Question about HP Scanjet G2410 Flatbed Scanner
Clean glass underside HP Scanjet G2410 - HP Scanjet G2410 Flatbed Scanner
IrishDruid
  • 2712 Answers
SOURCE: HP Scanjet 3400 C
Unfortunately, The 3400 series cannot be cleaned on the underside of the glass. Scanners with the capability of having the under side of the glass cleaned are listed below.
Posted on Oct 04, 2008
  • 5 Answers
SOURCE: Disassembly of HP ScanJet 4470c.
You remove the panel that holds the control buttons by putting a small flat head screwdriver under the both outside edges (held by two small pins). Be carefull the ribbon cable does not unplug. After removing the two screws that are under the back hindge slots, the whole top pivots up and off of pins at the front. You feed the panel thru the hole left when you removed it. This frees up the top and the glass on both sides can be cleaned. Hold the glass up to a strong light to be sure it is clean before putting everything back in reverse order
Posted on Feb 19, 2009
ButtFuzz
  • 463 Answers
SOURCE: Not Support for Windows 2003 Server
From the HP website, on the G2410 support and drivers page: "If what you were looking for is not listed, then it is not available for downloading from the web in this OS and language" In short, you are SOL. You could try the Windows XP drivers (they'd be the closest match), but your mileage may vary. A lot. I've tried tricks such as this before with HP products with little success.
Posted on Feb 28, 2009
SOURCE: cannot uninstall or install HP scanjet G2410
I tried all the "decent" uninstall solutions like running HP's Level 1-4 Uninstall batch files. HP's installation software still insisted that parts were already installed. Then, with the scanner connected, the installation software got into competition with Windows also trying to install the driver. The reinstallation was no good. Solution Center wouldn't even start, preposterously announcing that it couldn't find the scanner!
When you have a reliable clone of your c:\ drive you can try daring solutions. Such as this:
1. Search the c:\ drive for files and folder with "Hewlett" or "HP" in their names. Kill them all.
2. Search the registry for keys with "Hewlett" visible or buried. Kill them all.
After 1 & 2, reinstallation worked smoothly. And my computer still works! The only evidence of the violence is an undeletable file 3963d.rbf now in c:\Config.Msi. I will report back if serious computer problems arise.
The point is that manual uninstall is possible and none of the elements are in hidden places. Someone else can determine whether both file and key deletions are necessary and exactly which ones.
Posted on Aug 09, 2009
SOURCE: The scan image becomes yellow
SCANNER G 2410 YELLOW BACKGROUND IN SCANNINNG.
Posted on Dec 17, 2009
In hp g2410 scans only the page top properly , remaining page is scanned as black inB&W or greenishyellow if color
it is not a problem with the scanner,are you closing the lid everytime??,your settings are not correct,or update the drivers, HP Scanjet G2410 Flatbed Scanner
Jul 11, 2015 | HP Scanjet G2410 Flatbed Scanner
How to clean glass
Any household spray like windex will work fine.
Nov 29, 2014 | HP Scanjet G2410 Flatbed Scanner
How to clean the glass underside of the hp scanjet g3010
working with computers since 1964 (yes, there were computers even then...), with consumer scanners since 1988, servicing hp equipment and scanners since 1998, for saving my life - i never, ever see any smudging on internal surface of the glass... could you kindly elaborate how you get smudging there?
there is no consumer serviceable parts inside, these are "disposable" scanners and never intended to be repaired or serviced inside.
Apr 24, 2012 | HP Scanjetâ„¢ G3010 Flatbed Scanner
How to scan in hp scanjet g2410
First install the required drivers for the HP Scanjet G2410 Flatbed Scanner.
Simple way is to scan is use PICASA
GOTO http://picasa.google.com/
Download picasa 3.8
  1. Make sure everything is connected and turned on!
  2. Put the photo on the glass of the scanner - face down
  3. In Picasa, click 'Import'
  4. Click the arrow for the drop down list of devices. You should see your scanner listed ... select it
  5. Now you will see a screen that depends on your scanner. There should be an option to 'Preview'. Click that.
  6. You should now see your picture, there may be some settings you want to change here, but if it looks OK then
  7. Click the button to Scan
  8. When it's done scanning, you're back at the standard Picasa Import screen. Click Import all.
  9. Select a folder to put it in. I made a folder called 'Old Photos' for the first one, then, for each subsequent scanned photo, I selected that existing folder from the drop-down list.
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jun 09, 2011 | HP Scanjet G2410 Flatbed Scanner
I cant install my g2410 scanner on my laptop running windows7
Some scanner drivers are not compatable with Windows 7. Check with the brand to see if they have any drivers available.
Mar 18, 2011 | HP Scanjet G2410 Flatbed Scanner
I Need Service Manual and Troubleshooting for HP Scanjet G2410
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3423841&taskId=135&prodTypeId=15179&prodSeriesId=3423840&lang=en&cc=us&submit=Go%20%BB
goto this link ull find all things
Jun 03, 2010 | HP Scanjet G2410 Flatbed Scanner
Lamp error in HP Scanner
It would cost more to replace the scanner assy than a new machine would cost you.
Nov 17, 2009 | HP Scanjet G2410 Flatbed Scanner
I NEED FREE SOFTWARE FOR EDITING TEST
You can download your HP SCANJET G2410 software and driver here, copy and paste this link to your address bar:
http://www.opendrivers.com/freedownload/247627/hp-scanjet-g2410-scanner-full-feature-software-driver-9.0-windows-2000-xp(x32-x64)-vista(x32-x64)-download.html
*Your vote will be highly appreciated. Thanks in advance.
Dec 26, 2008 | HP ScanJet 2400 Flatbed Scanner
HP Scanjet 3400 C
Aug 03, 2008 | HP Scanjet 3400c Flatbed Scanner
HP Scanjet G2410 Flatbed Scanner Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
