Avery precision cutter 880n plastic bar - Office Equipment & Supplies
Where can i buy 2 29" avery barstool dark brown espresso
We are produce modern metal bar stool in china. If you need, please feel free to write email at mobi@herofurniture.net for further information, thank you.
Oct 15, 2013 | Target Home Barstool: 29" Avery Bar Stool...
MY CHAIN SAW SEEMS TO BE CUTTING ON AN ANGLE BUT THE BAR IS STRAIGHT, ANY ADVICE OF WHAT CAN BE CAUSING THIS PROBLEM
If the bar is straight, and the rails of the bar are equal both sides, then it is due to the cutters being longer on one side of the chain than the other, when you sharpen a chain it is important to do the same amount of file strokes on each cutter, this helps to keep all the cutters the same lenght. Measure the cutters and file the longer side down to match.
Sep 13, 2011 | Garden
I think a virus corrupted the driver for my tdk 880n burner any way to reinstall
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Dec 30, 2010 | TDK AID+880N Black (AID+880N BK)...
Problem with shaver
are you talking about springs under the center cutter bar between the foils? If so, you will need a new foil and cutter set. It is available at shaveroutlet.com with link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
Or maybe you refer to a spring that goes to one of the clips that hold the foil assembly to the pivoting swivel frame. If so, you will need the part linked below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
Jan 14, 2010 | Braun 360° Complete 8985 Electric Shaver
Can not find parts
www.discountonlineparts.com
Apr 18, 2009 | Homelite 'Yard Broom' Leaf Blower
Where do I get a gear to turn the shredder
Her
Date: Thu, 9 Jul 2009 11:16:33 -0400
Subject: TS4500 from Winsource Ind.
To:
Rick,
This TS4500 shredder had been discontinued for more than 5 years. The factory did not make any spare parts for this model.
Thanks,
Victor
Customer service
e is my response
Mar 22, 2009 | Tech Solution TS-4500 Shredder
Motor runs both forward and reverse, but cutters don't turn
How about a hidden 7th screw? If you look at the sticker on the underside where the bar code is you may see a dimple like there is a hollow space under it. If you can't see it, rub your finger over it to find the hole. Just stick your phillips screw driver through the sticker to get access to this last screw. As for the motor working both directions but the cutter doesn't turn it is most likely a broken nylon cog on the drive gears within the white plastic housing at the end of the shredder. There are 3 or 4 gears - all nylon (plastic), my unit had one tooth completely broken off and the one next to it was worn. I am looking into finding parts but I'm not having any luck so far with local service centres. I have a call into the fellowes main 1-800 number to see if they can help. On reviews I have seen this is a common problem. One reviewer was told they use nylon to reduce noise, but of course it isn't going to last long, especially if you ever jam. Nice metal cutters but the weak link is the drive gears that you can't see.
Oct 16, 2006 | Fellowes P600C-2 Shredder
54 people viewed this question
jasbo
jasbo
