Question about Acer Aspire 5720 6497 Laptop
My computer will not boot up correctly. - Acer Aspire 5720 6497 Laptop
  • Atticus30
    Atticus30 May 11, 2010
    What is it doing?
Computer was trying to boot but had no operating system. I installed windows to hd on another pc. put hd in the acer and now it wont boot. It acts like its on protect mode. How do I boot?
The OS will only work in the machine it was installed on. With the correct OS in the correct machine, examine the hdd that won't boot and check the drive has a drive letter assigned to it. If it hasn't, that is a reason why it won't boot.
Jun 30, 2015 | Acer Computers & Internet
Cannot boot up!
Take the small battery out of the motherboard for a few minutes and replace,prees del whilst booting to get to bias and select last good configuration
Jan 10, 2014 | ASUS CG8350-06 Desktop Core i7 3.4GHz 8GB...
Dell xps 710 motherboard replaced with 700 motherboard but it does not boot
This could be any number of problems. First start with hardware. Is everything seated and connected correctly? Are the hard drives installed correctly. Are the power on pins on the board set correctly or pinned at all? Is the ram the correct ram?
Check the hard drives, are they functional, do they boot with other computers?
Use a volt meter and check that the power supply is producing the correct voltages on all the connectors and rails.
If that all checks out, it might be a bios error. Check your boot load order and if the motherboard is detecting the hard drives, check that the correct bios settings for OS management are in place as this is a server. Is the RAM power settings (voltage) and speed correctly selected? Will the computer boot from optical drive using a live CD? Will it boot from a USB live OS (like Ubuntu)?
Since it's not booting, you may not have compatible hardware or damaged hardware. The OS that's installed on the hard drives may not be able to load on the new (older model) motherboard due to driver incompatibility.
Oct 13, 2013 | Intel Server Board SE7501BR2 Motherboard
Computer not booting
Do you get anything on the screen at all? Is this a laptop?
Jul 07, 2009 | Dell Inspiron 1420 Notebook
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
Start up
That message will appear when there is no boot record found on any device the system board tries to boot from. This probably means that your hard drive is not being detected, does not have a bootable copy of Windows on it, or is defective.
Make sure the drive is correctly listed in the motherboard setup screens. If it is not, check for proper power and data cable connections at both the drive and main board. If the drive is being correctly identified, you may need to reinstall your operating system.
Jan 20, 2009 | Intel Motherboard
My computer won't start up right
press F1, when it boots you are going to have to go down to the date and time, and click on it then you will need to put in the correct day date and time. If pressing f2 it will take you into the bios, and you can set it from there prior to booting, unless you know what you are doing, stay away from the bios, it can really screw up your computer. Good luck and Peace,Gym
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Hp a305w will not boot to windows
I solved a similar problem I had by pressing the function keys upon booting up. Then, when I found the correct buttons to get into the bios, I was able to set the correct boot-up device(s).
Mar 01, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Acer Aspire 5720 6497 Laptop Logo
70 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
