Question about Beko Dishwashers
Salt light on continually BEKO DW600
Salt light stays on
  • 1462 Answers
SOURCE: the salt light keeps burning
the salt light is done by a reed switch operated by a float in the salty water. float may be stuck - give softener (where you put in the salt) a tap and also stir the water inside the softener. i assume you have put in enough salt. its not a serious fault
Posted on Mar 30, 2007
  • 1462 Answers
SOURCE: Low salt light
try stirring the water in the salt container. however, as long as you renew the salt now and again, it doesn't matter
Posted on Jun 24, 2008
  • 25 Answers
SOURCE: Salt lasts only a very short time in dishwasher
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
Posted on Jul 13, 2009
  • 867 Answers
SOURCE: my beko dishwasher is not rinsing properly, we add rinse aid and salt and the pots still come out with **** on then and are not being cleaned properly even on the hottest wash
Try running a dishwasher cleaner through it, it will break down any built up residue in the machine, with using salt to soften the water it can build up in places and reduce water flow.
Posted on Mar 06, 2012
  • 867 Answers
SOURCE: salt light stays on all the time -salt is full
The sensor that detects the salt level is faulty, it shouldn't affect the actual operation of the dishwasher though.
Posted on Mar 11, 2012
Testimonial: "Thanks for the help."
What happens if I put too much salt in dishwater
Hey Des,
I assume you're referring to the pool rather than dishwater. Adding too much salt won't necessarily do harm instantly. However, to some swimmer, the high salt content can be quite rough on skin and even hair. Aside from swimmer experiences, any masonry around your pool will erode quicker over time due to salt being extremely abrasive by nature. I'd recommend getting a salt tester strip or electronic meter to check your salt.
To add on, if the salt generator is constantly saying to add salt, it's probably time to clean your salt cell also.
Sep 15, 2017 | Pool & Spa
Dishwasher salt light wont go out after filling it with salt and everything is coming out white
well,if you fill it with salt and the salt light wont go out,and your dishes came out white,PLEASE STAY AWAY FROM THE DISHWASHER! the salt light is a warning light ,not to fill it but to delime it! wow,
Apr 23, 2015 | Dishwashers
Why does my low salt light stays on
might be a sensor failure id try giving it a high dose of salt water direct to the intake of system (not the entire pool)
see if light temp goes out , then ya know sensor thinks you dont have enough salt in pool
Apr 23, 2014 | Intex Salt Water Saltwater System Chlorine...
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
Service light comes on and stays on
check salt level if ok check or clean salt sensor
Oct 22, 2013 | Intex Automatic Salt Water System for ...
Hi, I have a BEKO GS5323 Dishwasher that has just
sounds like the sault filter has broken. it is in the base at the bottom its a thin plastic filter type. will need to be changed.
Sep 29, 2013 | Dishwashers
Salt light stays on
There is probubally an sensor in the machine that senses salt levels, it is not uncommon for and sensor to be faulty out of the box, I would contact the manufacturers on their 1-800 number nd consult with them and if be order the replacement part from them directly. Hope this helps
Sep 08, 2012 | Amana Dishwashers
Salt light stays on all the time -salt is full
Mar 10, 2012 | Hotpoint Dishwashers
My beko dishwasher is not rinsing properly, we add rinse aid and salt and the pots still come out with **** on then and are not being cleaned properly even on the hottest wash
Mar 06, 2012 | Dishwashers
The red light for salt (PC) is on. What does this mean as we do not have the instruction manual. Thanks
Salt Light is connected to the level of hardness of your local water supply. If your water level is very soft (below 4gr/..) then you dont need salt, but the light will stay on. Otherwise need to add salt and the light should go off (if it is working.)
Apr 16, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Dishwashers Logo
37 people viewed this question
Top Beko Dishwashers Experts
Shekar Avadhani
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
