Question about Targus Amp18us Presentation Remote
Targus amp18us I plug the USB dongle into my laptop and put the presentation in Slideshow but when I use the presentation remote, the PowerPoint slides do not advance.
4 Suggested Answers
Jastababe
  • 117 Answers
SOURCE: Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Posted on Feb 25, 2008
Damilare
  • 358 Answers
SOURCE: Targuss Wireless presenter not recognized
The first thing that I would advise you to do is,
Make sure you are connecting it to your system through a USB 2.0 Port, and not 1.0 USB Port.
Next, uninstall the Wireless presenter totally from the System first,
Then go to "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your Wireless presenter).
After this, ensure that it is On, then Scan for wireless networks.
It should connect like that.
(In case you don't know how to uninstall the Adapter, Right-Click on my computer Icon, Properties, Device Manager, then select the Adapter under network adapters, and right click on it, then select uninstall.)
Hope this helps.
Goodluck
Posted on Nov 24, 2009
SOURCE: No recognition by OS
Contact your provider and try to inquire whether what OS will the device run only. If the device comes with a container, try to read some instructions there on how to make it run and what particular OS it will run.
Posted on Feb 04, 2010
How do I use a jump drive to display a power point presentation on my TV?
It means it is only for putting new firmware onto the tv. You won't be able to load anything through this USB port. The TV is looking for a specific filename to run and even if you named your powerpoint presentation the right name, the TV will not be able to display it.
Your next best option is to get a DVD player that has a USB port for MEDIA and load a slideshow of IMAGES. You'll have to export your PowerPoint as images first (obviously).
Apr 30, 2014 | Seiki 55" LCD TV - SC552GS
August LP102R presenter will not work
You obviously need a driver. Where did you get the presenter?
Apr 11, 2014 | August LP102R Wireless Presenter with Red...
How to make an slideshow and download?
Two methods for you to make a slideshow:
1> save your PowerPoint file as slide show:
Before you save your PPT as PPSX format you need to set up the exact time duration for each slide so that it can run by itself. For more details, please click How to Timing Automatic PowerPoint Presentations.
Then you should place the presentation file and the music together in the same folder, zip it and send to the recipients.
2>convert your powerpoint to Flash
No sound or any other effect gets lost with both converters. Then email the video presentation or put it on YouTube so that they can share.
Dec 31, 2010 | Arcsoft Computers & Internet
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Photos to slideshow converter
you can install windows movie maker software. then you can create slideshow movie.
Mar 03, 2009 | HP Pavilion dv6000z Notebook
I forget how to connect my targus presenter to the usb device. What sequence do I push the connect buttons?
To Reconnect the Device and the Receiver :
Position the Power Switch to “Presenter” mode to turn on the presenter.
1 This presenter is a plug and play device and should work once the USB receiver is connected to and recognised by the computer. If the device is not working or you have recently replaced the batteries, you can try to reset the ID code between the receiver and the remote. To do this, do the following:
2 Once the computer has recognised the device. Press the
connection button on the receiver.
3. After the connection button is pressed on the receiver, press the
connection button on the back side of the presenter.
The devices are paired and ready to use.
Or check from page 5 on the USER GUIDE
Dec 17, 2008 | Targus (AMP0205USZ) Remote Control
Cannot get my Sharp Notevision remote to advance slides
you need an infrared receiver that plugs into your laptop to receive the signal ...honestly they arn't very reliable...go buy a targus presentation remote at staples for 39-69 bucks if you want areceiver i think i have one left
Nov 13, 2008 | Sharp Notevision XG-P10XU Multimedia...
Targus Amp18us Presentation Remote Logo
27 people viewed this question
Top Targus Computers & Internet Experts
dhnguyen
J John
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
