Question about Maytag Dryers
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
Maytag Electric Dryer model MDE7057AYW (5600 Watts).
Dryer runs ,but no heat . It states 120/240 volts I wired 120v.When hooked up it did appear to work , but not too good, now not at all. How do I remove panels to check inside? Then how do I trouble shoot? Thank you
  • astroarc Mar 13, 2009
    Ok I got this part Now how do I get the covers off.
  • 6 Answers
Most electric dryers run on 110 volts, but heat on 220 volts. Unit needs to be wired to 208 to 240 volt, 30 amp circuit to Run and HEAT properly. Motor, interior light and controls run on 110 volts, neutral (white wire) and one hot wire, usually black. The heater works on both 110 volt hot wires, usually one red and one black wire. Unit can be hooked up to run and heat on 110 volts but will allways take two or three times as long as a 220 volt setup. It is producing half or a little less of its 5600 watt rating. It takes three things to efficiently dry clothes: heat, air flow and tumbling action. Remove any one and the unit runs much less efficiently. If you need a dryer to run on 120 volts, buy one that says 110 - 120 volt operation only, but it will still take up to two hours or so to dry a load. Brent
Posted on Mar 12, 2009
  • Maytag Master
  • 3,361 Answers
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Maytag neptune dryer will run, no heat I think the heating element is out, how do I replace it. Model MD5500
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag dryer model #MDG308Dawn heat not coming out of dryer dryer motor running but clothes are not drying can't feel the heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Maytag Dryers
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
The dryer does'nt heat Model # MDE7057AYW
You most likely have either a broken heating element or a popped safety switch.
Both can be found on either Applianceparts.com or Ebay after you go the Maytag website and spec out your parts.
Feb 09, 2010 | Maytag Dryers
I have a maytag dryer model number is mce8000ay
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag Neptune Dryer not heating
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Mar 07, 2009 | Maytag Neptune MDE4000 Electric Dryer
Dryer runs but no heat. gas dryer (maytag)
check the ignitor. depending on the model can be from $25- $90.00 This is what heats up when you start the dryer. like a pilot light on a water heater, only it doesn't stay on all the time.
Feb 19, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
MAYTAG MDE7057AYW NO HEAT
CAN YOU USE A MULTIMETER? IF SO, OHM THE THERMAL FUSE. IF THIS IS OPEN REPLACE IT.
Jan 28, 2009 | Dryers
Watt for dryer
Total 5500 watts for motor timer and heating element on an electric model. (estimated)
Jan 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
524 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
