Gatehouse/enter to lock.
Mar 22, 2015 | Televison & Video
Cifial doorknob
I never seen a doorknob on a laptop before, I would love it if you post a picture.
Aug 26, 2014 | Computers & Internet
Cifial doorknob
You could use a needle.
How to remove gatehouse door knob?
Look for a small set screw on the side of the deadbolt on the inside of the door loosen the set scrww and remove the cover to expose the screws that hold the door knob on
Oct 31, 2013 | Gatehouse Springfield Satin Nickel...
How to put the striker from a door knob kit back together
i can help you with that...just follow this steps...
1.Remove the old doorknob by taking out the screws that hold it in. You will have to remove the striker separately by removing the screws that hold the strike plate in place on the outside edge of the door. Slide the striker out.
2.
Take the new doorknob, striker, and strike plate out of the packaging and look for the directions. (Most doorknobs are installed in the same way, but there are always exceptions.)
3.
Slide the striker bar into the hole. Insert the screws into the striker plate and tighten.
4.
ake the two halves of the doorknob, and place the one with the male end through the hole in the striker bar. Place the female side of the doorknob on the other side of the door and make sure that it lines up with the male end. Slide the two together. Screw the knob together using the two long screws that came with the doorknob. Make sure that the screws are tight. Make sure that you have the lock facing the right direction. You want the locking mechanism on the inside of the house or room.
5.
Test your work before you shut the door. Make sure that both sides of the door knob turn and the striker bar goes back and forth.
:p
Dec 01, 2011 | Hardware & Accessories
The key still goes easily into the doorknob
can be easy as wd-40 squirt of oil. try that first... then on to more drastic measures
Dec 13, 2009 | Schlage BE365-CAM BE365CAM620 Antique...
I have several ''gatehouse'' deadbolts and i can't get the core out in order to rekey them. how can i get it out or find instructions?
Here is a link to the manual for rekeying all Schlade/Gatehouse locks.(It's in PDF format)You can download,save,print,or view online.
Please take time to rate this fixya
May 14, 2009 | Schlage B362 605 KA4 DBL CYL DEADBOLT 4 EA...
Doorknob sticks in 'lock' position-but no real 'lock' feature
If this is the lock part itself,try gradually loosening install screw enough to be able to manuver lock to work and if so slowly tighten as you test each time gradually. Please clarify problem more if need to.
Mar 12, 2009 | Top Knobs M826 Door Pull
Hardware & Accessories Logo
156 people viewed this question
Top Gatehouse Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Gatehouse Hardware and Accessory Expert? Answer questions, earn points and help others
