Question about Cisco ASA 5510 Firewall
ASA 5510 battery - Cisco ASA 5510 Firewall
  • 7 Answers
SOURCE: ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Posted on Jun 24, 2008
YvTech
  • 16 Answers
SOURCE: Activation key
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Step 1
Obtain the serial number for your security appliance by entering the following command:
hostname# show activation-key
Step 2
Access one of the following URLs.
Use the following website if you are a registered user of Cisco.com:
http://www.cisco.com/go/license
Use the following website if you are not a registered user of Cisco.com:
http://www.cisco.com/go/license/public
Step 3
Enter the following information, when prompted:
Product Authorization Key (if you have multiple keys, enter one of the keys first. You have to enter
each key as a separate process.)
The serial number of your security appliance
Your email address
An activation key is automatically generated and sent to the email address that you provide. This key
includes all features you have registered so far for permanent licenses. For VPN Flex licenses, each
license has a separate activation key.
Step 4
If you have additional Product Authorization Keys, repeat Step 3 for each Product Authorization Key.
After you enter all of the Product Authorization Keys, the final activation key provided includes all of
the permanent features you registered
Posted on Feb 12, 2009
SOURCE: installation of cisco asa 5510 firewall
The problem is your version of java, you need to uninstall java 6 update 11 or 12 and install java 6 update 6. you can download this from the archive section at the java web site. I had the same problem but this solved it.
Good luck
pls send me a line if your problem is solve
asowe@lastingsolutions.gm
Posted on Mar 10, 2009
  • 1170 Answers
Have a look at this tutorial :
Straight-forward way to configure Cisco PIX Firewall/ASA
Posted on Mar 23, 2009
  • 8 Answers
SOURCE: Restart Cisco Asa 5510
Yes. The firewall will restart. Just be sure to save your running config to memory before turning off. For that you must issue the command: write memory.
Best Regards,
T
Posted on Apr 23, 2009
How can i get into ASA 5510 after lost password
Its simple, you have reboot with console connect, get into to ROM mode and change configuration registry so it will not load the saved configuration. Please refer Resetting the passwords on Cisco ASA 5510 Binary Royale Ltd for the step by step process
Mar 21, 2013 | Cisco ASA 5510 Firewall
I want toblock web sites on my cisco asa 5510 firewall
I know that iKeyMonitor can also block sites on iPhone/iPad/iPod now.
http://ikeymonitor.com/
Jul 16, 2012 | Cisco ASA 5510 Firewall
I have cisco asa 5510 firewall and i have dialup internet connection i want my asa 5510 between my LAN and my dial up internet
Your best bet is to place the ASA into 'transparent' mode, and letting the traffic pass through it and be inspected on the way through.
To do this you need to first do the following command:
firewall transparent
Once in transparent mode, the firewall will no longer look like a hop in the packets journey, and you can set rules to allow/disallow traffic using access lists on the inside and outside interfaces, plus you can perform packet inspections using policy-map and inspects.
Hope that helps!
Feb 12, 2010 | Cisco ASA 5510 Firewall
Block websites on cisco asa 5510.
All websites or specific ones?
If you want to block all web traffic, a straightforward rule preventing HTTP traffic (TCP port 80) as well as HTTPS (port 443) will block any and all web access.
If you just want to block specific sites, I'd recommend an access control list (ACL) configured to deny traffic to those specific site's IP addresses.
Feb 10, 2010 | Cisco ASA 5510 Firewall
New cisco asa 5510 setup
connect your laptop to the asa5510 using a cross over cable
Oct 07, 2009 | Cisco ASA 5510 Firewall
IPSEC problem between ASA and Microsoft ISA
can you try lower encryption levels on each device and see if that helps? sometimes it is neccesary between Cisco and other devices.
May 18, 2009 | Cisco ASA 5510 Firewall
Best Regards,
T
Apr 18, 2009 | Cisco ASA 5510 Firewall
Installation of cisco asa 5510 firewall
Hello kuniksh,
Look at the below link for all configurations
http://www.akadia.com/services/cisco_router_firewall.html
Do rate this solution!!!!
Mar 21, 2009 | Cisco ASA 5510 Firewall
Open Questions:
See all Cisco ASA 5510 Firewall Questions
Cisco ASA 5510 Firewall Logo
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
