When the mother board goes out, you'll get nothing ever again from it. If it comes back usable each time, it won't be your motherboard. Fix the other stuff.
there is no way to fix this problem rather than changing the mother board in your mobile. contact your service provider to change the mother board of your mobile.. this will fix your problem..
if yes take the mother baord out of cabinet . place the mother bord on an insulating surface with proceesor . then connect smps ... poweron the board by shortin the frnt panel connectors . connect all peripehrals like monitor , kb and mouse etc ..... if this seems to be working try to insulate the cabin whre mother board is fixed ................ SMPS can also cause no power try chekin with another smps too
remove ur power supply socket from the mother board short the pin green and black in the connector if the smps start no problen with the power supply then the problems lies with ur mother board wiring or fault in your mother board if your mother board has secondry power fix it correctly to mother board sock et with has 4 pin if its not working cousult a chiplel engineer the fault lies in the power supply of the motherboard
