Question about Poulan Pro PRRT850 17 Tine Tiller
What kind of oil to put in gear box of 850 tiller
How much grease to put in gear box on a honed fg100
If it is heavy grease and not a 90 weight or better gear oil, you can pack it full. Use solvent and pressure to get all the old stuff out.
Oct 06, 2013 | Honda 25cc 4-cycle Mini Tiller
What kind of oil is in gear box of a ariens RT5020
What type of oil do you use on an Ariens RT5020?
Mar 20, 2013 | Garden
Jerry, I just want to service the gear box on my front end tiller, I guess just opening it and adding grease. Anything else that I need to do to this 40 + year old tiller?
Is the gear box still good? In a lot of older tillers the gear boxes go bad. This is normally due to weeds getting wrapped around the tines and rubbing away at the seals in the end of the gear box. If you have to add oil (grease) then the seals are probably leaking. You should not have to open the gear box up, there should be a plug in it. The plug should be about half way between the bottom and top of the gear box. You should be able to fill the gear box up to that plug with a squeeze bottle. Please rate my answer so I am rewarded points for it.
Jan 29, 2012 | Mtd Garden
How much gear oil for gear box and gear case
most gear boxes have a bottom drain and a side fill plug , you fill until the oil runs
out of the top plug
Oct 18, 2010 | King Kutter Ii Gear Driven Rotary Tiller...
I have a horse tiller. How do you ck. the oil in the gear box. Whate wt. of gear oil do you use.
Hole in the top side casting ... remove the plug. 90 or 110 weight gear oil available at yor auto parts store or other fine retailer who sells lubricants.
Jun 23, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
What kind of oil do you put in the gearbox of a 15 year old pony tiller
Hello. The older models use SAE 90 or SAE 140 weight gear oil. joe
please rate my answer as very helpful. Thanks. Joe
Apr 25, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Need to know the kind of oil or grease that goes in transmission
engine oil is sae 30
the the gear box I think is a 90wt
Mar 10, 2009 | Mtd Garden
Poulan Pro PRRT850 17 Tine Tiller Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
