Question about Grohe Plumbing
LOOSE FIXTURE Thehome I'm renting has a Grohe 33-755 High Profile kitchen faucet (installed in akitchen redo 5 months ago)  The entire unit has become very loose and wobbly. I'm afraid that what ever keeps the unit snuggly in place has comeundone.   Thesink is very deep and I have limited access underneath the unit, but to thebest of my knowledge, there is no fastening nut beneath the unit. I was toldthat there may be a special tool provided by Grohe that tightens the unit fromthe top.     Is thistrue?  How can I tighten?  My land lord is of no help!
  • 150 Answers
Unfortunately you cannot tighten the faucet from the top. you will need a 1/2" extended socket (the type for car repairs) and you will need to tighten it from underneath using an extension bar.
Posted on Mar 12, 2009
Grohe warranty
GROHE - Warranties - Services for you
https://pro.grohe.com/us/5685/services-for-you/warranties/
  1. Cached
Residential Products: We provide the following warranties on all GROHE products to the original purchaser, installed in a residential setting. This warranty is effective for all faucets sold after January 1, 1997. Mechanical Warranty: A Limited Lifetime Warranty is provided on all mechanical parts to be free from manufacturing ...
Warranty - Grohe
https://www.grohe.ca/en_ca/our-service/warranty/
  1. Cached
We provide the following warranties on all GROHE products to the original purchaser, installed in a residential setting. This warranty is effective for all faucets sold after January 1, 1997. Mechanical Warranty: A Limited Lifetime Warranty is provided on all mechanical parts to be free from manufacturing defects in materials ...
Luxury Bathroom Taps, Shower Heads & Kitchen Mixer Taps ' GROHE
  1. Cached
  2. Similar
GROHE - Luxury fittings for exceptional bathrooms and kitchens. Our range of bathroom taps, showers, shower heads and kitchen mixer taps includes designs to suit all interior styles and budgets.
GROHE Faucets Warranty - eFaucets.com
https://www.efaucets.com/grohe-faucets-warranty.asp
  1. Cached
Limited Lifetime Warranty (U.S.A. Only). Residential Products: GROHE provides the following warranties on its products to the original purchaser, installed in a residential application. This warranty is effective for all faucets sold after January 1, 1997.
calling grohe faucet owners..lifetime warranty? - Houzz
https://www.houzz.com/discussions/.../calling-grohe-faucet-ownerslifetime-warranty
  1. Cached
  2. Similar
Nov 11, 2010 - My parents put in a grohe faucet 25 years ago that has been leaking for the better part of the past 15 years. I JUST noticed the name on the faucet as I was sitting at the counter last night and thought, "hey, I bet this expensive faucet has a lifetime warranty" Can anyone share their expe...
Dec 12, 2017 | Grohe Home
How to tighten grohe curve faucet?
There is a set screw at the base i need to see the entire faucet to give specifics is it in bathroom or kitchen need to know if it is supposed to be in fixed position if so there is a set screw at the base
Sep 03, 2014 | Grohe Plumbing
Why is my grohe alira kitchen faucet loose
There is a nut up under the counter its hard to see but tighten that . Most faucets come with a special tool fo hat but can be done with wrench
Aug 31, 2014 | Grohe Alira Pull-Out Kitchen Faucet S....
Why is my grohe alira kitchen faucet loose on a granite counter
Probably a loose fixture nut under the counter behind the sink.
Yeah ya gotta pull out everything and crawl up into the cabinet on your back and see if the nut (right up at the granite, above the hot and cold inlet pipes) is loose. If it is THEN you'll need to tighten it. Wrench, slip-joint pliers or a basin wrench. (probably basin wrench which is a specialized tool made for reaching up into tight places)
How to change spray hose on grohe kitchen sink ladylux model
I have the Ladylux plus. I was confused on how to remove this as well. There is a quick release plastic piece, just pull down on the yellow part on the connector under the sink. Disconnect the plastic connector from the hose and pull it right out of the faucet. Very easy to remove in this case.
Jul 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
Hello: My Grohe Lady Lux Cafe kitchen faucet has become loose where is it attached to the sink. How do I tighten it back up? David
You'll have to go under the sink and look up were the faucet comes through. You'll see it's held in place by a large nut. This nut needs to be tightened. Unfortunately working in the tight space under the sink is a pain in the ****, just be patient and you should be able to tighten it. TIP: Have someone hold the faucet on top in the position you want it.
Feb 07, 2010 | Grohe Model 28 206 OOO: Ladylux Plus...
I have a Grohe Ladylux Plux kitchen faucet that was installed 5 years ago, and it is now loose. There isn't a way to tighten from underneath and the installation directions called for using a tool to...
you can pull the faucet arm off, the part right on top of the base , if my memory serves me correct you can tighten it with a creset wrench and the neck will pop right back on after
Aug 04, 2009 | Grohe Plumbing
Loose Grohe kitchen faucet
there are mounting plates underneath the counter which fasten the faucet to the counter.This unit will need a small allen wrench if memory serves me correctly...keep in mind that all moen faucets are lifetime guranteed and alot of folks do not take advantage of this amazing warranty which makes these the most desirable faucet on the market.however the need to tighten this faucet prob isnt a warranty replacement procedure but can be determined once mounting items and faucet is inspected...good luck
Jun 28, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Grohe ladylux faucet loose on counter.
Here is the manufactures web where you may request the information you desire concerning your faucet.
http://www.groheamerica.com/s/25_4060/page/modules/iframe/index.php?if_url=http://12.130.64.173/litrequest2.htm
Dec 10, 2008 | Grohe Plumbing
Plumbing Logo
749 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
