Question about Schlage COBRA by Keyless Lock
Code not working
Only red light comes on when I put my code in and I tryed changing the batterys
When crank to start clock gos dark will not start come up with code 68
Hi,dont know what code means but if you put lights on and try and start the car and the lights dim then it could well be the battery,put a multimetre on the battery,black cable to earth and red cable to positive on battery put multimetre to volts you should have a reading of 12volts no less therwise battery has had it,replace.
hope this was some help.
Apr 12, 2015 | Cars & Trucks
Have an electronic safe, am putting the correct code in but the safe is not opening and the red and yellow lights are coming on and safe is beeping. I put new batteries in but still no use.
Red light means low batteries. the only thing that worked for me was heating the safe to help the batteries recover a bit and it opened!
Feb 19, 2011 | Locks & Locksmithing
Do i need ti install any software, i have changed the batteries several times but the green and red light do not come on.
If the mouse is working:
The green light only comes on when the mouse first comes on, battery change, switch on etc (as far as I can see).
I dont think you can see the red light, I can't.
My V220 works and the above are true for it.
If the mouse is not working:
Give more details; your operating system, mouse model, what you have tried...
Nov 03, 2010 | Logitech Cordless Mouse
Solid red light
Have about a 30 second window to replace batteries before all codes are lost and when you put in the new batteries it goes into programing mode. Re-enter codes and try it again. Have the same remote and it has happened to me before.
Mar 12, 2010 | DISH Network IR Remote Control
Batteries died. Put new ones in (red light comes
there is one red buton press two min then try
Dec 03, 2009 | Logitech Cordless Mouse
When I press the power button the light turns
hi..
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
thank u
rate me!!
Jul 15, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Sony Ericsson W580i
The red light is display comes whenever there cell phone battery is weak... try changing the battery!!!
Good Luck
FixYa
Aug 28, 2008 | Sony Ericsson w580i Cellular Phone
Sandleford electronic safe es20
have just had the same problems if you had the key there is a red button inside the door to reset the code but obviously no key no red button I have the sandleford number to call 03 97750699 or try the factory pre set 159 A or B see how you go
Aug 20, 2008 | Computers & Internet
Red light flashing
I had the same problem last night. It went away when I recharged the AA batteries.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Schlage COBRA by  Keyless Lock Logo
85 people viewed this question
Top Schlage Locks & Locksmithing Experts
JOHN LAPIER
ken skalski
Are you a Schlage Lock and Locksmithing Expert? Answer questions, earn points and help others
