Question about iSedora Media Server
Isedora After using iSedora for months, today, after restarting my computer iSedora shows this message: "Server error occured"
The server could not be found
This problem occurs because Outlook does not support connections to a server that is running Exchange Server by using the EAS protocol. Try this app to resolve your issue https://www.outlookrepairtoolbox.com/
Mar 21, 2017 | The Computers & Internet
Microsoft Exchange Server. HTTP 500 Internal Server Error.Any recommendations?
To resolve this problem, follow these steps on your Exchange 2000 or Exchange 2003 back-end server. Alternatively, follow these steps on another computer that has access to the same domain controller and the same global catalog server.
NoteThis procedure requires the Exchange Server Fix Toolbox
1.Start the the Exchange Server Fix Toolbox
  1. Right-clickYour_back-end_Exchange_server, and then clickProperties.
  2. Clicknetworkaddressin theAttributeslist, and then clickEdit.
  3. Add a new value forncacn_ip_tcp. Use the FQDN of the server instead of the NetBIOS name or the host name of the server.
    The syntax for this value isncacn_ip_tcp:FQDN. For example, if your Exchange back-end server has a host name of EXCHANGE1 and the FQDN is EXCHANGE1.domain.com, use the following value forncacn_ip_tcp:ncacn_ip_tcp:EXCHANGE1.domain.com
  4. Remove the oldncacn_ip_tcpvalue that contains the NetBIOS name or the host name of the back-end server.
  5. Apply this change.
  6. Because your Exchange computer may change this value back during a failover or a system attendant restart, configure the following registry value on both nodes of the cluster:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\MSExchangeSA\Parameters\UpdateProtocols
  1. Right-clickUpdateProtocols, clickModify, type0in theValue databox, and then clickOK.
  2. If your network uses a Hosts file on the back-end cluster node, modify it by using the following order of entry:
  3. Restart the Exchange services on the back-end cluster node.
  4. If there are multiple domain controllers, wait for replication to occur before you try to log on from the front-end server. If the problem is not resolved after replication is complete, restart the IIS Admin Service on the front-end server.
You can obtain the Exchange Server Fix Toolbox by visiting the following site: https://www.fixtoolbox.com/exchangeserverfix.html
Jul 27, 2015 | Microsoft Exchange Server for PC
Why does it say communication error when i try to activate microsoft office 2007
This issue may occur if you configure your Internet connection to use a proxy server that requires authentication. In some situations, the Activation Wizard can not connect through the proxy server to an internal Microsoft server and show error message.
Alternatively, this issue may occur if your firewall software is blocking the attempt to connect to the server through your Internet connection.
To resolve this issue configure the firewall software to let the Activation Wizard connect to the Microsoft server or restart the computer in Windows Safe Mode With Networking, and then try to activate the software.
May 25, 2014 | Microsoft Office Word 2003 for PC
The server encountered an internal error or misconfiguration and was unable to complete your request. Please contact the server administrator, support@mytopia.com and inform them of the time the error...
Facebook did some sort of upgrade today that has been affecting many of the games. If you check the fan page of your game, they may have posted the same message that many games have done today.
It should be back soon.
Aug 11, 2011 | Mytopia Bingo Island 2
Server error
Clear System Event Log thru CMOS setup or the management software provided with server . The SEL is full that is the reason the error message
Mar 02, 2009 | HP ProLiant ML150 G3 Server
Server error
The System Event Log may become full of erroneous IPMI Events reported by the System BIOS. When this occurs, the following message may appear during Power-On Self-Test (POST) and POST cannot continue without user input:
02a2: BMC System Error Log (SEL) Full
Press F1 to Continue, Press F2 to Setup
If the above message appears during POST, perform the following steps to run BIOS setup and delete the System Event Log:
  1. Boot the server and press the F10 key when prompted to run BIOS Setup.
  2. Select the "Advanced" menu.
  3. Scroll down to "IPMI" and press the ENTER key
  4. Scroll down to the System Event Log and press the ENTER key.
  5. At the "Clear System Event Log" selection, press the ENTER key to toggle between "Enable" and "Disable."
  6. Select "Enable."
  7. Press the F10 key to Save the changes and exit the BIOS Setup.
Mar 02, 2009 | HP Compaq ProLiant ML110 G4 Server
Dell PowerEdge 1600SC Server problem
I had the same thing happen in a 600SC about a month ago.
Replaced the memory, and it fixed the problem.
It did the same hang. Would run fine for any where from a hour to 3 hours, and then quit (hang). And I got the same message. Talk to them and it was a short in the memory module, so some times it would read the entire stick, other times it would "not see it", and that would lock the OS.
Sep 03, 2008 | Dell PowerEdge 1600SC Server
Error 232*
Error 232 Severity 16
Error message text Arithmetic overflow error for type %s, value = %f.
Explanation This error occurs when Adaptive Server detects an arithmetic overflow error during execution of a SQL statement. Arithmetic overflows occur when a variable has too few places to store the converted data. In particular, Error 232 is raised when an overflow occurs for a variable of datatype float.
Error 232 can occur during execution of the convert function. It can also occur during implicit conversion within Adaptive Server, either during a stored procedure run or during execution of a SQL statement which converts a float value to some other datatype.
Action Determine which variable is causing the problem based on the datatype reported in the error message output and the SQL statement on which the error occurred. If the error occurs within a stored procedure, an additional error message will be displayed showing the name of the stored procedure and the line number where the error occurred.
Increase the size of the variable that is causing the error. If it is in a procedure, re-create the procedure.
If this error occurs on a Sybase-supplied system stored procedure, contact Sybase Technical Support.
Versions in which this error is raised
Jul 24, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Error message connecting web cam on yahoo messenger
make sure that the web cam attached to the personal computer nor
in remote computer . if it attached to the remote computer it may have permission problems.
Dec 13, 2007 | Logitech Webcam
Computers & Internet Logo
232 people viewed this question
Top iSedora Computers & Internet Experts
David Payne
David Payne
Are you an iSedora Computer and Internet Expert? Answer questions, earn points and help others
