Question about Tally T2250 Matrix Printer
Harware Alarm on a tally t2045
We have an hardware alarm on a tally t2045.
Number is like : T113Z?00 -004049
Thanks
Alain
  • jigo1901 Mar 31, 2009
    hardware alarm erron in tally 2280
  • 84 Answers
SOURCE: Tally 2250 Matrix printer
try to replace the ribbon or check if its properly inserted.
Posted on Jul 21, 2008
  • 114 Answers
SOURCE: Tally t2155 - Showing "Hardware alarm wrong board"
change the logic board. your problem will solve.
Posted on Jan 31, 2009
  • 114 Answers
SOURCE: Tally sprint pro
Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
SOURCE: tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
Posted on May 25, 2009
  • 169 Answers
SOURCE: tally t2265 'check ribbon' hardware alarm...
The check ribbon message on the 2265 indicates the printer is detecting problems with moving the print head. You have ruled out the ribbon as being the cause of the problem by using ribbons from another printer.
Befor suspecting other components check the pritner model, if the printer is a 2265+ check to ensure the correct ribbon is used. Note the ribbon for the 2265+ is different to the 2265 ribbon. The 2265+ has a ribbon sensor to detect the ribbon moving. If the printer is a 2265+ the part number for the ribon should be 062471.
If the correct ribbon is used the problem could be the timming strip which could be dirty or warn. Try cleaning this and check for damage.
The problem can also be caused by a dirty or lubricated carriage shaft, the carriage shaft should be clean and dry running - Keep clean of any type of lubricant.
The problem can also be cused by the timing station on the carraige, the carriage motor.
Posted on Aug 24, 2009
Testimonial: "Really good advice, checking those ribbon part numbers can save a lot of wasted time stripping the printer down! Not a very nice machine to work on! m"
Hardware Alarm Wrong Board tally 2280
Hi Denis,you are having wrong board tally because you fixed the wrong part.pls check the part number and get a new one and fix it back.
Apr 11, 2014 | Tally Matrix T2280 Printer
My printer is showing error as "hardware alarm +1308 +131 --- 000004+0381+1317" wat could be the problem
The hardware error indicated on your printer is indicating that the printer is encountering problems when moving the print head.
This error can be indicated if there is any thing which may be preventing print head movement, things you can check include;
The printer ribbon is not jammed and is located correctly in the printer,
You can also check to ensure there is no paper jam of loose paper which may prevent print head movement,
You can also check the carriage shaft to ensure it is free from paper dust or any other obstructions.
With the printer powered off, the print head should slide freely across the width of the printer, you can then see if there is any obstruction to the printhead
Nov 18, 2011 | Tally Matrix T2280 Printer
TALLY GENICOM 2280+ HARWARE ALARM CODE +0016 +131
Unfortunatly not enough of the Hardware Alarm Task Number is included in the description to identify the most likely cause of the problem but some things you can check are;
  • Remove the ribbon from the printer, ensure this is not jammed or damaged
  • Power the printer OFF and try manually sliding the print head from side to side, look out for any objects which may obstruct the movement of the print head (pen lids etc!)
  • Ensure the print head gap is not set to close to the paper, thus jamming the print head
  • Remove the paper to ensure the paper is not restricting print head movement.
  • Clean the Optical Timing Strip that runs under the print head, ensure this is not damaged also.
  • Clean the carriage shaft, this should be FREE from any lubricants WD40 etc and dry running. Remove build up of paper dust etc.
  • Dec 06, 2010 | TallyGenicom 2280 Matrix Printer
    T2250 giving error in harware alarm code +0000ne-w81 000 000000002 - 4032
    Check whether AGA Gear working Proper or not OR giving noise after power on printer
    If AGA Gear not working proper insert the steel rod in AGA gear properly
    Oct 27, 2010 | Tally T2250 Matrix Printer
    TALLY 2250 HARDWARE ALARM WITH 000000128 305
    you req to diagnose the initializing of tally 2250 printer. most of case initializing problem occured, aga gears coming out is the main problem
    Oct 08, 2010 | Tally T2250 Matrix Printer
    Tally T2250 showing an error..
    when power on the printer the printer coming leftside and showing hardware alarm
    check ribbon
    +0306ne -007 000
    000000128 +0304
    error in display. how to rectifie the problem
    Jan 29, 2009 | Tally T2250 Matrix Printer
    Tally printer hardware alarm home postion
    Dec 07, 2008 | Tally T2250 Matrix Printer
    Tally sprint pro
    Aug 26, 2008 | Tally Matrix T2280 Printer
    Tally T2250 Matrix Printer Logo
    154 people viewed this question
    Top Tally Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Tony
    Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
