Question about Husqvarna Garden
What are the timing specs on a Husqvarna 36-r string trimmer
I have a Husqvarna 36-r trimmer that i am installing an ignition module in and I need to know what the timing specifications are.
  • 181 Answers
There is no timing spec . the air gap is .010 to .012. or .254 mm to .305 mm.open the gap all the way up and tighten the screws.bring the flywheel magent to the coil making sure that both sides of the coil is on the magnet.slide the gapping tool in and the magent will hold it in place.once it's there release the screws holding the coil and the magents wiil pull the coil to it.once it's there retighten the screws and your done.
Posted on Mar 12, 2009
Husqvarna Problems
unplug the kill wire and then check
Oct 29, 2013 | Husqvarna 128L Line Trimmer
Husqvarna 36 cc chainsaw wont start replaced spark plug cleaned carb
Are you getting a spark..? - NO? check wiring loom from ignition module, check timing gap between flywheel and ignition module, check on/off switch.
Does it have compression.? - NO? then check piston/rings and cylinder
Is fuel getting to the cylinder.? - NO? Carb problem of fuel line issue
Dec 06, 2012 | Husqvarna Garden
Replace string on 323L tap out line terimmer
I'll send you a link to the online manual.
Mar 22, 2012 | Husqvarna 28cc Gas Line Trimmer
How can I determine if my husqvarna magneto is working?
Remove spark plug from the engine, reconnect it to the plug cap cable which come from the bobin.
Find a piece of steel wire jumper, atleast a foot. Make a jump from the metal body of the plug to the chassis of the engine.
Safety issue: Place the plug away from the spark plug's hole on top of the engine to avoid gas ignite.
Set the trimmer on the floor, set the gap of the spark where visibility while you pull the string.
Pull the start string and the arc could be seen right on the plug gap. Consider an Arc Purple or Blue coloration are good.
If the arc has not been seen, the Magneto need to be serviced.
Jun 11, 2009 | Husqvarna 28cc Gas Line Trimmer
Garden Logo
796 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
