Question about Garden
Troy-bilt gas Pressure Washers won't start - Garden
  • 508 Answers
SOURCE: Troy Bilt Pressure Washer Model 01902 Leaking Gas from Air Filter
try banging lightly on carberator with block of wood or something to free up float and valve!!!!
Posted on Jul 01, 2009
  • 174 Answers
SOURCE: Soap will not siphon on my Troy Bilt pressure
Are you using the soap on low pressure. This is the only way it will work
Posted on Sep 20, 2009
SOURCE: oil for a troy bilt 2550 psi pressure washer pump
What fluid and how much is required in the Troy-Bilt 2550 power washer pump?
Posted on Apr 18, 2010
SOURCE: troy-bilt 2200 psi pressure washer
I have a Troybilt Model 2200 PSI Pressure Washer in which I have used only 2 times in the past 2 1/2 years. Went to use it this past weekend and the pump in not working. Water shoots out of the side. I bought this brand and model as I thought Troybilt was suppose to be so good. Went back to where it was purchased and had no success but to say I could buy another pump or take it in to be repaired. I believe that this power washer should be replaced at no charge. 2 uses does not constitute a few hundreds of dollars.
Have you to heard anything concerning pump problems on this particular model? Thanks for any advice. .
Posted on Jun 08, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
All outflow stops when I start the motor on my Troy-bilt 2600 pressure washer. What's up?
Could also be crack/leak in HP pump. If it were left in cold weather without antifreeze, I'd check there first. Part + labor might warrant new washer if more than a couple years old.
Sorry.
Aug 11, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
020488 USER MANUAL
Contact Troy-Bilt...
http://troybilt.custhelp.com/
They have a page for Pressure Washers explaining thet tehy do not build their own pressure washers...
http://troybilt.custhelp.com/app/answers/detail/a_id/430
Jul 14, 2014 | Troy-Bilt XP 2800 PSI 2.5 GPM Gas Pressure...
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Drive system not working
I'm not sure what you are expressing. Give us a call when you can be at the washer so we can diagnose it over the phone.
Dec 15, 2013 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
How do I change oil in my Troy Bilt Model 020245 pressure washer
if its a vertical engine it;s underneath the base of motor look for a plug with a square slot in it i usually use a 3/8 " extension
Aug 21, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Change oil in Troy Bilt 020245 pressure washer pump
underneath base of motor look for a plug wuth a square slot,i normally use a 3/8" extension with ratchet.
Aug 20, 2013 | Troy-Bilt Troy - Bilt 020245 Pressure...
Garden Logo
293 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
