Question about Toshiba Satellite Pro 4600 Notebook
How do you clear the hdd?
My toshiba has a fatal error and will not boot up. I want to clear the
HDD so I can reload the software.
  • 77 Answers
If it is physical damage on the hdd it will not help to clear it, but if it isn't a physical damage i would recommend you using GParted Live CD to delete hdd partitions..
Download link:
You can try and download it, burn it to a cd and leave the cd in the computer and restart (You can use the program ImgBurn to burn it as a image):
How to burn downloaded it with ImgBurn:
1. Load ImgBurn.
2. Switch to 'Write' mode.
3. Insert Disc in Burner.
4. Select Image to burn.
5. Click 'Write' button.
6. Restart computer with cd in it..
You may have to the change the boot order in the BIOS setup if the cd doesn't start..
A guide to change the boot order:
PS: Please rate this solution
Posted on Mar 12, 2009
  • 2,692 Answers
Download hard driver software test then reformatt the hard driver.
An Example is; Seagates, Seatools. May be found at
An error occurs by checking the Control Table of "Image storage area" when the machine is "ON"
I would try the following, under service mode goto:
Set Chk-Type to 1
Execute HD-Clear
Set Chk-Type to 2
Execute HD-Clear
Power the copier off then on again.
Also make sure you are running system software v31.04 or later.
Jan 20, 2015 | Canon imageRUNNER 6000 Copier
Enter service mode to clear f109 error
you do software upgrade .same problem you do mother bod Chang after chang HDD after HDD cabol
Sep 25, 2014 | Toshiba E-Studio 2040c Copier
Can i change the Harddisk with another Harddisk if the error does not clear?
No, you would need to replace the HDD and reload the firmware which is only available through a Toshiba dealer.
Sep 13, 2012 | Toshiba E-Studio 3511 Color Copier
Toshiba Tecra M1 HDD failure
no you just put new hdd and run recovery
Dec 15, 2009 | Toshiba Tecra M1 PC Laptops
Toshiba NB 100 fatal screen
this is a case of os corruption somehow..!!..may b a virus/trojan or hardware or software is responsible..
all u need is the os boot cd anyway..
reinstall os..
(totake data backups u gotta connect the hdd to another pc/laptop, for suchcases a hdd-case is available in the local spare market, it'll makebehave ur hdd to act as an external removable drive)..
this canalso b a symptom of faulty/defective of RAM..pen clean/remove carbon& or oxide formed on the teeth with an eraser n resit it..[it'll bmore prominent, that if itz cause by ram or not,..if during normaloperation, a Blue Screen appears/Memory Dump]
though, sometimes itz also caused by the m/b..
see if ur hdd is making any humming/ticking noise (like 'tuc tuc' or 'kirr kirr')..if so it is likely to be replaced..
if once u can login, do the following:
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..
download n run Startup Control Panel..'remove all theunnecessary startup items from here..(if u can't find what toremove,post me/us in ur comment with all the items listed in each nevery tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..
disable thefollowing: a) 'Automatically Restart' right click onmy computer->properties->advanced->startup nrecovery->(uncheck on the) Automatically Restart; b)'ErrorReporting' right click onmy computer->properties->advanced->errorreporting->disable error reporting->(uncheck on the) 'but notify mewhen critical error occur'..
Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
always better to seek professional advice of ur system admin/vendor....
Nov 10, 2009 | Computers & Internet
Just replaced the HDD in my Toshiba Satellite M55-S329 from a 100GB to a 320GB after the old HDD failed. Now after replacing the HDD, it does recognize the hDD but I get the error message "pxe-e61 media...
You have to change to boot order in the bios settings, it is currently trying to boot from a network drive, it needs to be set to the HDD you just installed.
Jul 27, 2009 | Toshiba Satellite M55-S329 Notebook
Usually the HDD is set on IDE #0.
The PXE error appears if the notebook tries to boot up from the LAN but the cable is not connected or there is no possibility for LAN booting.
In my opinion there is something wrong with the HDD or the BIOS cannot recognize the HDD correctly. I would recommend checking the HDD pins. Furthermore you should change the booting order in the BIOS.
Apr 24, 2009 | Toshiba Satellite A100-S8111TD Notebook
Toshiba satellite is having issues
First thing to do is stop booting up the computer. This message means the Hard Disk Drive (HDD or "C Drive") has errors. Errors can mean disk corruption including bad sectors and/or physically damaged hardware inside the disk drive.
Since you are able to log into the computer, if even briefly, perhaps the HDD is what I like to call "fail-ING"; there may be hope of retrieving some of your data (pictures, etc). Ask your local Geek Squad Agent help you - if damage is severe, this is not necessarily something you can fix yourself (e.g. "fail-ED" HDD).
Remember, I said not to keep booting the computer - the more times you boot a "fail-ING" drive the less likely you will retrieve anything. If you insist, however, on a DIY method - you could learn more about the following:
1. New HDD installed
2. HDD Enclosure (USB)
3. Acronis Software
4. A nice drink and a couple of hours to clone the old HDD
OR 1. Geek Squad Agent
2. Credit Card/Checkbook
HINT: if you talk to a Geek Squad Agent and s/he can't explain Acronis software, find an Agent who can...
May 20, 2008 | Toshiba Satelite 5205-S505 Notebook
Toshiba A60 Not Booting
You might want to run a harddrive diagnostic test. You can find bootable iso's on the harddrive manufacturers website.
May 11, 2008 | Toshiba Satellite A60 Notebook
Toshiba Satellite Pro 4600 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
