Physicaldump of the memory
Problem: physcial dump of the memory when i working in internet then tis error will occr in two time in day.but when i work with application or editor like turbo c then i got this error after few minut. i also change my ram & reinstalled the o.s ihave gigabyte motherborad 80 gb HDD 512 ram p4 2.99 intel processor
  • Thomas F. Schneider May 11, 2010
    Their is an incompatability issue somewhere. No note telling you "due to conflect at..."?
  • 2,229 Answers
In my experience, you will never really be able to troublehsoot from the memory dump. It doesn't tell you anything that the normal person can understand.
You need to go to the control panel, and click on Administrative Tools. Within that window there will be an icon that says Event Viewer. Click on that. There should be at least 3 categories of events. One is security and that is probably not a problem. The next is Applications. If you click on that in the left pane, the messages will appear in the right pane. Any message with a red X (error) shows a problem. Clicking on that error message will show you what the error is. The same goes for the System item. Because there can be many problems, we cannot address them all here--but by clicking on the error messages you can get a start on the troubleshooting.
Perhaps coming back to this forum with the errors you can find some answers.
Posted on Mar 12, 2009
Physical memory dumping
once your computer take an BOD or blue screen of *****. it is an indicator that one of you perepherals was damage. in that case you only have to option the memory cards or the HDD. if some point you dont experience a hard time in booting it is not the HDD. maybe your memory cards was in defective state. sometimes good sometimes bad. try to chkdsk first or scan your HDD for posible bad cluster. and make a test also in your memory using some stress memory tester
Aug 21, 2017 | Intel Motherboard
The screen is blue and says beginning to dump physical memory
Windows has detected a serious programming-error, and cannot continue to run. Turn your computer off. Turn your computer on.
The next time that you connect to the Internet, Windows will send the "dump" of your computer's memory to Microsoft, so that they can trouble-shoot the cause of the problem, and try to fix it.
Aug 18, 2010 | IBM ThinkPad T22 2647 Notebook
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
Computer restarting again and again and shows a blue screen with "Beginning dump of physical memory." Also when i scan the system using kaspersky internet security antivirus it got restarted and i couldn't...
sometimes it happen because you have installed a driver recently and it is creating a havoc there. try to run in safe mode and restore the configuration to the previous one.
other options, is that a memory went bad. try to read what error is telling before the beginning dump of physical memory.
if one bank of memory is bad, try running your computer with one of the banks at the time.
Apr 23, 2010 | Microsoft Windows XP Professional With...
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Kenel data in page error
You need to rebuild your operating system from the supplied CDROM that came with your computer. You have the classic BSOD display, Blue Screen Of Death. Its a long job but its worth it in the end to completly repair your operating system and clean up your hard drive.
Jun 13, 2009 | Microsoft Windows XP Professional for PC
Memory dump
There are essentially two major causes of the physical memory dump screen: Running way to many programs at once, errors in the Windows registry.The first cause can be fixed rather easily. Simply run fewer programs or purchase additional RAM or processor upgrades. Your computer is running past its specified limits. But keep in mind the blue screen of
death should happen very infrequently. If you see the physical memory dump blue screen more often then the problem is errors in the Windows registry.This is a more abit of a harder problem to deal with. The registry is the most important component of your computer. The registry contains settings and information to run all software and hardware on the computers. When there are errors in the registry it disrupts the computers ability to communicate. When the system cannot compute, it freezes up and displays the Windows blue screen.
I found a registry cleaner that is free and works rather well. It is named cCleaner, has been around for some time and did I mention FREE...Download it from thelink below run it should clean up your registry...where good men fear to tread.
http://www.ccleaner.com/ccleaner-20
good luck, please leave a rating...thank you
May 04, 2009 | Intel Computers & Internet
Started with error memory dump
Try to do a system restore to where you have not install the SP1 or to the date the computer is still working fine.
May 09, 2008 | Computers & Internet
Sony Vaio VGN SZ330P
Try "Safe Mode " by pressing F5 or F8 while booting, if you dont have hardware problem on hard disk or somewhere safe mode with take you to system without loading many drivers and startup programs.
Dec 06, 2007 | Computers & Internet
Blue screen dump error when print to winfax
I suggest checking out the folks at GetFaxing.com, they are winfax experts
Nov 07, 2007 | Symantec WinFax Pro for PC
Computers & Internet Logo
61 people viewed this question
David Payne
David Payne
