Question about Health & Beauty
I wantto know wear can i get a charger ae244000 24v lead-acid for rascal 600
It is a prism ghc-244000-emi
3 Suggested Answers
  • 692 Answers
SOURCE: Hello. I need a
Any 4 amp charger you can find will work to charge your batteries. Preferably find one that has an on/off switch on the charger. You should be able to find one on ebay a lot less than what the scooter repair store quoted you Check around your neighborhood someone might have a second charger that they are not using. Since Medicare will pay for a new chair every 5 years someone might have a extra charger laying around. Hope this helps you
Posted on Oct 18, 2010
batvette
  • 16 Answers
SOURCE: rascal 600
Neil wood, the Rascal 600 DOES use an on board charger. What signal is the white wire looking for to make the scooter move is the question. 28v?
Posted on Sep 01, 2012
VETERANS HOME JUST GAVE ME A USED QUANTUM WHEELCHAIR AND PRIDE MOBILITY CHARGER. HAS AGM BATTERIES. CHARGER MODEL EA11488 SAY LEAD ACID BATTERIES ONLY ????
AGM batteries( absorbant glass mat ) batteries have a different charge rate to ordinary lead acid batteries
it is all abiut the charging rate or charging volts so the charger you have may not be suitable for the AGM batteries in the chair
the difference in the lead acid battery and the AGM battery is the construction
Lead acid batteries will spill acid if tipped over where as a AGM the acid is absorbed in the glass mat or is an acid gel
to get a read of what it is all about go www.batteryuniversity.com and you will see what I am refering to
next best thing is to ring your local battery shop and ask then what charger you should be using for AGM batteries and if a normal lead acid battery is suitable for the job
Jan 24, 2017 | Pride Health & Beauty
Electric Mobility: Replacement scooter charger
Rob, If need be, possible you can adapt you old chargers connector onto new charger if not the same plug. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
24 Volt 4 0 Amp On Board Battery Charger for Rascal Scooters and Power...
RASCAL 600 600t HANDICAP MOBILITY SCOOTER PRISM 24V BATTERY CHARGER...
Aug 17, 2016 | Electric Health & Beauty
Battery light comes on charge light will not dc out put 24v 4v charger prism GHC-244000il-EMI no output when could I have a problem other than charger has an 1605 inhibit boost
hi , what is the name of the mobility scooter please ? have you checked that there is no fuse fitted to the charger line ? can you please try another charger ?, this will eliminate the scooter ...
Regards
Rob
help me help you ...
Sep 21, 2015 | Health & Beauty
I have a rascal and put new batteries in it and it seems they will not charge up what could be the problem?
Hi Chris,,,, Now lets get the silly question out of the way first, have you tried another charger ?
IS it a built in charger ?
Remember a bad charger == Bad batteries...
the lead that goes from the chagrer socket to the batteries via the controller are most likely adding resistance that the charger does not like ...
Regards
Robi
Aug 31, 2015 | Rascal 600 T Electric Scooter w Seat Lift...
What kind of chargers can i use for rascal 600
I would recommend the correct automatic charger as you don't want to damage your batteries or have a fire/explosion.
Mar 27, 2014 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal scooter
Battery Voltage is usually always 12, Amperage can vary slightly with no major problems. 35 Amp is standard and will not present any problems.
Jan 28, 2014 | Health & Beauty
My charger on Rascal 600 does not charge. After checking all the common reasons without any luck I remove the charger and could not measure any voltage output. My Dealer sezs the charger won't work without...
Most chargers are 3 pin. Plus and minus charging voltage to the
batteries and a third pin monitors the actual battery voltage, so
that the automatic charger can turn itself off once the batteries
are fully charged. As Brad has mentioned, the connection
from the charger has to be made for the charger to produce
a voltage at those pins. The best way to see if it is charging
is to remove the seat and measure across both batteries..
assuming it's a 24volt system like most. Charging voltage
can be as high as 28volts across the positive of one 12volt
battery (connected in series to the other 12v battery) and the
negative of the other battery. You can monitor the charging
voltage across the batteries with a digital volt meter.
Nov 04, 2013 | Rascal 600 T Electric Scooter w Seat Lift...
Rascal 600
Apr 20, 2012 | Electric Mobility Power Electric Scooter...
Hello. I need a battery charger for a Rascal 325. This is the second one. It is not an OEM but a Prism GHC-244000IL-EMI 24V Model AE244000. They tell me at my scooter repair store that the OEM costs...
Oct 18, 2010 | Electric Mobility Power Electric Scooter...
Battery charger
Most lead acid batteries can be charged with a boost, this can be 10 AMPs, but normally have a current sense circuit so when the battery reaches it knee it goes into a trickle charge.
Jul 18, 2008 | Computers & Internet
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
