Question about Motorola Cell Phones
No service inside house
I have no service inside my house, but have service outside the house
    Brigadier General:
  • 3,614 Answers
ABout the signal of your cellfone, this can be a weak signal from the network or the location inside your houise wasa death spot, cause of thick wall and roofing.
you may need a Motorola 270c MINI Magnet Mount Cell Phone Antenna Booster.
Posted on Mar 12, 2009
Air con has water dripping out the front
Does the fan work to evaporate the moisture? ACs are pretty easy to diagbose. Is it dripping in the house?
Mar 26, 2016 | Heating & Cooling
I need the telephone line fixed,you did not reply
If you live in the US, the telephone lines outside the house are the responsibility of the telephone company to repair/replace. You must be certain that it is the outside lines, though. If they come and find that the problem was not theirs, they can charge a service fee, even if you refuse to have them come inside and repair the problem.
Jan 12, 2012 | Lands Phones
We purchased a digital thermostat to replace our old existing one. It seemed very easy to install and according to the manual and with further online instruction we had all the wires in the correct place....
are you talking about a 'split system' here - as in a house - where you have an inside unit and an outside unit?
If so - when you say you had the 'breaker' off - are you talking about the breaker to the 'outside' unit or the breaker to the 'inside' unit?
Note: on split systems you have a breaker that controls the outside unit and you have a breaker that controls the inside unit.
Typically - the outside unit has a breaker box/fuse box outside with the unit although you will also have a breaker in the main breaker box too, which is usually located in the garage or house somewhere.
The inside unit (usually located in the garage or house somewhere) will not have a breaker box/fuse box, (will merely be plugged in to the wall) but will have a breaker - also - in the main breaker box.
The importance of these questions is because it's possible you 'shorted' your transformer (located in the inside unit) when you changed the thermostat. Although if you had the inside breaker off while you were changing it (thermostat) - I don't see how you could of did this.
In any event - do you remember seeing a spark when you were changing out the thermostat?
If so, then I'm betting you shorted out the transformer.
If that's the case - I would recommend calling a Service Tech - because changing a transformer and 'clearing the short' is sometimes a complicated process - and unless you are fairly adept mechanically and electrically - I would advise getting a professional to do this.
In any event - he/she should be able to solve your problem for only a nominal service call.
good luck!
Jun 28, 2010 | Heating & Cooling
Water leaks in the house from under the unit.There is a drain pipe that leads to the outside but we dont know if that pipe gets clogged or needs service.
Open up the inside unit pannel where the drain pipe is and you'll see a drain pan where the condensation water runs out to the drain , clean the drain pan and the hole and then with air pressure from an air compressor blow the drain from inside to outside and go outside the house where the drain discharged and you'll see the clogh that came out from the drain . To keep the drain clean , pour a cup of bleach or clorox every 3 or 4 months through the drain and in the drain pan.
Oct 16, 2009 | Goodman Heating & Cooling
The AC is on and it says it is 86 in the house and cold air is kinda blowing but it is HOT in the house.
Check outside unit to see if running if not check breakers and see if there is float switch inside the air handler inside. There is only so much you can do. Calla service tech for free estimate. Russ
Aug 15, 2009 | Heating & Cooling
House HVAC Not Blowing
If the outside unit is running and the inside unit is not, probably a problem with the fan motor itself or its capacitor. If you have to have someone repair or replace the fan $200-$250 with parts, a capacitor for a service call and part $100 or so. Check it yourself first to see if there is anything obvious broken wire, hot connection, etc if you feel safe doing that. Turn the power off first. There is also a chance the thermostat could be the problem. Have you tried running the fan on the thermostat "fan on" setting?
Jul 01, 2009 | Goodman Heating & Cooling
TV & Radio in two different rooms
dual source button, and switch them around to your choice of in/out sounds
May 21, 2009 | Bose Lifestyle 48 System
My hotpoint tumble dryer is taking an extremely long time to dry my clothes I have no man in the house and with 3 teenagers to wash and dry for this situation is extremely frustrating!
Look behind the dryer for a kinked or crushed vent. This is the main cause for long dry times. If the dryer is on an outside wall in the house, go outside to check the vent hood for blockage. Check inside the vent hood for a wasp or bee nest before reaching inside to remove the lint that may be keeping the flapper from opening fully.
If this does not solve the problem, refer to a qualified service technician to diagnose for internal problems.
Apr 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Fan not turning outside
Is the outside compressor running? Check the fuses in the outside disconnect by the outside condensing unit. Also check the breaker for the A/C in the main power panel.
Jul 06, 2008 | Heating & Cooling
Phones Dead but DSL OK
A short inside the house should also disable the DSL service, but you can rule out this possibility by disconnecting the inside wiring from the outside wiring at the entrance box. If you still can't get a dial tone when you clip onto the incoming wires, then you need to contact your local phone company to have them find the problem and restore your phone service.
Good luck...and I hope this is helpfull!!
Jan 26, 2008 | Lands Phones
Cell Phones Logo
121 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
