Question about Miele K8952SDED Refrigerator
Miele K8452S sensor adjustment - Miele K8952SDED Refrigerator
Have a Miele 1612 washer whose heater element comes on during any cold only program. As we are off-grid, any unnescesary power useage is unacceptable. Is there something I can reset, or do I just remo
Hi Ed ..
The following is from the Miele handbook and would indicate that the machine can have the water temperature adjusted...... However I suggest that by merely disconnecting/removing the element
the machine's temperature sensors would not allow the machine to work..
A compromise may be to select the lowest wash temperature (ie 30c) This is better than cold water for detergent economy and effectiveness, and machine life.. I understand your situation.
Good luck
Nomess
http://m.miele.ca/OperatingInstructions/en-CA/Laundry/Washing%20machines/Previous%20models/Miele%20Washing%20machine%20Manual%20W1612.pdf
Page 50
Tap water line (cold water) The tap water connection is established using the inlet hose with the blue marking. If the washer is connected to this line only, the appliance will need to be reprogrammed to cold water fill only. Please contact your Miele dealer or Miele Customer Service for reprogramming instructions.
Feb 05, 2015 | Miele Washing Machines
I have got miele fridge freezer but the fridge keep freezing what can I do
Usually a faulty temp sensor on the fridge evaporator, not an easy repair for most, I would personally recommend Miele's fix priced repairs
Service Repair Miele Support Miele UK
Sep 19, 2014 | Miele KFN12923 SD-2 Fridge Freezer, A...
Stops and says adjust load
It could be clogged vent or defective sensors in the dryer and Best way is check for any cloged or rusted or cracked components and use step by step deduction method for trouble shooting
Dec 08, 2013 | Miele Dryers
Miele t 4839c adjust the load
The drum is overloaded (too much laundry), or there is a problem with the moisture sensor not registering the moisture content of the laundry correctly.
Jan 23, 2012 | Miele Dryers
G660 door falls open
Hi.
The problem is either because the spring supporting the door half way up is broken or because the spring must be adjusted.
First perform a door spring adjustment procedure as explained at page 28 in chapter 10 of the Installation Manual.
Here Miele installation manual for the G660. The file is in PDF format.
If the regulation procedure does not do the job, then the spring must be replaced.
This video shows how to replace the spring (model and manufacturer are different-operations are similar):
The spring is usually sold as part of the hinge assembly.
To get parts or to book a qualified technician call the Miele support number listed on the owners manual or use the Contact page on your local Miele website. Here UK website: Miele - Contact Us.
Regards.
Ginko
Nov 05, 2011 | Miele 24 in. G638 Plus Free-standing...
I have a Miele W404SB WPS washing machine. Water leaks out of the door during the washing cycle. Do you have any suggestions how I can stop this. Regards, Teresa Rooney
1. Make sure the washer is level first, with a small torpedo level at the top center edge of the washer ,check at the front and one side. If its not, adjust the 2 front level foot adjusters (at the front of the unit where they touch the floor) to level the washer.
2. If level is ok, check the door seal and replace if cracked or torn or old and hardened.
3. If ok, look at the latch on the door and the washer. Some have an adjustment for how far the door closes to latch. There will be 2 screws or small bolts you will loosen to slide the lever or the latch plate to adjust so the door closes tighter.
4. If ok, then the water level sensor will have to be replaced by a qualified tech.
Sep 04, 2010 | Miele W4840 Front Load Washer
Miele pyrolytic oven: error 90
F90 is a faulty oxygen sensor. This fault clears after resetting your circuit breaker for 24hrs only. you will not be able to use any automatic programmes as the oxygen sensor measures the moisture in the air and then decides how long to cook for. You will need a Miele service technician or a registered service agent to replace the oxygen sensor. This should be covered under warranty but check with your local Miele dealer first.
Mar 14, 2010 | Miele DG 4080 Stainless Steel Electric...
Termostat do not work properly the frige tun to a freezer
Check Thermister bulb is properly attached to the Coil or Replace Specific Thermostate will be ok
Good Luck
Feb 16, 2009 | Miele K8452S Refrigerator
Freezing up
Primary Cause is Thermostate
Secondary Cause only Anti Freez Switch which is attached to the Evaporator Coil unit
Good Luck
Oct 11, 2008 | Miele K8452S Refrigerator
Miele w 1203 not drying towels
could be an unbalanced load ie too many or too few clothes, if so, the sensor within the machine will not permit 'maximum speed' Try load adjustment to see what works & what doesnt
Oct 20, 2007 | Washing Machines
Miele K8952SDED Refrigerator Logo
41 people viewed this question
Top Miele Refrigerators Experts
mike cooper
jhnolson
Paul Bade
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
