Question about Samsung HT-DS610 System
Power plug in the home theatre system the hello banner comes on,then it says protection, then its says goodbye.the red power suts off for about 5 seconds then comes back on.The unit is only 18 months old. any suggestions
  • 3 more comments
  • paullb Nov 05, 2007
    comes on says protection..shuts off
  • Nevada Dec 14, 2007
    I press power button. Display says Hello, scrolls says Protection, unit shuts off.
  • campo Dec 17, 2007
    when i turn the receiver on say hellow protec and turn of
  • Anonymous Dec 21, 2007
    I have the same exact problem...
  • Anonymous May 20, 2008
    same problem, our cable went out and my son watched a movie several times then the protection problem happened.....
Same thing ..
Posted on Jan 18, 2008
SOURCE:
I have a samsung HT-Z310 home theatre. I left plugged and when light was restored the power ic blew. So i replaced and the power came back on but immediately it comes on it say protect.
That's the power supply board isn't it. Have you checked the main power amp board? For when the power board failed it might have taken out the main power amp with it!
Jul 25, 2016 | Samsung Audio Players & Recorders
Toshiba sd-kt50 dvd player turn on open/close hello appears protection appears and goodbye comes up turns it self off. we had two second power offs not associated with a storm
the sudden power cut-off can either blow the fuse or corrupt the system of DVDs.but, some DVDs has protection for this occurrence.try not to use it for sometime.then if it's well rested try turning it on see if is resets it's protection circuit.if not, a new unit or call a technician for it.
May 07, 2009 | Televison & Video
Instalation instructions required
Uhmmm. . .okay. . .I would use nothing less than 16AWG speaker cable. Do not run the speaker cable parallel in close proximity to any AC wiring. Speaker cable rated to run through walls with usually be color coded red and black. Connected the red to the red on the speaker and red on your home theatre receiver. Do the same for the black. If speaker cable insulation is clear, look closely for subtle markings or writing on the insulation. The writing will only be on one of the two wires. Designate that as the POS or PLUS or + or RED. Connected it to the red on the speaker and the red on the back of your home theatre receiver. The other is by default the black and connect it to like colors. Repeat for all 5, or 7 speakers in your theatre. Your subwoofer probably has a seperate amplifier, so it gets it's power from it's own AC power plug. . .so plug it in. The sound coming from the Home Theatre receiver will be low-power and will carry on an RCA cable. Look for the subwoofer output on the home theatre and connect it to the input on the subwoofer. There may be a right and a left input on the woofer. . .it doesn't matter which you plug it into. . .either one will do.
Mar 09, 2009 | Audio Players & Recorders
Sound goes off
You probably have too much power running to your power strip that you probably have your xbox, playstation, tv and home theatre system plugged into, try using seperate wall outlets for your tv and home theatre system
Dec 20, 2008 | LG LHT854 Theater System
Samsung HTDS610 Home Theater System power wont stay on!
I have the same problem.
I did my research and this is the solution:
Your HT system is overheated and the fan is not working. Just replace the fan and you will be good to go.
Ken
Aug 06, 2008 | Samsung HT-DS610 System
We are trying to watch a movie on our new ht-tx72 dvd home theatre system...but it keeps shutting itself off and saying protection goodbye....what can we do to fix this?...it is getting frustrating now
Your ICs audio amplifiers are in short circuit thats why that legend are coming for protect your theatre of more damage you got to replace the ICs.Good luck
Apr 13, 2008 | Televison & Video
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
Samsung HT-DS610 System Logo
239 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
