Question about Maytag Dryers
Dryer not venting properly
We checked and cleaned out the lint trap and the hose on the back of the dryer. We then checked the hose out to the outside vent. The dryer is letting out a little bit of air but when you turn it on and let it run for a minute, open the door, it lets out a BUNCH of steam. The air is not getting out to the vent on the back of the unit. The outside of the dryer is also hot to the touch. It is a Maytag dryer - model # MDET236AYW - Serial number is 11187451JT. Can someone please help me with this? Thank you.
  • Maytag Master
  • 3,361 Answers
Unplug the dryer.
Raise the top lid.
Remove the front panel.
Inspect the blower wheel attached to the motor.
It is probably turning on the shaft.
If so, replace the blower wheel.
If not, dig the lint out of the vent between the wheel and the rear of the dryer.
Posted on Mar 12, 2009
Dryer does not dry well , an the turn knob does not turn while the dryer is on towards turnning off.
Lint Trap
The lint trap is a metal screen with a plastic handle that is located either near the corner at the top of your dryer, or inside the dryer door. In most cases, the lint trap is clearly marked. If your clothes are not drying properly, this is the first place to look because it is the easiest problem to solve. Remove the lint from your lint trap, and then see if your clothes get dry. If they do not, move to the next troubleshooting problem.
Vent Hose
To work properly, a dryer needs to be able to vent warm air. If the vent hose is clogged, bent or has a hole in it, your dryer will not work properly. Examine the vent hose to see if it is installed completely over the dryer exhaust vent, and to make sure it does not have a hole in it. Remove the vent hose to see if it is clogged. There are vent hose brushes you can purchase to clean the vent hose properly. Also check the exhaust vent on the dryer and the outside vent to make sure they are not clogged.
Thermal Fuse
If you have been running your dryer with a clogged vent hose for a while, you may burn out the thermal fuse. A burnt thermal fuse will allow the dryer drum to rotate, but the unit will not heat up. Your owner's manual will show you where the thermal fuse is and provide the part number you need to buy to replace it. Thermal fuses are available at most hardware stores and are easy to replace.
Heating Element
The heating element is the long, coiled wire in the dryer that heats up the air. Over time, the heating element can burn out or become defective. In some models, the heating element can be repaired; in other models, the heating element should be replaced. Refer to your user's manual to see where your heating element is and whether you can repair it or need to replace it.
Jan 09, 2013 | Dryers
My dryer is heating fine but there is no air blowing out of the vent. Therefore, clothes are not drying properly. I have cleaned the lent filter, checked the outside and and inside vent for clogs or...
run the dryer with the vent hose off, if it drys correctly then it is in the vent tube. The best way to clean the vent hose is with a leaf blower, now if it is not drying with the vent hose off then you will need to disassemble the dryer, and clean from the bottom of the lint trap back to the back of the dryer with a brush(paint) and a vacuum:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Washing comes out covered in fluff and bits after drying?
check to make sure that the lint trap is clean and clear -- also check the exhaust hose and outside vent for any obstructions. also check the vent holes that lead to the lint trap -- sometimes these can become plugged up with fibers and not lint out the wash proper.
c...
Dec 31, 2010 | Zanussi ZWD1270 Front Load Washer / Dryer
Dryer has heat but clothes are still wet we dryed a dog pillow that came open and the stuffing went all inside. we took the back off and the shoot for the lint trap but there was no more lint.
If your machine is running properly and you have heat as you say then you may have a clog in the main vent line from the dryer through your house.
Try running the dryer once with the vent hose disconnected. If it dries your know the clog is in the house's vent line. Unusual but it does happen if you have a lot of lint.
Check first at the immediate opening point in the wall there is often a 90 degree elbow where lint can trap.
The other place is the cover plate on the outside of your house. Some at are static and others have vents that open and close. Those too can trap lint and cause a problem.
If you know you have a clog in the house line somewhere but the opening and exit are not clogged then take a drain auger (same as used to clear a clogged toilet) and run it through. If you don't have one try your garden hose.
Good luck.
Please rate if this gives you some direction.
Mar 13, 2010 | Kenmore 62602 Electric Dryer
The cycles have stopped heating. We have replaced the thermol fuse twice now in two weeks. Noticed when I touch the button to start a cycle, the readout is saying to check filter. Where is that? I'm...
Go outside and look at your flapper valve. Here is another news flash the lint filter can be clean but the air ducts in the dryer can still have lint build up in them. Pull out the lint trap also then using a flaishlight look underneath and around the lint trap area for lint build up. If you don't see anything there remove the rear vent hose and look both into the dryer and into the vent hose. Most likely you find either a kinded vent hose or lint buildup somewhere other than the lint trap itself. If you do find the source just do not use anything sharp to attempt to remove the lint. A bent metal coat hanger or a very large zip / spot ite works great for this task. Hopefully this will resolve your problem. If not post back and we can go from there.
Jan 14, 2010 | Dryers
Dryer does heat but takes 3 hours to dry a medium size load of clothes
Sounds like the moist air is not being properly vented. Your dryer has a fan that pulls in dry air and expells the moist air. This is vented thru your dryer hose and should be vented to the outside of your home. Sometimes the hose will get either a blockage or a partial blockage that will make it either not dry your clothes or take longer than it should. I have seen hoses that have a sag collect water much the way your trap will under a sink. You can either throughly clean the hose, and check for a blockage in the hose or the dryer itself, or you may, as a test, disconnect the hose temporarily and vent your dryer into an old pair of panty hose. When you turn the dryer on, the panty hose should inflate. Also make sure you keep your lint trap clean...EVERY LOAD.
Oct 02, 2009 | Amana DLE330RAW Electric Dryer
Dryer shuts off on E-1 code..Lint trap has been cleaned as well as vent hose and vent riser to outside.
Check for brisk air flow at outlet of vent hose (hose disconnected). If weak, remove lint screen and retry. If now has brisk flow, clean screen in hot water and detergent.
Aug 01, 2009 | Dryers
Lint filter sensor with Error Code: 01 constantly comes on after the dryer is in use for 5minutes or less. Screen is clean, vent from back of dryer to 3ft of flex hose to outside wall is spotless.
Sounds as though the sensor is dirty of faulty. I would recommend having a service tech out to check and replace. Also if the sensor is going bad, it may be tripping it due to the excessive heat.
Apr 08, 2009 | Bosch Nexxt 500 Plus Dryer
Roper dryer
YOU HAVE A VENTING ISSUE WHICH CAUSE SLOW DRY STEP1 REMOVE LINT FILTER AND CLEAN WITH HOT WATER AND SOAP STEP2 MAKE SURE YUO'RE NOT CRUSHING YOUR VENT HOSE BY HAVING DRYER PUSHED TOO FAR UP AGAINST WALL STEP 3 CHECK OUTSIDE VENT TRAP IS NOT OBSTUCTED BY LINT IF THESES STEP DOESN'T WORK HAVE PROFESSIONAL CHIMNEY SWEEP INSPECT AND CLEAN VENTS
May 28, 2008 | Dryers
Dryers Logo
175 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
