Question about Roper REX4634KQ Electric Dryer
Thermostat wher is the thermostat at so i can order a new one
  • Roper Master
  • 3,361 Answers
Depends on your model number and your problem.
There are several that control different functions.
Posted on Mar 12, 2009
What do I need to change thermostat in a dodge durango magnum 5.2
if its the stat then you will need a 13mm socket and ratchet with extension to remove the bolts that hold the stat housing to the motor. a drain bucket to drain the cooling system below the level of the stat, remove stat and clean surfaces on both the housing and motor. install the new stat and gasket reassemble in reverse order and refill the cooling system and run engine to operating temp and make sure all air is out of system.
May 25, 2014 | 2000 Dodge Durango
Wher is the thermosat in 2005 GMC canyon pickup
Follow the lot hose to the drivers side of the engine. The thermostat is the part the hose is attached that is bolted to the engine block. You will get the thermostat housing assembly when you purchase the new one. Removing the drivers front wheel inner liner will help make the repair easier.
Apr 06, 2013 | Cars & Trucks
Wher is the thermostat on a 1999 Mustang
It's located in the from of the engine. Look for the top radiator hose follow it to the engine it connects to the thermostat housing that's mounted with 2 bolts to the engine. The thermostat is located inside that housing.
Jul 08, 2011 | 1999 Ford Mustang Cobra
Bottom water hose stays cold. do i need to r&r thermstat & wher is it located?
sounds like a bad thermostat, follow the top radiator hose to the engine, this hose will end at the waterneck, usually secured with 2 bolts, remove the bolts and carefully pry the waterneck off, inside you will see the thermostat, note which way it is facing, should be spring side down, use a new waterneck gasket when putting back together
Jan 15, 2011 | 2002 Jeep Liberty
How to put in a thermostat
Find the return hose from your radiator, remove the thermostat housing from the engine, (this will be located where the radiator hose meets the engine) pop the old thermostat out and replace, make sure to install the new thermostat the same way it came out, and i have noticed that some thermostats dont come with a new gasket, if not, you may be able to use the one already on your thermostat, if its not in bad shape. Hope this helps and good luck
Mar 19, 2010 | 2003 Pontiac Grand Am
Temp doesn't shut down when preset temp reached. Have to do it myself. Set it for 62 for example, won't come on till I set it to maybe 70. Try to set the temp to maybe 65, doesn't shut down till we...
This is normal. It will only turn on when the temperature set is below the ambient temperature in the area around the thermostat.
Your problem may be the location of the thermostat is not ideal form the areas you are heating. this usually cause the temperature in areas vary from the thermostat to the point wher relocation of the thermostat is sometimes the best resolution.
this is often the case wher ther are multiple heating zines in a building, and one or more zones interfere with the thermostat of others,
but it also happen in single zone heating systems too.
Jan 30, 2010 | DeLonghi DCH4120 SafeHeat Ceramic Compact...
Wher is the thermostaton1800cc
on the back of the head i think
Nov 15, 2009 | 1999 Volkswagen Passat
Wher is the thermostat on my 95 jetta with the 2.0
The themostat is located on the front passenger side of the car . Follow the hose coming from the raditator and it will lead you to the location of the thermostat. You have to move the power steering pump out of the way for easier access of the thermostat.
Sep 06, 2009 | 1995 Volkswagen Jetta
Thermostat replacement
go to and look in the compounts list for that year car and it will tell you excatly wher it is located.
Feb 19, 2009 | 1992 Toyota Celica
I need a new motor for my mx91 blender, wher cN I GET 1?
You can order direct from Novon
Most companies that deal with commercial restaurant equipment parts and service will also stock parts for this blender.
Aug 10, 2008 | Dynamic MX91 Handheld Blender
Roper REX4634KQ Electric Dryer Logo
49 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
