An worktop upstand was fitted on top of stainless steel splashback which was then burnt and removed from stainless steel splashback. It had been stuck to it with clear silicone and although all the residue of silicone has been removed, you can still clearly see where the silicone was on the stainless steel which is now exposed as the final finish?
Hello Anonymous,
If you look on AMAZON... (let's say)...
You will find a regular INDUSTRY both Do-it-YOURSELF
and PROFESSIONAL refinishing/scratch removal...
(et al)
Such as...
https://www.idealhomegarden.com/web?qsrc=999&qo=semQuery&ad=semD&o=604745&l=sem&askid=f1fdf0d7-86e2-4c98-a6f4-29a5fbcf5728-0-ih_gsb&q=refinishing%20stainless%20steel&dqi=&am=broad&an=google_s
And...
https://index.about.com/index?qsrc=999&qo=semQuery&ad=semD&o=603322&l=sem&askid=64703305-984f-441c-a99f-b09877dddd88-0-ab_gsb&q=stainless%20steel%20refinishing&dqi=&am=broad&an=google_s&gclid=EAIaIQobChMI3K6Xn9L21gIVDKZpCh0FGgK7EAEYAyAAEgKN1_D_BwE
SS Sink: VERY clever article (avoid all the "down-loads")
How to Refinish an Old Stainless Steel Kitchen Sink
Hope this helps
Carnac the Magnificent
SOURCE: fingerprint stains on stainless steel fridge doors
going with the grain( s/s has grain just like wood product) try cleaning with a stainles steel cleanlingcloth and some wd40, this will remove any defect in th metal go with the grain not across you will leave rub marks if going avcross t he grain!!
SOURCE: discolorations/stains on stainless steel refrigerator surface
Tried lots of suggestions to no avail. Tried a USED, dried out Scotch Brite Cook Top pad on the scrubber handle with Heavy Duty Fantastick sprayed on the pad. Scrubbed the drip marks at the bottom and wiped away to see if it was "scratching" or marri8ng the finish. Nope, but IT WAS taking the water marks off. So I did a bit more and checked again. Working great with no problems for the finish. Cleaned the whole watermark area. Rinsed of with wet cloth. Let it dry and then used my usual stainless cleaner, buffed to shine and walked away to post this. :> My refrig is an Aman too but I read other problem sites and it is common with stainless steel refrigs
SOURCE: White water mark stains on stainless steel
Debruce Polish will remove these marks. DeBruce Polish is all you will ever need for your stainless steel and ceramic cook tops, polished granite, marble, porcelain, formica and
glass. DeBruce is non-toxic odor-less and eco-friendly. You can get
DeBruce on line at debrucepolish.com.
They also have a you tube demo "debruce method"
this stuff really works
SOURCE: door removal
THE HANDELS LIFT UP AND RELEASE THEY ARE STUBORN PUT A LAYOR OF DUCT TAPE ABOVE HANDLE TO PROTECT THE PAINT OF THE DOOR THEN **** UPWARD
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
SOURCE: DAMAGED SAMSUNG REFRIGERATOR STAINLESS STEEL DOOR,
go back to the seller and he will put more light on how you can get the part.
