Question about RELIANCE ELECTRIC WATER HEATER
Water from new water heater smells like sulfur & has air pockets
Everytime we turn on the hot water faucet we encounter air pockets. We installed it as instructed by manual. What can be the problem?
  • Farley Redfield
    Farley Redfield May 11, 2010
    Is this a taNKLESS WATER HEATER?
  • Thomas F. Schneider May 11, 2010
    Smells like rotten eggs? The water has a high meneral content that when heated turns  into a gas?
  • 463 Answers
Sounds like there might be a super-hot spot in the water heater and the water is boiling. Can you hear some percolating noises from within the water heater from time to time?
Posted on Mar 12, 2009
Installed a new rheem water heater last night and still no hot water. It has power thermostat set at 130.
Turn off the heater then open the bleeder valve on top of the tank to let the air escape. Once all of the air has been bled off, faucets included then turn your heat back on.
Jun 14, 2017 | Rheem Water Heaters
When a electric water heater smoking and it gits turned off at the breaker box will there be a chemical smell after
No. A water heater is a sealed system it needs to be addressed for the original problem. High sulfur content has been a complaint as far as smell,and I remove the anode and replace with a brass plug because of. Shallow wells in the area largest complaints.
Nov 27, 2014 | State Water Heaters 40 Gallon Select SL...
Egg smell from hot water
You either have water with a high sulfur content or need to flush your heater. you should flush your heater every year anyway. you can turn off the water and electric to the heater. and totally drain the tank when it is totally drained add more water and drain some more. then refill the tank and run a hot water faucet the tub is best to eliminate any air in the system then turn the electric back on this should solve the problem if it does not you probably have sulfur in the water and would need water treatment or filters to help
May 06, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem electric water heater 50 gallon, lukewarm water. Water is warm but not hot, where should we look for problem?
Luke warm water is the result of top element bad and the bottom is the only one heater. The best solution I can reccomend is to change both out due to the fact the bottom element may go bad and since you have to change one you might as well change both.
Turn power and water off, drain heater down and once water is drained out change them out. Once new ones installed turn water on to fill heater and open faucets and get air out on the hot side of each faucet once water is flowing out of each faucet you are now ready to turn power back on.
Oct 12, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Installed a tankless gas hot water heater a few months ago, and ever since then when ever I turn on the hotwater, I get pockets of air coming out of the faucet. There are no leaks in the water lines, but...
1) Never, ever install tankless water heater, unless your wallet is 2" thick and you enjoy nuisance problems and recommended continual maintenance.
2) Add in-line air vent.
http://waterheatertimer.org/images/Air-vent-added-to-return-22.jpg
3) Look for check valve along the line. Look for mixing valve, pressure regulating valve, etc.
4) If you have recirculation system, remove cross-over check valve and see if problem is located there.
5) Contact Rheem. 800-432-8373 They will want model number, serial number, and name of installer. And might recommend contacting installer or plumber.
6) Increase water flow. Check water flow requirement of tankless (.5 gallons per minute activation) with actual flow at faucet.
7) Clean water filter at tankless unit.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
8) Crossover at single-handled faucet.
http://waterheatertimer.org/Crossover.html
9) Fix all leaking faucets indoor and outdoor so no air is being sucked in.
10) Bad TP valve on water heater sucking in air each time water pressure pulls on the valve?
Additional resources: No information about air-in-line
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Sep 20, 2011 | Rheem Paloma PTG-74XP / RTG-74XP Liquid...
We have a one year old home with PEX pipe and one year old hot water heater fed by a water softener. In one of the bathroom sinks, and only there it seems, there is a sulfur smell when we first open the...
i would check the softener before the water heater, when was the last time you did a back flush of the system? water sitting at the bottom of a water softener tank can get moldy and begin to rot, which causes H2S gas which smells like sulfur , its a breakdown of decay,, this will also happen if your home is using well water,, so check that first , empty the tank and clean it our ,, then back flush the system
Jul 03, 2011 | Water Heaters
How do you check the condition of the annode tube in a hot water heater?
You'll have to disconnect the water lines from the top to pull the rod up out from within the tank. If you don't have enough clearance above the tank, you'll have to drain the tank, remove the venting and tilt it or lay it down to remove it. The sacrificial rods usually go bad prematurely on well water systems with hard water and causes a sulfur stench in your water. Here's a quick test to try before you do this: Go to the nearest faucet to the water heater and fill a glass full of cold water and another glass full of hot water and smell them. If the hot water is the only glass that smells like rotten eggs, it's most likely coming from your water heater due to your anode rod. Douglas
Oct 04, 2010 | American Standard 40 G Natural Gas Water...
Hot water does not last long. Model 82vh40-2 mnf. 05/2005
If the lower heating element burns out the upper element will heat the top part of the tank then shutoff. homw depot/lowes etc should carry elements. 1 turn off breaker, remove element access cover (the 2 panels on the front of the heater) test for electricity at the reset button ( uppermost device in upper panel) to make sure power is off. 2 turn off water (I usually turn off the cold water main to stop water cross feeding into hot supply line back into heater) 3 disconnect the 2 wires on the lower element, test with continuity tester. shhould be no continuity between terminals and tank, but around 10 ohms between the 2 terminals. Check the thermostat for continuity if tank is cold thermostat should be closed ie zero ohms across the 2 terminals.
If stat is bad replace stat; disconnect wires push it up out of the spring clip insert new stat reconnect. If element is bad: drain tank. connect garden hose to tank drain valve, open tank drain valve turn water main on to clear rust sediment and get water flowing. Next remove filter screen from a hot water faucet then turn on ( a hot faucet upstairs or higher than tank drain). Now turn water main off, air will now go in through hot faucet and tank will drain, takes about an hour. Use a water heater element wrench about$10 to remove element(s) make sure no bits of rubber gasket are left in element opening- dig em out with a screwdriver if needed. Insert new element with its gasket and tighten. reconnect wires DO NOT TURN ON ELECTRICITY! BE SURE TO FILL WATER HEATER WITH WATER ! Turn water main back on -air will come out of the hot faucet for several minutes. When water runs without any air sputtering, turn off faucet and replace the faucet filter screen. check element(s) for leaks. turn breaker back on.
Feb 17, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
High pitch noise when water is turned on.
that's a faucet problem, nothing to do with the tank
either replace the faucet washer (The one that's noisy)
or get a diffeent style faucet
Aug 31, 2009 | Water Heaters
ATWOOD WATER HEATER
you will need to have a 115 curent for electric, run a line off the panel box, turn off water to the house drain it down, disconnect the lp gas line and cap it off, remove the water heater, install the new heater run the cold side water to the cold side {blue on the heater} the hot side to the red, take the cover plate off on the water heater run the wires, hook up the groung wire then the red and white wires to the wires comming off the panel box,, fill the water heater with water have a open faucet on the hot side, and bleed the air out, DO NOT TURN ON ELECTRIC TILL THE AIR IS OUT OF TANK AND WATER IS FLOWING THRU COMPLETELY, after you get water commming out of the faucet turn it off and turn the electric on to the water heater ,, wait about 30 min, you will have warm after an hour it will be hot and you are done,, good luck write me if you have questions, gary1121@aol.com
Jun 29, 2009 | RTO Atwood Water Heater - 6 Gal LP
RELIANCE ELECTRIC WATER HEATER Logo
579 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
