Question about GE Profile WPSR3100W
AGITATOR REMOVAL GE WASH MACHINE, MODEL WPSR3100
UNABLE TO REMOVE THE AGITATOR
  • 408 Answers
If you remove the top cover to the agitator, inside you will see a I believe 9/16" nut.  Remove this to take the agitator off the shaft.
Posted on Mar 12, 2009
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    GE model WWA8320GAL How to I get the agitator to come off. Thanks for any advice art
    Please read this link below first before you try to remove the agitator.
    http://www.geappliances.com/search/fast/infobase/10002927.htm
    This link below will tell you how to remove the Agitator on the ge washer.
    http://www.wikihow.com/Remove-a-Stuck-GE-Washer-Agitator
    Jul 07, 2011 | Washing Machines
    How do you remove the aggitater
    1- First you must determine the brand of washing machine you have. 2- To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
  • Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts. 3-Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
  • Read more: How to Remove an Agitator From a Washing Machine ' eHow.com http://www.ehow.com/how_4620771_remove-agitator-washing-machine.html#ixzz1IhUKY7OQ
    Apr 06, 2011 | GE WBSR3140DW Top Load Washer
    How to remove agitator from GE washer? Model WHDRR418G1WW.
    how to remove agitator from GE hydrowave washer machine?
    Feb 27, 2010 | GE WBSR3140DW Top Load Washer
    My GE washer won't spin or agitate
    check the motor capacitor if your motor doesn't turn when powered, otherwise the "wig-wag"coil could be faulty,these coils shift your transmission for different cycles
    Aug 23, 2009 | GE Profile WPSR3100W
    GE profile washing machine won't agitate it spins out, drains,
    Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
    Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
    How do I remove the agitator from my GE Profile WPSR3100?
    Just yank it up is correct, but you may find that difficult sometimes. If so, try sliding a belt or other similar item under the agitator and fastening it to a heavy broom handle, then yank on it straight up. Now that it is off, you should see a upside down plastic can shaped part with one bolt holding it on. Remove that. If that does not come off, you may have to break it off. Next, try to turn the splined metal shaft with your fingers. If you can turn it, your transmission is shot. If you can not turn it with your fingers that's good, just replace the agitator drive (the upside down can thing) part number WH43X10032
    Nov 12, 2008 | GE Washing Machines
    GE WASHER MOD.WPSR3100 DRIPS OIL HOW TO GET TO IT
    your bearings are gone that's why you have oil you have a big job on your hands if i was you i would go down to your local second hand appliance shop they might take on the job and its not all the dear so try and ask first before wasting money doing it your self.
    Dec 08, 2007 | GE Energy Star WCVH6260F Front Load Washer
    Washing Machines Logo
    607 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
