Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
No Network Adapter
I install Xp with SP2 on my HP Pavilion Laptop that once had Vista and now I cannot connect to the Internet through my wireless. I am of the opinium that the drivers need updating but i cannot since I no longer could connect to the Internet What could I do
  • 463 Answers
How, then, are you connecting to the internet at this time to write for help? From another computer?
Purchase/acquire what is known as a "thumb drive", a little USB device that will hold files.
From a working computer: go to http://www.hp.com , click on support and drill down to your computer type. Download the driver in question to the thumb drive.
Unplug thumb drive from 1st PC.
Boot 2nd ("errant") PC.
Plug thumb drive into 2nd PC.
Run X:\blah\setup.exe or whatever the name of the program is that installs the wireless drivers.
Cha-ching!
Posted on Mar 12, 2009
  • 76 Answers
Well since you posted this issue that means that you can get online with a computer purchase a flash drive go to the manufacture site and download the drivers needed even if its just your Ethernet driver thats enough to get you online long enough to download the rest of the drivers you need for you computer
I have a hp pavilion dv6 and need to turn my wireless connectivity on
Go to control panel and click on device manager, scroll down to network adapters and find your wireless adapter. Once found right click on your wireless adapter and see if there is an error found usually you will see an attention mark yellow if there is an issue with the network whether its a driver or not. If it is a driver right click on the network adapter and click update driver.
If the computer has the best network driver for the hardware, right click on the wireless adaper once again and uninstall, restart your computer. Once restarted your computer should recognize your wireless adapter and you should be able to access the internet.
If unable to access the internet check the connections to your router and modem, if that doesnt work your will have to refer to your manufactor due to a bad network adapter/
Nov 17, 2011 | HP Pavilion dv6000z Notebook
I have F5D7234-4V1 with insight internet connection and i have win-xp laptop , ERROR MESSAGE - (windows cannot configured wireless ) tell me what to do - But unable to start WZC on my computer
If you want to use Windows Wireless Zero Configuration to manage the wireless network, you will need to have Windows XP with service pack 2 as a minimum.
With Windows XP and SP2, you will need a Microsoft update for WPA2 that can be obtained from:
http://support.microsoft.com/kb/893357/en-us
After installation you will need to use the Windows Zero Config wireless configuration in the control panel to configure the adapter. WPA2 should now be available and work correctly.
Windows XP with Service Pack 3 and Windows Vista offer support for WPA2 without additional updates.
Nov 04, 2010 | Belkin F5D7234-4 Router
The wireless networking on my HP Pavilion laptop suddenly stopped working correctly. I can now only get online via ethernet. When I open up the "Connect to a Network" page, none are displayed. Then when I...
Need to contact the HP Tech Support Number 1-800-474-6836 and checked whether the notebok was under any recall for WLAN Card and if yes and i'm sure it would have expired then Its time to pay $259.99+ taxes and get the Motherboard replaced for you can order Linksys WUSB600N Dual-Band Wireless-N USB Adapter worth $ 79.99 + Taxes to use Wireless Internet efficiently
Aug 18, 2010 | HP Pavilion dv6000z PC Notebook
HP pavilion network adapter not found
You need to download the drivers from the Compaq/HP WEB support/download page. Make sure you select your model computer and the XP Windows version of the drivers you require and install them. Use this link to download the drivers :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Aug 03, 2009 | HP Computers & Internet
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
HP Pavilion dv9000 17" (Windows XP) lost my wireless internet
Hi there.
If your using Vista or XP, what i want you to do is right click "computer" select "manage" and then "device manager", then click on the + sign next to "network adapters" and right click on the wireless network and "un-install" the device, reboot the PC and wait for windows to detect the wireless card and install the drivers for it, this will appear in the system tray (bottom right hand side) when its done try to connect again
keep me informed please
Good luck and thanks for using FixYa!!
Apr 03, 2009 | HP Pavilion dv9000z Notebook
Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Mar 22, 2009 | HP Pavilion a1320n (882780261747) PC...
My Hp pavilion tx2000 cant play audio files,cant connect to net
Hi James
First, Sound drivers:
HP Pavilion tx2000 CTO Notebook Realtek High-Definition Audio Driver 6.0.1.5494 A from HP notebook
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38206.exe
and video drivers..
HP Pavilion tx2000z CTO Notebook NVIDIA GeForce Go 6150 Video Driver 7.15.11.5682 A
http://notebook.free-driver-download.com/url.php?id=TlRJeE5Eaz0&link=0
Now network:
HP Pavilion tx2000 CTO Notebook NVIDIA nForce Chipset/Network Driver 5.53 A
ftp://ftp.hp.com/pub/softpaq/sp38001-38500/sp38205.exe
and wireless!
This is an older WIFI driver that only works in XP, and in certain HP Pavilions, but try it.
ftp://ftp.hp.com/pub/softpaq/sp36501-37000/sp36684.exe
and this is the Vista one that is correct for your laptop, it probably doesn't work in XP but if all else fails, you could try it. (You should really run Vista on it, I reckon)-----------------
HP Pavilion tx2000 CTO Notebook Broadcom Wireless LAN Driver 7.0 Windows Vista
http://notebook.free-driver-download.com/url.php?id=TlRJeE5EWT0&link=0
All support you need is here at HP Tech Support:
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=3650975
Good Luck
Merry Christmas
Chris (ziraffa)
Dec 23, 2008 | HP Sound Card
Wireless connection problems
Download driver Acer Aspire 5100 for Atheros Wireless adapter ar5007ag
Aug 22, 2008 | Acer Aspire 5500 5570-2609 Laptop
Wireless Network Driver
Dezzie.
This software will work with your Toshiba Laptop. This software was created by Toshiba. You need to install the Network Adapter. So go to Toshiba's website and update your network adapter drivers for win XP SP2.
Please let me know how this works.
Thank you
Cabletech
Nov 22, 2007 | Computers & Internet
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
115 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
