Question about P3 International Compaq Evo N160 Notebook
Compaq EVo N610C My laptop will not boot up.
Compaq evo n610c
The laptop will not boot up.
Sometimes I can get the screen to light up, and I try to press F10, but it dies on me. There is power to the computer as I can see the lights for the battery charger, hard disk and RAM.
I also have to press down on the bottom left hand side of the computer to make the ram light turn on.
Is this problem repairable? Should I throw this piece of junk away? Should I think about replacing the motherboard with a compatible one?
David Carberry
Quebec City
  • Anonymous Apr 08, 2009
    IF I do not press either F10 or F12, and wait between 5-15 minutes, the hard-drive-based password utility (which I have never previously used, and currently does not appear when the system behaves normally) appears.
I AM LOOKING FOR A LAPTOP BATTERY FOR MY COMPAQ EVO N610C A GOOD LOW PRICE.HI-CAPACITY LI-ION (4400MAH 8 CELLS) FOR COMPAQ EVO N610C
don't waste money on buying second or used.
buy original from near HP store or order online. check HP center near
Oct 12, 2010 | HP Compaq Evo n610c Notebook
My evo n610c will not boot, acts like it is going to then goes to black screen again
Try reseating your memory, if that doesn't work check power voltage at end of power cord to see if your getting correct reading
Nov 30, 2009 | Compaq Evo N610C Notebook
Screen turn off of Compaq Evo Notebook N610c
check your settings under power options in control panel, also check advanced power options in bios. very likley you will find problem here.
Jul 25, 2009 | Compaq Evo Notebook N610c
Evo n610c won't power up
pls connected to pc to mobile phone bluetooth connected
Mar 14, 2009 | Compaq Evo N610C Notebook
Compaq Evo N610C Faint Screen
Usually it's the inverter. Sometimes it's the backlight / lcd, and occasionally it's the lcd cable and or video card.
Easiest thing to do is order a replacement inverter from ebay. They're cheap and then swap it. You just need to remove the outside lcd bezel, it's just four or five screws and you're in business.
Feb 22, 2009 | Compaq Evo N610C Notebook
Bios password n610c
Try this: -
Remove your Laptop Li-ion battery module.
Then remove the RTC battery for at least 15min.
Replace RTC, and boot the computer ONLY with the AC-Adapter.
Enter the BIOS and set to boot from USB
Feb 13, 2009 | Compaq Evo N610C Notebook
P3 International Compaq Evo N160 Notebook Logo
306 people viewed this question
Top P3 International Computers & Internet Experts
David Payne
David Payne
Are you a P3 International Computer and Internet Expert? Answer questions, earn points and help others
