Question about HP Compaq dx2000 Microtower PC Desktop
HP dx2000 failing to boot to usb
I am trying to image my dx2000 mahcine but when I boot to the usb I get a message saying the boot failed. I have all the driver updates and windows updates but it still fails.
  • 352 Answers
SOURCE: not recognize usb printer hp laserjet 3050
Hi, I would suggest you update your printer drivers with fresh drivers, try this, follow instructions exactly as written:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
anaanymous
Rate Me Please! Hate it? Rate it…Like it, try it!
Thank you for submitting your question to FixYa.com
Would you please take a moment and show your appreciation by rating my performance.
All ratings and comments are welcome. Thank you - anaanymous
Posted on Oct 21, 2008
SOURCE: cartridge failed
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Posted on Oct 29, 2008
Inkworks
  • 87 Answers
SOURCE: alignment failed notice
Could be one of two things....
1 - you may have bad cartridges...when the machine does an alignment it looks for specific marks on the paper...ie..green check marks before each line etc...if the correct marks are not there you will get an alignment failure...if the green check marks are there etc then you have a different problem...
2- spot sensor on the side of carriage is not working...this is the little blue/green light that comes on during alignment. Its what reads the markings on paper so if the markings are correctly there and you still get this error then the spot sensor needs to be replaced. Simple fix that u can do. We sell the spot sensor for $15
Change cartridge (color first) before doing anything.
Inkworks
866-381-0541
Posted on Nov 06, 2008
SOURCE: My Hp desktop does not boot. It requires F1 key to be press. Why?
WHEN I START MY PC IT REQUIRES TO F1 FOR START PLEASE HELP ME
Posted on Feb 16, 2009
  • 189 Answers
SOURCE: Desktop PC system fan failed error
hello.. this means that the fan which cools your pc is not working, get a new fan for your mode and fit yourself if possible or go to computer technician.
do not keep it using as your pc may crash.
its very important to keep the cpu cool to keep computer working. hope this help.
Must rate me.....
Thanks
Posted on Mar 25, 2009
My Tab will not start, I receive two different "draw failed" messages...if it is charging, it says, 'charging_7.jpg' draw failed. If the USB isn't plugged in the message is logo_expresso7.jpg draw fai
It sounds like the system image (operating software) got corupted and need to be re-installed. If you haven't got a backup image of your tablet, then you need to take it to a cell shop so they can re-install your OS (Operating System) software.
Mar 19, 2014 | Samsung - Galaxy Tab 2 7" 8gb Wifi
Tip
My hp pavillion g6 wont boot
By pressing f11 repeatedly during start up will pop up dialog box to access system recovery image. But if the system image has been deleted accidentally, check if you have a friend with the same model copy the recovery file from his computer. You will locate the recovery file when you open my computer. Then connect the usb device and try restart your system using 11. If it fails enter setup and change the first boot device to usb and still press f11 for the system to see the system image file. Otherwise look for original os cd for your computer. Nnamdi
on Jun 25, 2014 | HP Pavilion dv6000z Notebook
Tried to boot from USD, CD/DVD Drive but failed. Still showing No bootable device -- insert boot disk and press any key
To boot up from the DVD drive go into the BIOS setting - boot device order and move the DVD as the first boot device and the hard disk as the 2nd boot device.
If you want to boot up with the USB then move the USB as the first device. If the USB is not listed as a boot device then it is not possible to boot up with an USB device.
May 26, 2012 | Acer Aspire 4930-6862 Laptop
AT POST motherboard hang at INITIALIZING USB.....
Several things you can try:
  • Remove the CMOS battery leave for 10 minutes and re-insert and try to reboot
  • If this fails to solve the issue, check the BIOS (F2 on boot) and disable USB legacy support
  • Then if that fails, try swapping out the RAM modules until you manage to get a successful boot.
  • If you suceed in this, download memtest and check the integrity of the ram modules, it may be you have an intermittently faulty ram module.
  • If this fails, it is likely that the USB controllers on the motherboard are damaged
May 19, 2012 | ASUS P5GL-MX Motherboard
I have a HP Compaq DX2000MT computer. When I want to start up the pc, he gives 10 beeps and the following message : Chassis fan not functioning, check fan connections & call for service. Shutting...
Without the chassis fan the pc would overheat and fry so it's shut down. Do what the warning message says: open the case, clean the interior and check the wire connector of the fan. If the fan still doesn't turns then it has failed and it will have to be replaced - a new one costs$10 at every pc shop.
You will need the manuals for service and maintenance
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?lang=en&cc=us&contentType=SupportManual&prodTypeId=12454&prodSeriesId=401819
Aug 07, 2011 | HP Compaq dx2000 Microtower PC Desktop
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Every time the system is turned on it says Non-system disk or disk error, replace and strick any key when ready. There are no disk in the disk drive or the sd drive. No matter how many keys you strike...
Your computer tries to "boot" from various devices:
* bootable files on a USB memory-stick or SD memory-card
* from 3.5-inch diskette drive (if installed)
* from CD/DVD disk
* from your disk-drive
Your computer tried to boot from your disk-drive, but FAILED to do so.
Since the disk-drive is "dead", it tries to boot from any of the other devices,
and displays that error-message when it cannot boot.
So, your disk-drive has "died". Ouch!
You need to purchase a new disk-drive, and reinstall Windows onto it.
Dec 23, 2010 | HP Compaq nc6000 Notebook
My pavilion dv5000 says on startup media test failure check cable
Computers can start-up ("boot") from many different devices:
* 3.5" diskette,
* CD-ROM,
* USB memory-stick,
* disk-drive,
* network,
* external USB CD-ROM
and so on.
Your computer is trying to use the network adapter to download a bootable image through a connection with a network-cable to a "network-boot-server" computer.
In your case, "check cable" means that your computer's network-port is either *NOT* connected to a network, or that no "network-boot-server" responded to the request to download to your computer.
First, check the "boot-order", i.e., the priority of each of the bootable devices, to ensure that "boot from network" has a LOWER priority than booting from your diskette, your CD-ROM, and your disk-drive.
Second, check that your disk-drive *IS* one of the bootable devices.
Is there any bootable media in the diskette?
Is there any bootable disk in the CD-ROM?
If not, then your computer has *TRIED* and *FAILED* to boot from your disk-drive, and then tried and failed to boot from the network.
So, it's possible that your disk-drive has failed.
Take the computer to a qualified technician, and get them to remove the disk-drive from your computer, and to connect it to another computer, to see if the disk-drive still is in working-order.
Nov 05, 2009 | HP Pavilion dv5000t Notebook
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
I am getting an error message when booting PXE-E61
The hard drive is most likely failing. It is being detected but is not functioning (when a boot device isn't seen or fails to boot, the system trys to boot to network and that causes the PXE error.
Most likely, since the drive detects, but doesn't work, replace the HDD
Jan 26, 2009 | Computers & Internet
HP Compaq dx2000 Microtower PC Desktop Logo
217 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
