Question about Maytag MSD2756G Side by Side Refrigerator
Maytag Plus side-by-side freezer constantly needing to be defrosted
The problem stems from the freezer door popping open when the refrigerator door is closed. Often this happens without notice by the door closer resulting in the freezer coil to become iced over and unable to perform its function. The entire freezer contents must then be removed and the freezer thawed. It seems that air from the refrigerator section is pushed through the freezer section when the door closes forcing the freezer door to open. Is there some fix anyone has come up with that will help prevent the occurrence of this situation? A latch on the freezer door...but how to install? Something else we are missing....
  • Elaine Poost Aug 05, 2007
    Yes, that is exactly what we could diagnose. With six children in the house, getting them to double check the doors has been completely unsuccessful. We even tried putting a lock on the handles hoping that the extra step would get them to pay more attention...unlocking the fridge becomes more of a hassle. I was hoping there was a latch we could install on the freezer door to counteract the air pressure coming into the freezer.
  • Anonymous Nov 08, 2008
    I have the same problem, will replacing the rubber around the door help at all?
Water is collecting on the bottom of the freezer and freezes then it becomes so much it starts to leak out side the freezer door. get about 1/4" thick. Is there a leak some where? Take about 2 days to form.
Posted on Jun 18, 2009
    Novelist:
  • 159 Answers
Thats a common problem on refrigerators today. Its due to if you can belive this there very well insulated even though they are lighter and thinner them older units. the reason the freezer door pops open is because when you close the frigde door the air pressure has to go somewhere. so it go's through the air ducts into the freezr and the door pops open. Yhe best way to stop it is to not shut the door to hard follow it through with your hand on it and maybe put your other hand on the freezer dor to make sure it says closed. I have never seen a kit to solve that problem.
Posted on Aug 05, 2007
    Problem Solver:
  • 4 Answers
We have the same problem with our top Freezer door. The only solution I could come up with is using one of the safety 1st child products. It is a little bit of an eye sore since our appliances are black, and their product is white. But it works. Especially having a three years old, it helps from her not getting into the ice cream. But it has helped a lot. Here is a link to what I am talking about.
http://www.safety1st.com/product/detail.asp?ID=205
Posted on Nov 08, 2007
SOURCE:
When I close my side x side frig the freezer door pops open
This happens because the refrigerators of today are air tight, the fresh food door pushes the air into the cabinet as it closes and the air has no place to go but up the air vent into the freezer and "pops" open the freezer door. First thing is make sure the freezer door is capable of closing properly and is not rubbing or catching anywhere. I sometimes add a washer or 2 to the center hinge under the freezer door so it doesn't rub anything. Put a little Vaseline ( or food grade silicone lubricant ) on the hinge side of the seal. I then raise the front of the refrigerator so that the front of the refrigerator is a little higher than the back of the refrigerator. Never level a fridge with a level. Once you have the door closing properly and front slightly higher than the back...let the fresh food door close from 90 degrees on it's own and the freezer door may "pop" open a little but will close again on it's own...and stay closed once all is set up properly. We see this more often now and have no trouble with the door staying open again after setting up the refrigerator properly.
Oct 17, 2012 | Kenmore Side by Side Refrigerator
My Maytag Plus refrigerator does not work, lack of frost, cold. The freezer side is working fine.
Need to see if the damper is open inside the fridge.  This the vent in to top left hand corner.  If it is not open then the damper needs to be replaced.  If it is open then one of the return vents (lower part of fridge) is blocked/plugged.  Let me know what you find.
Oct 21, 2007 | Maytag MSD2756G Side by Side Refrigerator
On my Maytag side by side, stainless steel fridge, Model #: MSD2651KES. The freezer works perfectly, but the fridge will not get cold, but if you open the freezer it will start sending cold air to the...
Its defrost problem.--------- When you open the freezer door, then ice starts getting defrosted, because outside temperature is warm and due to that inside ice gets bit melted.--------- -------------- The working procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. ----------- The damper is operated by a motor.Its a complete damper assembly with motor included in it.--The damper has door.Which closes and open with the help of motor.In your case the damper door is blocked by ice, because your refrigerator is not defrosting.But when you open the freezer door, the inside ice gets bit warm and it starts melting and this lets the fridge section get cool.------------------- In this case you will have to manually defrost the ice and inspect, if the problem solves.For manual defrost procedure, click the link below:-------- Click this below for more detail:--- http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html ----------- This will help.Thanks.Helpmech.
Aug 11, 2011 | Maytag MSD2657H Side by Side Refrigerator
Freezer runs constantly, refrigerator not cold freezer ices up, does not defrost
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 03, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
I have a Maytag Plus side by side Refrigerator MSD2756GEQ. Every couple of days there is a puddle of water on the floor on the freezer side door. What can I do to fix this problem?
ck the bottom of freezer and if ice is there . the drain is pluged and water is running out the door on floor . every 8 hr of compressor run time the unit will defrost and water on froor .
Aug 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag Side by side MSD2356AEW unit. Everything was OK for years till the maid cleaned it. Afterwards we noticed water under the bottom drawer on the refrigerator side. Slowly in the course of 2...
Do a manual defrost overnight by unplugging and leaving the doors open the opening should not be frozen. Alot of humidity or constantly opening the door sometimes causes the frostup.
Mar 13, 2010 | Maytag MSD2651 HE Side by Side...
I have a Maytag refig. that is freezing
Sounds just like a defrost condensate drain blockage. Every time the refrigerator defrost if the water does not go to the drip pan below the refrigerator all moisture remains inside freezer and refrigerator. That also could be what some models have is called an auto damper between freezer and fresh food compartments. If moisture freezes there because the defrost condensate drain is blocked it will keep the damper open and fresh food section will not be able to regulate a constant safe temperature of 38 degrees F. Send me your model number and look into back and bottom of freezer. If water seems to be flowing from that area you will need to unplug, remove contents and rear panel of the freezer to get to the defrost pan. Melt the ice and lets try to force a little warm water through the opening with a little Clorox to kill any slime that may be blocking the opening. On some models there is a heater below pan to prevent this. I will just need your model to confirm' I'm really sorry you are having to pay someone that should know things like this, Thanks, Sea Breeze
Jan 11, 2010 | Maytag Refrigerators
My freezer door pops open when i shut the fridge door
make sure the fridge is tilted back a little so doors close with a little push by raising the front legs,also put some weight on the door, fill a bottle with water or any kind of heavy thing you want,this will hold the freezer door in place when you shut the fridge door
Dec 05, 2009 | Refrigerators
Maytag MSD2756G Side by Side Refrigerator Logo
2,514 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Marvin
Marvin
Carlos Alvarez
Level 1 Expert
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
