Question about Ford 8N Tractor
Smoke coming from oil fill cap and vent
White smoke coming from oil fill cap and vent on top of motor. white smoke
shaggyrat
  • 1224 Answers
SOURCE: white smoke
oxygen sensor
oil leak at back of block thats spirting on hot engine block
bad oil rings in block
valves bad
head or head gasket worn and cracked check the oil if chocolate brown then this would be it
a/c preasure line busted or a/c locked up
water line busted on hot engine or small water leak
bad emmission components
these are the things i can think of off the top of my that could give this reaction in vehicle since im not there in person to see vehicle this will have to be what i think
Posted on Jun 16, 2008
SOURCE: i have a 1993 ford f-150 4.9l milky white residue under oil cap
I have seen that with my truck too. It happens when you mainly drive short distances. The oil does not stay hot long enough to evaporate all the water.
Posted on Dec 19, 2008
Louie_3006
  • 79 Answers
SOURCE: 1995 ford f350 diesel white smoke or steam coming from oil cap?
Diesel Shop was correct may be blowby or may be to much pressure on your combustion chamber and it could be a head gasket going. I would do a compression check just to be safe. It's simple the cooling system check fits onto where your radiator cap goes and refer to a technical manual on your max pressure on your cooling system. I would do this just to be better off safe than sorry you know.
Posted on May 17, 2009
  • 142 Answers
SOURCE: WHITE EXAUST SMOKE WATER VAPORE COMING THROUGH AIR
Well, this definitely sounds like you have a blown head gasket, and maybe a busted heater core (water vapor out of air vents). Both were probably caused by the car overheating creating a lot of pressure in the cooling system and blowing the head gasket(s) and maybe the heater core. The vapor out of the vents could also be caused by external coolant leakage of the head gasket on the hot engine bringing the vapor inside the cab via the heater fan...
I'd get that checked before any major engine damage happens...
Posted on Sep 09, 2009
SOURCE: oil cap does not tighten,
dont know where the oil cap is on a 84 ford ranger
Posted on Jan 29, 2011
I put oil in the motor and it starts smoking from the muffler it's white smoke
white smoke is steam
blue smoke is oil
black smoke is rich mixture
suspect failed head gasket, so check your oil for water droplets and a white mayonnaise-like deposit on the inside of the filler cap.
May 06, 2016 | Cars & Trucks
Excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Blowing white smoke
If you have overheated your car recently, then you possibly have a blown head gasket. Take off your oil fill cap (with engine off) and inspect to see if there is a milky substance underneath the cap. If so, bad news- head gasket. You can also check the oil dipstick for the same substance to verify bad head gasket, but usually it has to be pretty bad (gasket) or driven for a while before exhibiting any signs. The oil fill cap is a pretty good indicator. With the car cool, you can open the radiator cap and look and smell for anything other than coolant (fuel smell or oil slick). If so, probable head gasket.
Oct 24, 2015 | 2003 Nissan Sentra
Why does oil come out my vent hose.
First of all fill it to the top. Mileage doesn't matter on motorcycles. They sit for long periods without being run. Seals dry out and crack.
Jul 19, 2015 | Cars & Trucks
2004dodge stratus blows just cold air and it makes like a bubbling sound when car is turned off and smoke comes from hood like its over heating
open the hood and visually see where the smoke it coming from ,, if its the radiator ,, or its over flowing, check the thermostat it could be stuck, if its from the front of the motor, check the belt to make sure its not bad. look at the oil fill cap,, did it get replaced correctly? that would cause oil to spray all over the motor and cause a burning smell and cause smoke . the cold air issue can be checked by checking the thermostat , make sure the antifreeze is filled in the vehicle,, and if your vehicle has one,, check the flapper that changes the air flow from the vents to the correct location
Sep 23, 2011 | 2004 Dodge Stratus
Alot of white smoke coming out of exhaust
If you are also losing coolant it is likely a blown exhaust gasket. The white smoke is a result of coolant leaking through the exhaust gasket and and being forced out your tailpipe. You can check to see if the head gasket is blown by removing your oil fill cap and checking the oil for a milky brown color. I hope this was helpful.
Mar 16, 2010 | 1997 Mercury Cougar XR7
Smoking caddy van 1.9 tdi
turbo might of started to **** oil pull off the air hoe to the turbo and see if it is full of oil that will give oyu a place to start looking
Sep 29, 2009 | 2004 Volkswagen Eurovan
Trying to diagnose an internal engine smoke problem, 06 prius was working fine, all of a asudden i hear the gas engine come on and it sounds like valve or rocker noise, very lightly, i go to check the oil...
White smoke coming out of the oil fill cap is not good, it means there's water in there (white smoke = water, blue smoke = oil, black smoke = lots of junk in gas or ruined engine). I suspect bad head gasket or cracked block.
Jun 14, 2009 | 2006 Toyota Prius
Car is blowing white smoke from exhaust when i step on gas
The most likely cause is a blown head gasket,but it could also be a warped head,was the motor overheated prior to the problem starting? The white smoke is steam,check the underside of the oil fill cap and dipstick for a grayish brown residue,check the coolant for a low level and oil conatamination,either of these conditions verify that a head isn't fully sealed.Unless your moderately skilled mechanically this a job to be done by a shop.A good shop will perform a leakdown test to verify this.
Jun 01, 2009 | 2000 Chrysler Concorde
Ford 8N Tractor Logo
47 people viewed this question
Top Ford Toys Experts
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
