Question about L-G Washing Machines
Lg wm2010cw, won't dispense bleach
The washing machine appears to never dispense bleach, on any wash cycle including the cleaning cycle.
  • 489 Answers
SOURCE: Fabric Softener & bleach dispensing
The control board program has many sensors built into the unit to determine when to dispense the bleach and the softener.  LG tech documents doesn't list when these liquids are dispensed so there must be a program that matches the current operation and loads of each wash program.  That's the best answer I can give you at this time.
Posted on Jun 11, 2008
robocop
  • 90 Answers
SOURCE: Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Posted on Jan 19, 2009
SOURCE: Kenmore/Sears 417.43142200 bleach dispenser not dispensing
Before you do anything, make sure that the plastic part in the bleach dispenser container is pushed in. Fill with bleach to the "max" line, written on the plastic part. Start the wash cycle and make sure that water goes into the bleach dispenser. Once water flows into the dispenser, the bleach/water mixture rises and should automatically dispense into the washer. We had this same problem. We removed the dispenser unit and took it to the sink. We then filled it with water and it started coming out from the bottom automatically. So sort of suction is caused from the amount of water and it starts to flow. Basically, you aren't adding enough bleach into the dispenser if the water flows into it as the wash cycle runs.
Posted on Apr 06, 2009
SOURCE: Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Posted on Jun 10, 2009
SOURCE: Bleach Dispenser not relaesing bleach during cycle
I have the same model # and same problem!!!
Worked fine for few months and then it started.
Sears technicians came twice but couldn't fix the problem. Now they have ordered a new dispenser door. Sears said they changed the design. Will see if the new door will work. Hope that helps.
Posted on Sep 02, 2009
I have an Electrolux washer model EWFLS70JSS. The bleach dispenses during the rinse cycle rather the wash cycle. I thank you in adavance for your help.
This is a siphoning problem. Please clean out the dispenser cup(s) as much as you can and try again. You may need to clean the unit and run vinegar through instead of bleach to unclog any small components.
Jul 23, 2012 | Electrolux EWFLS70JSS Washer
The bleach dispenser did not dispense bleach during Tub Clean cycle. The drawers were clean (only have had washer 3 wks)
I just called LG and they said for this model WM2101HW the bleach will only dispense from the soap dispenser during the tub clean cycle
Apr 16, 2010 | LG WM2101HW 4.0 cu.ft. Washer
The inside of my washing machine smells
Regular cleaning maintenance is required to prevent odor build up inside the machine. The LG WM2688HWM has a TUB CLEAN feature, a special cycle for the cleaning of the inside of the washer. This cycle uses a high water level with higher spin speed.
  1. Remove any clothing or items from the washer and close the door.
  2. Open the dispenser drawer and add liquid chlorine bleach ONLY to the bleach compartment.
  3. Close the dispenser drawer slowly to prevent the bleach from spilling.
  4. Turn on the machine then press the EXTRA RINSE button for 3 seconds.
  5. Press the START/PAUSE button to start.
  6. Leave the door open to dry the washer door opening, door seal and door glass after the cycle is complete.
Dec 02, 2009 | LG WM2688HWM TROMM SteamWasher
Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Jul 20, 2009 | Washing Machines
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Apr 26, 2009 | LG Washing Machines
Jan 12, 2009 | LG WM2455 Front Load Washer
Jun 05, 2008 | LG WM2688H Front Load Washer
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
55 people viewed this question
Top L-G Washing Machines Experts
Are you a L-G Washing Machine Expert? Answer questions, earn points and help others
