Question about Jacuzzi Pool & Spa
Jacuzzi jsn-180f bought new and installed to specs, when turned on code 12 appears when burned should light
2000 acura tl coolant fan after fluid change
New thermostat, installed, saw, new coolant made a little mess filling reservoir, (normal) checked fan fuse for some reason, and condenser fan fuse (xxx ?:), and temp guage, is slightly lower on gauge (than normal?) (disconnected xxxx? quit? a bit? to get to thermosta?.t no dash warning lights have a feeling I popped a relay.
Answer:
ok, you did a coolant service with STAT,
and it failed.
tell us what works right and wrong, symptoms only.
over heating? parked, (fan never comes on)? as it hits 225F?
under heating? ( fan stuck on , up North can cause huge cold engine)
dash gauge stuck low. (thermostat wrong heat range 180f is best. see FSM for spec. on this temp. spec..
Dash guage varies.? oddly (air in system)?
Dash gauge too high.? (Stat put in upside-down or bleed hole (jiggle) not UP side. higher side of mount , trapping air.)
Does something wrong happen only driving?
leaks?
does cap on rad hold 12-14psi pressure, hot.?
if car has fan belts, are they tight? (for sure water pump does)
Nov 19, 2013 | 1994 Honda Civic
Jacuzzi tankless water heater code 12 appears
For my Jacuzzi tankless water heater model #J-SN180F: It turned out to be an exhaust issue. If I take off the exhaust vent completely then the talks heater works with 3 baths at full hot water. I get the error code 12 again as soon as I put event an elbow of the vent. So my conclusion is I need some sort of straight vent.
Apr 22, 2013 | Water Heaters
When I try to turn off my Jacuzzi tub it will not turn off. I pushed the gfi and it went off. I then reset it a few days later and the tub would not turn off and this time the gfi would not shut it off. ...
You will need to have a technician from the store you purchased it from install a new switch.
To be up to code, you should have a GFI for your Jacuzzi to plug into and a GFI circuit breaker dedicated only for your Jacuzzi. I
If you already have it, that's great, but if not check with an electrician for installation.
Regards
Apr 05, 2011 | Jacuzzi Mito, 5 Soaking Bathtub -...
I just bought a home that has a 3 year old white Jacuzzi Cetra H526 000 Whirlpool Jetted tub. It was not well maintained. I need 4 new Thermo Pro Jets, 2 Accu Pro Lumbar Jets, a square grille,and a product...
Jacuzzi Cetra Comfort Bath home page:
http://www.jacuzzi.com/baths/options/models/cetra
Installation and Operating Instructions:
http://www.jacuzzi.com/admin/files/files/4cfd8269-e7b0-4286-9908-7b9743.pdf
For replacement parts your best bet is to you use the on-line dealer locator:
http://www.jacuzzi.com/baths/pages/dealer-locator
or you can shop on-line from one of their authorized retailers; however did not see any of the parts you are looking for at the sites I checked:
http://www.jacuzzi.com/baths/pages/buy-online
Mar 17, 2011 | Jacuzzi Home
What is the rough-in specs for installing the flange for this toilet?
Usually 12 inches in from the wall, but measure the toilet to be sure.
Oct 09, 2010 | Jacuzzi Bath Perfecta EZ33 959 White round...
Old Jacuzzi Vectra (86), not cycling!
Keep giving it a few kicks! When that happens to motors it usually means that it is on its way out, I'd milk it for as long as possible but start thinking about a new pump and motor.
Aug 03, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Continuous low speed, no heat
At this point after having spent all that money, you have to figure something else is frying those boards.
You need to make a decision whether to A: Call a Jacuzzi repair specialist
B: Replace the the control panel, the board, and possibly even the heater and pump, thermometer and sensors.
C: Cut your losses and buy a new Jacuzzi. Trade this one in on it for whatever you can get. And from personal experience, stay the h*** away from Ebay when it comes to electronics.
May 21, 2009 | Home
I hooked up a Jacuzzi bathtub and pump won't stay on
I bought a new house and I have a jacuzzi bathtube . and all the sudden stopped working .. where or how I can locate the pumpe ? the only thing I see is the button to turn it on or off and now it does'nt go on ?!! I checked the circute praker and everything seems okay to me.... help please.
Mar 08, 2009 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Rapid Heater for Jacuzzi
The light is supposed to be on when the tub is full of water and the pump comes on. Make sure the heater is plugged into a seperate breaker, it cannot be on the same line as the pump.
Look on the heater for a label. If your heater is installed on the discharge side of the pump it should say "pressure heater" on it. If it is installed in front of the pump it should say "Vacuum Heater" on it.
Once installed, fill the tub with water and turn the pump on. If it is installed in the correct position the light will come on when the pump turns on.
Feb 22, 2009 | Jacuzzi RapidHeat In-Line Heater U395000 [...
Will not start
All jaccuzzis must have a GFI breaker or outlet where it plugs in. Find either and reset
Oct 04, 2008 | Jacuzzi Amiga Whirlpool JAC-N888...
Pool & Spa Logo
85 people viewed this question
Top Jacuzzi Pool & Spa Experts
Jay Finke
Jay Finke
Mike
john h
Are you a Jacuzzi Pool and Spa Expert? Answer questions, earn points and help others
