Error code sc 194 LANIER 5515 - Office Equipment & Supplies
2 Suggested Answers
bowdo
  • 78 Answers
SOURCE: LANIER 5618 COPIER ERROR CODE SC-320
Yes this is a Polygon Mirror motor error it is reasonably common in the Lanier digitals. The mirror motor can be ordered separtetly to the laser unit.
Posted on Feb 12, 2008
Lanier 5518 with a sc541 code
To clear enter service mode and cycle power,(push in sequence clear modes(yellow) 1 0 7 then hold the stop(red) for 5 seconds) -Carl
Jan 20, 2015 | Lanier 5515, 5518, 5618, Ld013 Fuser Kit
SC392 ERROR CODE
There's a video showing how to clear SC error codes: Resetting Ricoh Savin Lanier SC Error Code There's also a discussion here: Thread Ricoh Aficio 220 error SC392
Jun 30, 2014 | Ricoh 885288 Black Copier Toner Cartridge...
Lanier 540c printer
IH inverter current error at power on. Either the fuser is damaged or the invertor coil is defective. You really should have a Ricoh tech look at that one. It is not an easy fix for the layman.
Feb 11, 2014 | Lanier Office Equipment & Supplies
Lanier 5518 gives a SC320 error code
This SC-320 code error occurs when polygon mirror motor fails or poor connection between BICU & polygon mirror motor please check first the connector of motor if you feel that the connector is good change the polygon mirroe motor it sits inside the LD unit please call the expert to change the part
thanks
Dec 15, 2010 | Lanier Office Equipment & Supplies
SC 571 error
Hello sir; The error code you have display, its means the fuser oil waste bottle full, check it out and dump it out, otherwise that's senser problem.
Feb 02, 2010 | Lanier Office Equipment & Supplies
A code just came up sc320 for the 5515 lanier
The polygon mirror motor (laser motor) is shot, and needs to be replaced.
Jun 15, 2009 | Lanier Office Equipment & Supplies
LANIER 5515 ERROR CODE SC390
the problem is with the toner density sensor.a quick fix would be to replace the photoconductor unit.thereafter you need to do the developer initialization adjustment.
Jun 09, 2009 | Office Equipment & Supplies
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
Feb 11, 2008 | Office Equipment & Supplies
94 people viewed this question
k24674
jasbo
jasbo
