Question about Bosch Ovens
SETTING A TIMER ON BOSCH HBM 91
The instruction manual isn't very clear on setting the oven timer. The pamphlet indicates that the time before the oven switches on (i.e. countdown) is displayed once set but on mine its the end time that displays. Not very confident in using it.
3 Suggested Answers
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • 106 Answers
SOURCE: How do you set the timer for both upper and lower oven at same ti
most ovens will only let you do a time bake for 1 oven at a time. And a min timer .Same as you can only self clean one at a time. Not knpowing what brand you have , you might want to contact manufacture.
Posted on Nov 21, 2009
How to set cooking timer on pyrotechnic Bosch oven?
Here's the link to the manual page. Without the model number, I cannot give you the proper instructions but this page will tell you where to find your model number, then link you to the manual as well. Good luck!
BOSCH Customer link:
https://portalcn.bsh-partner.com/portal%28bD1kZSZjPTAwOQ==%29/PORTALFRAME.HTM
Jul 16, 2014 | Bosch Ovens
Smeg electric oven timer controls
Apr 10, 2008 | Smeg SE280X Stainless Steel Electric...
I've read the "getting started" instructions regarding the auto matic switch on and it doesn't seem to make sense. I can get it to turn off automatically but not on. Sorry for being dim.
Firstly, make sure the actual time is correct. Set the oven (if it's a double oven the clock function will only work on the main oven) to the setting and temp required. The first timer setting you put in is the cooking duration (not the start time) ie if it's a casserole that you want on low for a couple of hours, adjust the first setting to 2:00, when you press for the next setting you will see the the timer has already added 2hrs to the current time, adjust this to the time you want the item to finish (eg, You want it ready for 6pm, adjust to 18:00). Don't press anything else, give it a second or two and the oven will switch off. The oven will switch on 2hrs (or whatever time you have set) before the end time. Whilst the oven is waiting to switch back on, on some models the cooling fan will run continually, this is normal. If you are a little slow enter the times the clock will time ut and return to the actual time.
Hope this helps
Feb 21, 2013 | Neff Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    Moffat Stove with a self-cleaning oven. I would like to know how to clean the oven using the "self cleaning" feature
    hi there! I have a moffat stove and hopefully these instructions help you.
    First clear out the racks in your oven. Take them out and remove any excess chunks at the bottom.
    Then close your oven door and lock it by pulling the lock latch.
    Now looking at your oven knobs [not your burner knobs] turn both of them so they are both on the arrow knob [your oven knobs should have small pictures on them and both should have arrows]
    Now you need to set the time so in the middle of your oven their should be a timer and one start and stop timer on top of each other. Both timers go in increments of half an hour. So if you are starting your self cleaner at 3 move the dial to 3 or if you are starting at 3:30 move the dial to one tick after 3. Once you set your start timer, you need to set your stop timer.
    Setting your stop timer, it is recommended to set it for 3-5 hours. I set mine for 4 hours. So then set stop timer to time you want the cleaning to be. If you set your start timer at 3:30 put your stop timer at 7:30.
    The oven will start cleaning according to the time you set. The oven will get very hot. I recommend to not used the burners as the temperature goes to 500 degrees! You will smell an odor and that is your oven cleaning.... Hope this helps...
    Sep 13, 2010 | Ovens
    Nov 21, 2009 | Ovens
    How to set the timer
    1. Set the oven to the required
    temperature.
    2. Press the g button.
    3. Set the total cooking time with the +
    button (see the example in the
    illustration right, showing 1 hour and
    30 minutes).
    4. Press the h button.
    5. Set the cooking finish time with the +
    button (the example in the illustration
    shows 12.30 hrs.).
    After setting the display shows the
    time of day and indicates »AUTO«.
    The oven cooling fan will start
    immediatley.
    At the pre-set time, the oven will be
    automatically switched ON.
    The settings can be corrected at any
    time.
    When the pre-set cooking finish time
    is reached, a signal sounds and the
    oven is automatically switched OFF.
    To turn the signal off, briefly press the
    h button.
    6. Turn the oven selector switch to the
    0 position.
    7. The »AUTO« symbol blinks.
    Important: It must be switched OFF
    by pressing the E button.
    Also here is the manual.
    https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
    Good Luck
    Jan 20, 2009 | Neff U1721 Double circotherm Electric Oven
    Just brought a bosch oven and there no life in the bottom oven
    If it has a timer, then make sure it is set manual and not auto, or the oven will not work.
    Try pressing 2 buttons at the left of timer and one button on right of timer to set it to manual, if it does not work this way, then try another combination of buttons.
    Hope this helps.
    Plz rate my solution.
    Thanks.
    Jan 03, 2009 | Bosch HBL 435 Stainless Steel Electric...
    Timer clock on bosch double oven
    Please follow this link and download the instructions.
    Manual
    Please rate me as FIXYA
    Apr 29, 2008 | Bosch HBL 5056 Electric Double Oven
    Fan won't turn off & upper oven work in Manual mode
    This sounds like a control panel issue, you may have to replace it, about $300.00
    Jul 09, 2017 | Bosch HBN 455 Stainless Steel Electric...
    Ovens Logo
    16 people viewed this question
    Top Bosch Ovens Experts
    ashburton
    reliableservice
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
