Question about DDI PENTECH RUBZ 7 COUNT ERASERS CASE PACK 24
Pentec rice cooker cannot cooking
Cannot cooking...just in warm condition without cooked.
My rice cooker, its not responding. Panasonic SR G06. power is ok , but its just dont want to cook! why??
check replace the micro switch of your rice cooker it is the switch that is connected to the cook and warm button....check for the heating ellement it is the coil that heats to do this open the bottom cover of your rice cooker you can see a round shape fillament examin whether this fillament is not brocken and is connected to the power source
May 20, 2010 | Panasonic SR-W06NA 3-Cup Rice Cooker
Was using rice cooked for sometime. My cooker is not starting to cook whne I press cook button. That is there is no blip and light above cook is not coming. Whereas when I press on warm button, warm button...
In the top cover of your rice cooker there is a sensor that controls the cooking circuit. Most of the t\ime what happens is the wire in the hinge area breaks due to the opening and closing of the lid. I even had to repair my own rice cooker by cutting away the damaged wire then soldering a longer new wire in BOTH wires. I also added shrink tubing over the 4 connections on 2 wires.
Jan 09, 2010 | Aroma ARC-838TC 20-Cup Rice Cooker
I was using the cooker and the lights went off. The rice cooked, but I'm thinking there is an issue with the cook/warm switch. I have the 8-cup cooker. HELP! I love this machine and don't want to be...
it may just be the bulb in the switch,, if its still cooking ok thats what i put my money on, there a neon type so they dont last for ever dont worry if its still cooking ok
Nov 08, 2009 | Cuisinart CRC-800 8-Cup Rice Cooker
I purchased today, when i tried to cook rice, followed directions, cook light only stayed on 10 minutes and warm light automatically turned on. Rice and water were cold. I tried several times and reread...
This a bad unit. You sould return for an exchange. There is thermo strip inside to control cooking time and to change the stage of ON/WARM light when it reaches the calibration point depending on the weight of rice to cook. Now it is not working.
Aug 12, 2009 | Rival RC61 6-Cup Rice Cooker
Rice cooker goes to "keep warm" mode before rice is cooked
bad thermostat . there are no parts made for this model . sorry
Jan 17, 2009 | Tiger JNP-1000 5.5-Cup Rice Cooker
Rice Cooker promaturely pops up before rice is cooked
try adding a little less water, And letting it sit about 4 min to make sure the steaming has stopped
Oct 21, 2008 | Zojirushi NRC-15 8-Cup Rice Cooker
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
Jan 01, 2008 | Continental Manufacturing Company CE23201...
DDI PENTECH RUBZ 7 COUNT ERASERS CASE PACK 24 Logo
62 people viewed this question
Top DDI Office Equipment & Supplies Experts
jasbo
jasbo
Are you a DDI Office Equipment and Supply Expert? Answer questions, earn points and help others
