Question about Xerox WorkCentre 7120/P Printer
Additional function key xerox
How do you find the additional function key
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
I cannot release the left margin on my Xerox Memorywriter 6015
When at the L. margin press the Mar Rel key not the L. mar key.
DickyO
Oct 24, 2012 | Xerox Office Equipment & Supplies
I am Deepak Gupta , I use Canon 3300 Xerox machine i face the error code 00100-002 pleace give me soultion
goto service mode by pressing additional function key and 2,8 keys at a time and press again additional function key then touch -
COPPER / FUNCTION / CLEAR /
ERR / OK ! / DC-CON / OK ! .
then switch off the power button and start again i think your problem is clear....
Mar 10, 2012 | Canon Office Equipment & Supplies
What do the f keys mean
On each keyboard there are additional sets of keys delineated as "Function" Keys. These keys are used for additional programmed functions, such as "F8" or "Function 8" which will allow a Windows user to access a boot menu when Windows first starts up. On a regular 102 key keyboard, such as those on a desktop computer, the function keys are located at the top of the keyboard with the letter "F" preceding the number of the key. On a laptop, generally the function keys are accessed by holding down a blue "Fn" down at the bottom of the keyboard and the specific number on the numeric portion of the keyboard. So in the above example of "F8" the combination of holding down "Fn + 8" would accomplish the same action.
I hope this help and if you require additional assistance, please do not hesitate to ask.
May 21, 2011 | Computers & Internet
Respected sir my ir400 canon xerox mashin masage is switch main power off and on.e001 i have machin switch main power off and on but problem not a solve pls discription this probem and solve. thanking...
it is related to fing unit.
you can go in service mode by pressing (additional function +2 +8 + additional finction)
touch on copier then go in function after that touch on clear
Err -then press ok
dcon then press ok
rcon then press ok
if then after problem not solved you have to replace fixing unit thermistar
because it is related to fixing temperature.
Apr 12, 2011 | Office Equipment & Supplies
My cannon iR3320 displays error code E000002-0000. the problem started today after yesterday's power surge
Most likely an error reset will take care of the problem. Get into service mode by pressing the additional function key, 2 & 8 key at the same time, then additional function key again. Press copier, function ( at top of display ), CLEAR, ERR then OK. Power down and back up again the copier. If error continues then the fixing film assembly will have to be replaced.
Dec 08, 2010 | Canon imageRUNNER 2200
I dont know how to go servicemode option in ir1570f pls reply...
additional functions key then pound pound on the # pad or its addition functions star star... or try additional function 2 and 8 then additional functions
Mar 20, 2010 | Canon ImageRUNNER 1670F Copier
Canon IR 2016
Additional Functions>2 key>8 key>Additional Functions (each key is pressed seperately, unlike regular iR copiers) Go to Copier>Functions>Clear> Err_ or Err_Clr. An E000 is a fuser code.
Aug 29, 2008 | Office Equipment & Supplies
Canon iR2200 Copier
E003 is a fixing unit error code. Have you been having power problems? Is this the first time it showed up? If so you need to reset the code in service mode..
Resetting Code: Press "*" additional fun.
Then at the same time "2&8" Then the "*", then touch "Copier", "Funca", "CLR", "ERA", then "OK"... then turn the main power off then on.
Jul 10, 2008 | Office Equipment & Supplies
Xerox WorkCentre 7120/P Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
