Question about Sport & Outdoor - Others
Zebco 33 reel diagram
Stoppage & short casts
  • 2976 Answers
SOURCE: Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Posted on Feb 20, 2009
  • 302 Answers
SOURCE: How to I fix a spin casting reel?
You should be able to remove the spool by removing the knob on the front of the reel which also is the drag adjustment. With the knob off the spool should pull right off. Hope this helps you
Posted on Oct 19, 2009
  • 32 Answers
SOURCE: As I was cleaning my Zebco reel, a shiny piece
the shiney pc is the stop so your reel wont go in reverse.look at where the crank go's through the boby of the reel.there are little teeth on it.the little shiney pc =(reel stop) go'e in that little slot under the crank shaft.
Posted on Nov 04, 2009
webberjp
SOURCE: i'm was cleaning a zebco
it goes into a slot at the base of the plastic located near the shaft that goes to the winder. to repair, unmesh the gears and pull the winder shaft out and put C-shaped piece in with tabbed end down into slot located at shaft housing. put gears shaft back through housing and remesh gears. c-shaped piece is for lock after throwing out line and rewinding for line not to run out.
Posted on Sep 17, 2011
  • 3940 Answers
SOURCE: need owners manual for Shakespeare E-Z cast reel
You can find it here
Posted on Nov 03, 2011
How do I remove the front cover from the zebco 33 reel???
Turn the screw a 1/4 turn, then twist the front line cover left to remove it. It may be stuck but this is how you do it. It will move about an 1/8", then pull it straight off.
Oct 31, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
How do I get my zebco to retrieve the line
Your reel has pickup pins on the spool that will guide the line onto the spool when you reel in.
Try holding gentle tension on the slack line just above your reel and start reeling in. If this does not work then remove the top cover of the reel and look to see if the line is tangled up on the inside around the center shaft underneath the pickup pin cover.
if this is the case, simply unscrew the pickup pin cover from the center shaft. It will be on the tight. Remove the tangled line and reassemble.
Sep 18, 2014 | Zebco 33 Platinum Spincast Reel, 5 Ball...
The line will not release when I cast
I am assuming you know at least something about fishing with a baitcast reel. If you do not, make sure you release the thumb button when you cast.
Chances are your line is either tangled or dirty on the inside. Also, the longer the line sits on the spool, the "curlier" it becomes, making it more difficult to get a good cast. I would suggest replacing your line.
If that doesn't help, then its possible that the release pin isn't releasing when the button is released. If this is the case, it is probably time for a new reel. Zebco 33's are inexpensive, and not really worth the trouble to try and repair- better to just invest in a new one.
Aug 08, 2014 | Zebco Spincast 33 Reel
Looking for a zebco 33 reel parts book
Easy one
Got to the website. And type in the model number. there are different model 33 diagrams so make sure you have the correct one for your reel My answers are short and sweet. Common sense mostly. If you are trying to get something for nothing...Don't waste my time! Remember if something sounds to good to be true that it usually is. I've spent many years of my life trying to cheat the system and was pretty good at it. This all changed when I discovered that people were doing the same thing to me. What comes around, goes around. Karma! Now I assist people in making win-win deals...that are legit!
Jul 30, 2014 | Zebco Omega Spincast Reel
Zebco manuals
That would depend on the rod, but usually either the front part of the hand grip can be unscrewed, or there is a screw under the rod that will loosen it.
Jul 26, 2014 | Zebco Spincast 33 Rod and Reel Combo
How do I get my reel to keep from letting the line out while I'm holding down the cast button?
Hold the line with your index finger and against the rod itself. Then cast and release your hold
May 12, 2014 | Zebco 11 Authent Micro SpinCasting Reel...
When releasing the thumb control to cast the line drops free (making it unable to cast)
you have to release the button after you start your cast, distance,height and length of cast is determined by where you release the button inside the forward arc of your cast, just like throwing a baseball.
Oct 18, 2013 | Zebco 33 Authentic Spincast Reel, 1 Ball...
Sport & Outdoor - Others Logo
21 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
