Question about Hotpoint Washing Machines
Hotpoint HVF344 not pumping out after wash cycle
Not pumping water out after wash cycle finishes
  • 10 Answers
SOURCE: wf340 hotpoint washer
it will be to do with the pressure switch it may be faulty, but more often than not there is a blockage in the pressure chamber which is located at the bottom of the outer drum, check the chamber and the tube that goes up to the pressure switch to see if they are blocked if they are clear of obstruction then test the pressure switch,to do this unclip the pressure switch from the side of the machine but dont take the wires off once off pull the tube off that goes down to the pressure chamber once off blow in to the nossle on the pressure switch, you should hear it click and then when you release it should click again, if it doet click twice then that is your problem, hope that helps.
Posted on Feb 22, 2008
  • 1028 Answers
SOURCE: washing machine
bottom right corner behind the little door
Posted on Sep 27, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
SOURCE: Hotpoint WT540 1400 spin. Flashing Rinse hold and Mini load LED
Had exactly the same last week - Jan 09 - and had to call out Hotpoint engineer - £99.98 all inclusive of parts - it was the main controller board, so thats under guarantee for another 12 months. all working and spinning as should be and only took around 30mins.GS :)
Posted on Jan 22, 2009
  • 118 Answers
SOURCE: Fabric Softner Tray
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Posted on Sep 02, 2009
My hotpoint hvf344 washing machine is only doing so much of a wash then stops and flashes f-01. took the back off whilst on cycle and sounds like its sparking
Please observe with a good observation lamp to see the point of spark, if this is from the motor or from any loose joints or connectors. This could lead you to the fault.
Remove the mains power and attempt any work on the line. Clean and replace any damaged plugs or connectors or motor/ motor capacitor or power board.
Sep 11, 2012 | Washing Machines
My machine will not finish a cycle and just stays filled with water.
It sounds as though you either have a clog in the drainage system of the machine, or a bad drain pump.
May 06, 2012 | Hotpoint Washing Machines
Hotpoint washing machine HVF344 error code F-05 not draining
Sounds like you have debris in your drain pump., You will be surprised at all the things you find in your pump.
http://www.on-timeappliance.com/washingmachinerepair.html
Mar 28, 2012 | Washing Machines
Hotpoint hvf44 flashing f05 and not finishing cycle or emptying of water fully
f-05 relates to blocked pump.
remove the front kick strip and on RHS u will notice the filter.
if u can tilt the machine backwards and place a basin under the filter. also have a towel ready.
remove the filter and clean out. also make sure the pump head is turning freely
Jul 06, 2011 | Hotpoint Washing Machines
Hotpoint Aquarius wms38 1200spin Machine fills with water after wash cycle is finished and it is turned off
If the water is coming in after cycle has finished, then it is 1 of 2 possibilities.
1- A faulty inlet valve, replace it.
2-Water is syphoning back from the sink if it is connected to the sink waste outlet pipe, raise washer outlet hose higher up to solve problem
Nov 30, 2010 | Hotpoint Washing Machines
How do i fix my washing machine interlock hotpoint hvf 344
The door should have a pin on it that pushes and closes the interlock switch. Check to see that the switch is inadjust ment to trip by turning off the water door open and with a plastic rod or a pencil push thru' the hole in the chasis where the door pin goes through and start the machine. If it starts quickly pull out the pencil, unplug the machine and adjust the switch. Plug it back in. It may continue on with the cycle you just started if not better! If not close the door aand start a short cold wash cycle. If it sounds like it wants to start, turn on the water and let it run thru' the complete cycle.
Jun 29, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Machine full of water and towels. Spinning at same rate then stop
Check pump filter located at rear of washer, remove rear cover, locate and remove large black hose, remove and clean filter.
Please rate my solution.
Thanks.
Jul 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Can I activate guarantee for a hotpoint washing machine
The normal procedure to activate your guarantee, is to post the registration card that came with the washer, to Hotpoint u/k.
If you have no card, then ring the Hotpoint help
line number, and they should be able to assist you.
Pleas leave a fixya rating for my solution.
Thankyou.
Feb 12, 2009 | Select Brands Washing Machines
Hotpoint wd44d wash/dryer wont finish a wash nor wont pump out
there may be something stuck in the pump itself. hairgrips and brawires are a common find.
Jan 19, 2009 | Hotpoint Ariston WD440G Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Washing Machines Logo
32 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
