Question about Dell Mini Computers & Internet
How do you fix a motherboard - Mini Dell Computers & Internet
  • Dell Master
  • 32,281 Answers
It depends upon the fault. Usually motherboards cannot be repaired and the motherboard is replaced.
Posted on Apr 23, 2013
Will an N71JQ-TY002V motherboard fit in N71JQ-x1 motherboard spot
Say me the motherboards problem, mabie it is possible to fix that problem, and why u wana to change motherboard wihout trying to fix it...
I am telling you if your motherboard is killed, the price of motherboard is 2/3 of the PC.... wayting for answer...
Jul 06, 2012 | ASUS N71JQX1 PC Notebook
Hi I have a GIGABYTE GA-81848PM motherboard.You or someone have posted that sometimes to fix a dead motherboard is enough replace some condensors...how can I know which are the condersors that I have to...
Honestly, I have been fixing computers for a while, and it is much easier to just replace the board. In order to properly test and replace condensers on a motherboard is usually more trouble than its worth
Jan 09, 2011 | Intel Motherboard
How to fix the usb pins into motherboard. how to
Here is the link to Official Intel Product Guide with all the information about Intel D102GGC2 Motherboard and its front panel connections etc. Refer to Page -39
Let me know if any further clarification is required
GoodLuck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
Dec 07, 2010 | Intel D102GGC2 Motherboard
It went off and it has no power since. This was bought only last Aug 2009 and I use it around 2 to 3 hours a day only. I had it checked and they said problem is with motherboard. Is there any way this can...
If you have tried using another charger, with and without battery, and it's the same then the defect is definitely in the motherboard. As a last hope you might try to fix it yourself: open it and try to locate the faulty part - start by looking at the capacitors then test the power transistors.
Sep 30, 2010 | Intel Motherboard
How to replace motherboard
1. Contact eMachines, and purchase an identical replacement motherboard.
2. Disconnect all the exterior cables from your computer (keyboard, power, mouse, et cetera).
3. Remove the side-panels.
4. Disconnect all the interior cables from your motherboard (power, data, audio, et cetera).
5. Unscrew any screws holding add-in cards (modem, video) in-place.
6. Disconnect those add-in cards from the motherboard.
7. Unscrew the mounting-screws that hold the motherboard to the case.
8. Lift out the motherboard.
9. Take the RAM out of the old motherboard.
10. Take the heat-sink-CPU-fan and CPU off the old motherboard.
11. Put the CPU and RAM onto the new motherboard.
12. Reverse the above steps, to reassemble.
Jul 17, 2010 | E-Machines eMachines Desktop PC
I need to replace the small motherboard fan. Any
Hi friend,
Yes this is easy task,if you wand to change the motherboard fan than firstly remove the power cord in CPU,pull out the side cover of CPU and than you see the motherboard fan in front of you,Two fans available in system one is CPU FAN and another is motherboard FAN,you need to change motherboard fan,this is attached in motherboard with two iron stick,press the both stick through thumb and press the upper,now you remove the older motherboard fan and fix the new one.after fix the new fan press both iron stick and fix it.
plug the power cable and switch on the system.
Thanks,
Jan 16, 2010 | Evesham Axis 64 FX (AXIS64FXMAR04) PC...
My computer uses a SOYO motherboard SY-P4VGM v1.0 and slowed down tremendeously. Best Buy checked and found 3 bad capacitors. They won't fix it. If I can buy the capacitors I can replace them myself. Or...
Unless you are a skilled electronics technician who has significant experience with heat sinks you are unlikely to be able to successfully fix your motherboard. It is much more likely you will fry some other component(s) while trying to perform the solder.
I recommend you buy a working motherboard still under warranty.
Oct 10, 2009 | Soyo SY-P4VGM Motherboard
Can't find wher can i fix the restart and the led bottons in the motherboard
There should be two rows of metal pins on the motherboard. The pins are about 5mm tall and have white letters printed near them on the motherboard. HDD PWR RST SPKR You connect your wires coming from the lights and switches at the front of the computer to these pins.
Jun 02, 2009 | Iwill MP4G Motherboard
USB ports don't work
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
khandan10
Apr 02, 2009 | ASUS P4XP-X Motherboard
Computers & Internet Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
