Question about Mtd 22" Yard Machine Push Mower
Oil change on murray 22 inch 4.5hp - Mtd 22" Yard Machine Push Mower
3 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: what does a 22
On the bottom of the motor there is a rectangular plug that will either have a raised or recessed SQUARE head that you could use one end of a 3/8 inch socket extension to remove it with.
Posted on Apr 11, 2010
#1 Taper
  • 1040 Answers
SOURCE: What type of oil do
SAE 30
Posted on Sep 25, 2010
I have a riding Murray Select 42 inch cut mower
My book says 10W30 and takes about 1 quart. Check the oil when you get almost a quart and do not over fill.
Sep 23, 2014 | Garden
Murray select hp
Mathieu. It sound like you have overfilled it with oil. Drain most of it out the leave it level. A lawnmower will run better with it not being overfilled. Clean the spark plug and heat it gently to completely remove traces of oil. John
Jul 02, 2013 | Garden
Need owners manual for murray 22 inch push mower model #22526X92A
There is no corresponding manual for model no. But here is the manufacturers site, you may be able to use a different manual.
http://www.murray.com/la/en/support/manuals/
May 19, 2012 | Oregon Scientific Gator Mulcher 3-N-1...
Where is oil plug to change oil, how much and what kind. It is a 6.25 hp 22 inch self propelled Murray Select Quantum.
They do not have a drain plug. You need to remove the dipstick and tip the mower dipstick side down while putting a container under it. After it has drained right mower and refill to full mark on dipstick with sae 30 engine oil. It will take approximately 600 mls. Regards Phil
Apr 17, 2011 | Garden
I have a 22" murray lawn mower 3.75. Can you give me the ratio of oil/gqas mixture to use ? Please advise on best type and grade of oil to use.
my 22" murry has a four cycle engine. and you dont mix gas and oil for a four cycle engine. put gas in the gas tank and oil in the crank case.
Oct 16, 2010 | Garden
What type oil and what level should I put in my 6-7yr old Murrary riding garden tractor. Model=?, but 25 HP, 2cyl 52 inch deck.
You didn't specify what engine is on your Murray, but most of them were either Briggs & Stratton or Tecumseh. Both of these engine take SAE HD30 weight motor oil. Appoximately 48 ounces will fill these from a complete drain.
If your Murray has an imported engine (honda or kawasaki) then they would use 10W30 oil.
Aug 30, 2010 | Garden
I have a Murray 6.0 hp 20 inch push lawn mower. How much oil do I put in when changing oil.
If there is a dip stick add some oil check the level till you get to the full mark. It should take a little more than a quart. If there is no dip stick then there is an oil fill plug down low on the engine. Fill slowly until the oil reaches the threads in the engine housing (almost overflowing). Be sure to replace the plug or you will have oil everywhere when you start it.
Don't just dump the oil in, check the level as you go!
May 20, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
What does a 22" murray 4.5 lawn mower oil plug look like
Apr 08, 2010 | Mtd 22" Yard Machine Push Mower
I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
Mar 27, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
170 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
