Question about Samsung Corby 2 GT S3850
My corby 2 is keep on charging itself without plugging to its charger and it keeps on initializing
When tis plug out to its charger, its keeps on charging and then after that its said press end to quit samsung kies and after i pressed end its doing the same thing
GrinningFool
  • 625 Answers
SOURCE: Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
Posted on Aug 18, 2009
SOURCE: battery/charge
i just tried both of these-- the hydrogen peroxide and shoving the battery up closer to the prongs... worked wonders!!! fixed completely!! thank you!
Posted on Mar 08, 2010
SOURCE: samsung B3310, freezes, switches on and off
buy a new phone
Posted on Jun 03, 2010
SOURCE: My Samsung phone won't turn
mine is doing the same thing, did you find a solution?
Posted on Jul 30, 2010
  • 21 Answers
SOURCE: There are 2 ways of
you can contact the service provider.........
Posted on Jul 11, 2011
My acer iconia8 will not charge and will not turn on. Been charging for days.its in really goodcondition
Two possibilities come to mind. Your charger croaked or the plug-in port on the laptop went bad. Either would keep the machine from powering up if the battery was dead. Does the power light on the charger come on? How about the charge indicator on the laptop itself?
You don't need a battery installed if you are plugged into AC. It should boot if the charger and port are OK. If they are, and it still won't boot, you have other problems.
Chargers are cheap, but repairing/replacing the charging port can run upwards of $100. And it takes a good tech to do it without damaging the motherboard.
Jan 30, 2015 | Acer Computers & Internet
My samsung corby cannot be charge..how can i solve this problem?
I would try charging it with a different charger. its more likely that the charger itself is the issue. If not then the issue could be with the phone. Try a hard reset of the phone ( pulling the battery) and then put battery back in and plug in charger. try moving it around if no connection issue could be with the charger or the charging port on the phone.
Oct 19, 2012 | Samsung GT S3850 Corby II
Once i plug in my charger its wont charge!
Turn it off, & keep it off for a while. It's happened to me as well. Turn it back on & plug the charger in.
Dec 16, 2011 | Sanyo SCP-2700 Cell Phone
Can not get charger to totally connect into the phone to charge. Do you think there is something wrong w/ the end on the charger or would it be the phone itself?
Check to see if there are any mechanisms on the charger plug that keep it plugged into the phone. If they seem loose or damaged, replace the charger. Also replace it if the tip of the charger looks in any way deformed. Otherwise, it may very well be a problem with the phone's charger input. Try cleaning the input with some rubbing alcohol as a last resort. If it charges but doesn't stay plugged in, the best thing may be some tape to keep it connected. Hope I could help =)
Mar 01, 2011 | Cell Phones
My laptop HP PRESARIO V1000 won't start without charger plug in. When push on, the charge led blinking for eight times then nothing happen. it start normally when I turn on with charger plug in, after...
It sounds like the Battery is Dead or not charging. You might try a local pc shop and see if they have any laptop batteries for you laptop. Or have them test to see if the battery is charging.
Dec 11, 2010 | Compaq Presario M2000 V1000 V2000 V3000...
Laptop is not getting charged
you need to buy new motherboard, it is a hardware problem
if you still on the warranty, take advantage of that because i believe they going to replace the parts for free
Jun 15, 2010 | Acer Aspire 4720 Notebook
On the exterior of my laptop where the battery power adapter plugs into the laptop the power cord wont go in to it?
Check that there isn't something jambed into the charger plug itself. When it fits into the charger port, most ports have a power pin running down the middle of them. The opening in the middle of the charger plug runs over that power pin. If the pin has broken off the power port or has been bent over, it will keep the plug from entering. Also, on the sides of the power ports there is a small strip of metal that touches the charger plug when it enters the port. Make sure that these are not sticking out too far to keep the plug from entering. I would check to make sure that the charge plug is not plugged up.
Dec 02, 2009 | Office Equipment & Supplies
Toshiba Tecra 8000 keeps switching itself off.
I'd suggest removing the battery. Most laptops can run directly off the AC adapter. If it will boot up OK without the bad battery, you can either leave it like that, or buy a new battery.
If it won't boot, then you have problems other than the battery.
Feb 08, 2009 | Toshiba Tecra 8000 Notebook
Samsung Corby 2 GT S3850 Logo
42 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
