Question about Lenox Softworks Inc. Script-Q Basic
Serial number Script-Q - Lenox Softworks Inc. Script-Q Basic
Tip
How to Recover your system from the Cyber Security Virus
It is best to try to remove this virus that pretends to be the Windows Security center before you start the operating system using either an Antivirus OR Antispy boot CD.
I created this SpybotSD BootCD a few months ago unzip and burn to a CD-RW I will post later versions when I have time.
http://rapidshare.com/files/296486827/SpybotBootCD.part1.rar
http://rapidshare.com/files/296511405/SpybotBootCD.part2.rar
http://rapidshare.com/files/296531828/SpybotBootCD.part3.rar
If you have either Norton Ghost v12 or v14 I have created this script that will auto-generate the latest antivirus definitions onto a CD-RW feel free to use it, just boot the Ghost CD first then when you are ready to use the inbuilt scan for virus option within ghost remove the Boot CD and replace the one my script generates.
http://rapidshare.com/files/315809069/getdefs4ghost14_iso_burn.exe
There is Nortons own Antivirus 2009 boot CD available but you will needthe correct version serial number to make it work here is the downloadlink for recovery_nav_x86.iso however with the serial this is useless I suggest my Ghost method as most people have this boot CD or if not should have.!!
on Dec 14, 2009 | Computers & Internet
I want to buy a Cartier lighter but I want to make sure it,s real. How do I look up the serial number?
To look up the steel ligter serial number is very easy ,I specialize in buying and selling Cartier watches. I've seen fakes with all the correct marks and a serial number, but that doesn't mean they are legitimate. If the watch was registered by Cartier when it was sold or if it has been sent in to Cartier for service Cartier will be able to verify it is authentic, but be aware that if the watch was not originally sold in North America or was not registered when sold (fairly common) it can still be authentic. Some sellers offer the Cartier quartz model for sale and only state that the watch has a quartz movement, but fail to mention if it has a Cartier quartz movement. If it has a replacement movement in it the watch is technically authentic, but not original and is not worth as much as one with an original or a genuine Cartier replacement movement. The biggest mistake I've seen amateur Cartier buyers make is using the Cartier micro-script signature on the Roman numeral to verify authenticity. Indeed this is a good indicator, but not the best indicator as there were many Cartier watches produced prior to the technology required to make the micro-script possible and not all Cartier watches have Roman numerals for the dial to have the micro-script signature. Furthermore, the micro-script is not always located at the same place and if the dial has been refinished it may not appear at all. Another common problem is actually caused by language differences, i.e. "all original versus "authentic". A watch can be authentic without being all original. Unless someone has owned the watch since it was new and it has never left their sight it is impossible for them to state the watch is "all original" as a part could have been replaced at some point in time -- even without their knowledge. Your best bet is to buy from a reputable seller even if you have to pay slightly more money. -- Cartier_Specialist
May 08, 2012 | Watches
Connecting problems
Installation
The scripts communicate with the Jandy system through a USB Serial Adaptor (e.g. the Keyspan USA-19HS USB Serial Adapter) connected to the Jandy Aqualink RS Serial Adaptor.
In order to use these scripts with SerialX, you will need to separately download and install SerialX as a Scripting Addition. As currently written, you will also need to determine the exact name of your serial connection and edit the following statement in both scripts:
property SerialConnectionName : "/dev/cu.USA19H47P1.1" -- Replace "dev/cu.USA19H47P1.1" with the name of your USB Serial Adaptor.
After editing, drag the Jandy Aqualink attachment script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Attachments
and the Jandy Aqualink background sync script into the folder: /Library/Application Support/Perceptive Automation/Indigo 4/Scripts/Background Tasks
Initiating use of the background script is typically accomplished by establishing a Trigger Action that activates on Indigo Server restart.
Usage
Assumes a Jandy Aqualink RS-4 or RS-8 Pool/Spa combination with auxiliary 1 set for pool light and auxiliary 2 set for spa light.
Unlike the previous version, the background script will now automatically execute periodically after being initiated (typically with a Trigger Action that activates on Indigo startup), will create variables as needed, and will update the status of those variables. By default the updates occur every 30 sec for most items using a single "#LEDS?" command, and every 30 min for the temperatures, with error detection if something does not update correctly. If the Spa is heating, temperature updates default to every 2 min. Variables created include AirTemp, ErrorFree, NextTempUpdate, PoolHeatEna, PoolHeatOn, PoolLightOn, PoolPumpOn, PoolSetPoint, PoolStateOn, PoolTemp, SpaHeatEna, SpaHeatOn, SpaLightOn, SpaSetPoint, SpaStateOn, SpaTemp.
Nov 22, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
A message keeps showing up when on internet explorer on facebook that says, a script on this page is causing internet exploer to run slowly if it continues your computer may become unresponsive i have...
Try this.
Common script errors messages can be eliminated by Clicking:
1. Open Internet Explorer.
2. On the Tools menu, click Internet Options.
3. In the Internet Options dialog box, click Advanced.
4. Click to select the Disable script debugging check box.
5. Click to clear the Display a notification about every script error check box.
6. Click OK.
There are situations when a Web page contains script that takes an unusually long time to run.
There will be a warning message after a certain number of statements has been processed.
The solution is to increase the default number of statements,before the warning is given
1.Go to Start/Run/type :regedit
Open this key: HKEY_CURRENT_USER\Software\Microsoft\InternetExplorer\Styles
(If the Styles key is not present, create a new key that is called Styles.)
2.Right click anywhere in the right pane and create a new DWORD value called "MaxScriptStatements"
(copy and paste that in to the name box) and set the value to the desired number of script statements.
Try 8,000,000 to start with.
Be careful editing the registry.Back up the key first.
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @
www.thebestpcdoctor.com or via 877-407-9229
Sep 21, 2011 | Microsoft Windows Vista Home Premium...
I have a wireless connection problem. My desktop is connected but my laptop is not. My laptop's signal was lost when my hard drive was repaired. My router model number is WRT54G2 AND THE SERIAL # IS...
Right click on the wireless connection on the LAPTOP. He is the one that needs to provide the correct connection script. Good case for backup, eh? In laptops, I reccomend replacing the harddrive WELL before you have any issues. Year and a half if you count on it. What you do is get the new drive and clone the old drive to it, the new drive will look and feel precicely the same, with no install of anything....Way easier. and cheap, at 100 bucks for new drive.
Sep 20, 2010 | Computers & Internet
Intend to down load symantec anti virus security to my PC having internet connection. Where to get FREE and what software is suitable / recommended Thanks
If you sign up with BT Total Broadband then you will get this free as long as you have this ISP otherwise you will need to but a serial for the retail version, here is a script that will download the latest defintions file and create a new ISO and burn it this can only be installed with a valid serial number which you will hav e to buy.
http://rapidshare.com/files/312529866/NAV2008_UPDATE_DEFS_BURN.rar
If you have Norton Ghost v12 or v14 I have created a script that will download the latest DAT files and create a CD for use with Ghost for pre-boot virus scans.
http://depositfiles.com/files/1mw2gyehi
Jan 06, 2010 | Symantec Norton AntiVirus 2008: Windows
Outlook express script errors
Common script errors messages can be eliminated by Clicking-Control panel - Internet Options - Advanced tab.
Check "Disable script debugging"
Uncheck "Display a notification about every script error"
If no joy then
Microsoft's Scripting download
Get the latest. Two download versions are available for Windows Script 5.6.
The first version requires Windows 2000; the second version requires
Microsoft Windows 98, Millenium Edition (Me), or NT 4.0. Please choose the
download appropriate for your operating system.
http://msdn.microsoft.com/downloads/defa...
=/msdn-files/028/001/175/topic.xml
Also, make sure you should not have Bad HTML bad coding as man people faced the same issue with outlook express.
Thanks for using "Fixya".
Jun 19, 2009 | Microsoft Windows XP Home Edition
Can't install Digi Neo 4 in RH Linux
you may have to delete it and re install it
Feb 27, 2008 | Digi Neo Serial Adapter
Computers & Internet Logo
Top Lenox Softworks Inc. Computers & Internet Experts
David Payne
David Payne
Are you a Lenox Softworks Inc. Computer and Internet Expert? Answer questions, earn points and help others
