Question about Samsung V20 XVC 2400 Notebook
I get error message that my XPS Gen 2 will not boot when I installed a 3rd party battery. The seller says there is something in the msconfig I need to disable for it to work. Anybody know how to get a 3rd party battery to work?
  • Samsung Master
  • 4,806 Answers
Hi there.
If its Vista you are using click on the orb (start menu) in the search box type msconfig, a system configuration window will pop up, in the general tab select normal start up, this will load all the 3rd party drivers after system restart.
Good luck and thanks for using FixYa!!
Posted on Mar 12, 2009
    Brigadier General:
  • 3,614 Answers
what exactly the error message appear,.
  • 412 Answers
Is the battery correct to the model?
    Genius:
  • 1,550 Answers
Disable the ISBMgr.exe in msconfig .
Unrecognised battery
There is a widespread problem with windows 7 and the non OEM batteries not detecting. If your battery will not detect, follow these instructions, and this is a proven fix. If it does not fix, then the issue lies somewhere else.
1) Disconnect AC
2) Shutdown
3) Remove battery
4) Connect AC
5) Startup
6) Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall. Do this for each instance (I had 2 batteries installed, so 2 instances. Most users will only have 1).
7) Shutdown
8) Disconnect AC
9) Insert battery
10) Connect AC
11) Startup
Hopefully, this will work for others!!!
batterywood.com
May 02, 2013 | Dell Latitude E6430 Laptop Computer- 3rd...
Blackberry 8520 app error 523
Hi, app Error 523 is a software hiccup usually caused by a 3rd-party application that is not compatible with the BlackBerry device OS.
Follow the below steps to get rid of this error message:
1. Take the battery out and put it back in after 30 seconds or so
2. While the device is rebooting (or while the hourglass is still spinning), plug it into the PC
3. Then open the application loader and remove the 3rd-party application that's causing the issue
4. Worst-case is when you need to wipe the device using JL_Cmder.
Jan 21, 2011 | RIM BlackBerry Curve 8520 Smartphone
App error 523
Jan 18, 2011 | RIM BlackBerry Curve 8520 Smartphone
Blackberry 8520 app error 523 appears wen i turn on phone.
Jan 13, 2011 | RIM BlackBerry Curve 8520 Smartphone
App error523
App Error 523 is a software hiccup usually caused by a 3rd-party application that is not compatible with the BlackBerry device OS.
4. Worst-case is when you need to wipe the device using JL_Cmder. Follow the instructions here: How do I wipe the BlackBerry using Jl Cmder?
Dec 03, 2010 | RIM BlackBerry Bold 9700 Smartphone
My Jamo i300 will not charge my new ipod nano (4th Gen).
not likely the new 4 gen Ipod has different pin set within its dock connector system for the video output which has made many 3rd party accessories no longer able to charge the ipod but it will still play music
Jan 15, 2009 | Audio Players & Recorders
Photosmart 3310 All-In-One - Cannot install..... Downloaded software from HP web site - 96% install it brings up a "FATAL ERROR" message and then uninstalls it. Running Vista - Help
Hi
The installation will get stalled at 96% , because due to 3rd party service running, will not allow to install HP printer driver.To resolved this follow below steps
1.Disconnect the Printer and uninstall the software.
2.Reboot the PC.
3.Click start, then in "start search" box type "msconfig"(without quotes).Click OK.
4.In System Configuration Utility, Under GENERAL tab, click on SELECTIVE STARTUP, Uncheck "Load System Services" and "Load Startup Items".Click on Apply
5.Then Click on SERVICES tab, at the bottom Check "Hide all Microsoft Services" and then click "Disable all".
6.Click apply and OK. Reboot the PC.
7.Now install the software.
Please let me know once you have done this.
Thanks
Rizwan
Dec 09, 2008 | HP Photosmart 3310 Printer
My pc won't boot, when i turn it on automatically restarts.
What happens when you try booting? does it give an error message?
May 25, 2008 | Computers & Internet
Dell xps 400 won't boot
If you have you have changed motherboard with diferent CHIPSET you need to re-install OS!
Another Couses:
1)Virus Problem
2)Program Conflict on STARTUP-Go with safe mode -with admin privilges then go start run TYPE there MSCONFIG and desable all programs ( do not desable antivirus ) AND restart pc!
3)Another hardware error!
Dec 26, 2007 | Computers & Internet
Samsung V20 XVC 2400 Notebook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
