Question about GE Refrigerators
Water freezing under deli drawer on ge model GFSL6KKYBLS
Model GFSL6KKYBLS
woodchuck789
  • 4059 Answers
SOURCE: GE frdge model ctx21eazhrww has water accumulating
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 20, 2009
  • 30 Answers
SOURCE: water under crisper drawers. model frt18b4a
Unplug the power to the Fridge, take the items out of the freezer. There is a bottom tray that's inside the freezer that has 2 or 4 screws, remove the screws that holds the floor to the freezer and lift it out. You will probably see a sheet of ice on the bottom of the freezer. You may have to take off the back cover which is inside the freezer, it covers the evaporator. Then you will want to defrost the ice, do not use a heat gun it will melt the inside of the freezer. Best way to thaw it is leave the power off and melt it with hot water (not boiling). Either wet vac out the water as it melts or use a hand towel to mop it up. Sometimes a turkey baster will work to squeegee it out. There is a drain hole in the back that you will see as the ice begins to melt. That needs to be clear and the only way to clear it is to cover it with hot water. You will know that it clears and working when you see the water drain out thru the drain hole in the back of the inside of the freezer. By the way the drain drains thru a pipe thru a tray that's on top of your compressor. That's what heats it and makes it evaporate. Be advised that as you see that it is clearing, you can stop dumping water down there as some may get on the floor as the pan may overflow and dump water on the floor. If that happens, just mop up the water from the floor. Now put it back together again and plug it back in and you should have no further problems.
Posted on Aug 31, 2009
woodchuck789
  • 4059 Answers
SOURCE: GE Profile side by side...water collects under the
Posted on Oct 27, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a GE Profile
Hi
Try and access the ice dispenser assembly and check from where the water is leaking. You would need to disassemble the ice dispenser and ice maker to check this. The ice dispenser is located in the upper portion of the freezer compartment. This assembly stores ice made by the icemaker and dispenses ice on demand from the door dispenser target switch.
1. Remove the upper ice bucket tray.
2. Slide out the ice dispenser assembly.
3. Remove the ice cube solenoid linkage Phillips head screw and slide the linkage back.
4. Remove the ice crusher cover Phillips head screws (2) and remove the cover.
5. With a pair of pliers, twist off the backing plate tabs located on either side of the crusher.
6. With 2 small flat-blade screwdrivers, unlock the ice crusher locking tabs located at either side of the ice crusher.
7. Lift the ice crusher out of the bucket.
8. Remove the ice crusher back cover.
9. Remove the locking ring from the ice crusher auger.
10. Remove the plastic nut with a pair of pliers by turning it clockwise.
11. Remove the spacers and blades. The blades are numbered for reassembly.
Icemaker--
The icemaker is located in the upper rear of the freezer compartment and supplies ice to the dispenser tub.
1. Disconnect the icemaker cable connector.
2. Remove 1/4-in. icemaker mounting screws and slide out the icemaker.
This refrigerator is equipped with an Electronic Icemaker.
Hope this helps... Please post back if you need more information.
Daniel
Posted on May 01, 2011
heatman101
  • 43501 Answers
SOURCE: I HAVE A GE PROFILE
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 29, 2011
What years was the marlin model 36 lever action .22 made
The Model 36 was introduced in 1936 by Marlin Firearms as an improved version of the Model 1893. Around the time of the First World War, Marlin dropped the "18" and started calling the Model 1893, the Model 93. But no significant change in the gun's design took place. In the period between the wars, metalurgy was changing, as were manufacturing techniques. So Marlin upgraded the Model 93 and re-designated it the Model 1936. This moniker lasted only one year, and in 1937 it became the Model 36.
Model 36s were made until the Second World War. In 1948, the Model 36 was redesigned and modernized again and was given a round bolt to replace the square . The model number was again changed to Model 336. Lots of versions and lots of small changes have been made since, but variations of the Model 336 are still in production.
Pete
Apr 06, 2017 | Firearms
I got a win model 70 308 serial number 862911
You don't say, but I presume you want the date of manufacture?
http://oldguns.net/sn_php/winmods.htm
Other info for you.
  1. Date Your Model 70 and 94 - RifleShooter www.rifleshootermag.com/rifles/featured_rifles_rs_model70wo_200803 These tables indicate the years of production for the Winchester Model 70 and 94 rifles ... Date Your Model 70 and ... the tables below show serial number range by ...
  2. Winchester Rifles Modern Bolt/Auto/Single Model 70 For ... www.gunsamerica.com > ... > Login To Save This Search Winchester Rifles Modern Bolt/Auto/Single Model 70 for sale on GunsAmerica. Find guns for sale, gun auctions and more on GunsAmerica.
  3. Winchester Model 70 rifles (Win. Model 70) - Chuck Hawks chuckhawks.com/win_70.htm Chuck Hawks shares information about the Win. Model 70 ... .264 Winchester Magnum, .270 Winchester, 7x57 Mauser, .300 Savage, .308 ... the Winchester Model 70 has ...
  4. Related searches for win model 70 308 serials
  5. Winchester Rifles - Model 70 Pre-64 For Sale www.gunsinternational.com > Rifles Browse all new and used Winchester Rifles - Model 70 Pre-64 for sale and buy with ... Pre 64 Model 70 Alaskan in 338 Winchester Magnum Caliber. Serial ...
  6. Winchester Repeating Arms www.winchesterguns.com The Winchester Model 70 in Vietnam. ... "The Prize for Capturing Geronimo" about the famed serial number one, 1886. Read the article on the Rock Island Auction website.
  7. WINCHESTER DATES OF MANUFACTURE - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... Model 70 Model 72 Model ... Model 59 Shotgun ...
  8. Winchester Model 70 - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Winchester_Model_70 The Winchester Model 70 series rifles are marketed as sniper rifles for military forces and law enforcement agencies under the ... .308 Winchester.300 Winchester ...
  9. Winchester Model 70 Information - MGW www.midwestgunworks.com > ... > Winchester Model 70 Winchester Model 70 Information ... and there are many "legends" about why the historic serial number records for Winchester rifles and ... .308 Win: Long Action: 7 5 ...
  10. Blue Book of Gun Values - WINCHESTER RIFLES: BOLT ACTION ... bluebookofgunvalues.com/Gun_Values/Manufacturers/WINCHESTER/... (new 2006), .308 win., ... model 70 custom special "70 years of the model 70" get pricing.270 win., ... winchester rifles: bolt action - post 1964 model 70 custom grades
  11. Winchester Model 70 Featherweight ( Pre ' 64 ) .308 Win ... www.cabelas.com > Gun Library > Wheeling Gun Library ... Winchester Model 70 Featherweight (Pre '64) .308 Win ... Shown: null. More Views: Additional Media: Winchester Model 70 Featherweight (Pre '64) .308 Win. Caliber ...
  12. Pagination
May 24, 2016 | Optics
Looking for what year my Winchester model 94 was manufactured in. The serial number is 2374881
Here you go. These sites will help you.
  • Serial Number info for Winchester Model 94 - The Firing ... https://thefiringline.com/forums/showthread.php?t=322230
    • 108 POSTS
    • FIRST POST: 2008-11-27
    2012-08-04 · Serial Number info for Winchester Model 94 User Name: ... Is there a place on line to research and find dates and serial numbers on The Winchester Model 94 ...
  • Winchester Model 1894/94 Dates of Manufacture www.savage99.com/winchester1894_dates.htm Winchester Model 1894/94. Winchester Lever Action Repeating Firearms, ... Our database contains values of serial numbers through 5103248 which ended the year ...
  • Model 1894 (Mod 94) - Winchester Dates of Manufacture www.oldguns.net/sn_php/windateslookup.php?file=win1894.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 1894 (Mod 94): ... Please enter a serial number and click the submit button. ...
  • Winchester Model 94 Serial Numbers - Gun Collections Online guncollectionsonline.com/winchestermodel94.htm Winchester Model 94 Serial Numbers. In 1894 Production began with Serial Number 1 and the Winchester Model 94 Serial Numbers run more or less, ...
  • Winchester Model 94 Identification - 8's Garage 8sgarage.com/Armory/Rifle/Data/Manuals/Winchester 94 Identification... · PDF file Winchester Model 94 Identification ... The Winchester model 1894 was introduced in October of 1894 apparently starting at serial number 1.
  • winchester 1894 serial number decoder ' Jeremy blog fitubangscam.blog.com/2013/05/04/winchester-1894-serial-number-decoder Ladder sight CARBINE Winchester 1873 1892. Winchester Model 1894 - Wikipedia, the. Winchester 1894 Serial Number ' Gun. Winchester Model 94, winchester model 94 ...
  • Winchester Dates of Manufacture - OldGuns.net oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. ... (Mod 94) Model 1895 Model ... Model 59 Shotgun ...
  • How can you find the age of a Winchester Model 94 - Answers www.answers.com > ... > Firearms > Winchester Firearms How can you find the age of a Winchester Model 94? ... What is the age and value of a Winchester Model 94 serial number 3910875?
  • How do you find out if a Winchester Model 94 is pre-64 ... https://answers.yahoo.com/question/index?qid=20081128210042AA3vaql
    • RESOLVED
    • 14 POSTS
    • 13 TOTAL ANSWERS
    2008-11-28 · Best Answer: The serial number is the best bet 95s had grip safeties as late as my 1982 model Put the serial number in here and it will give you ...
  • Dates ' Winchester Collector winchestercollector.org/dates Serial Number. Get Manufacturing Date . Manufactured Date. ... History of Winchester; Winchester Model Information; When Was Your Winchester Made? Winchester ...
  • http://www.bing.com/images/search?q=winchester+model+94+serial+number+decoder&FORM=HDRSC2
    May 22, 2016 | Optics
    Can you tell me the year my Winchester Model 94 32 special was made? The serial number is 1380891. Thank-you
    Hello Mark
    my connection here doesn't permit weapons searches, but all the info is below.
    Serial Number info for Winchester Model 94 - The Firing Line Forums
    https://thefiringline.com/forums/showthread.php?t=322230 Nov 27, 2008 - 25 posts - ‎17 authors Serial Number info for Winchester Model 94 The Harley Nolden ... a rusted $50 tomato stake Standard Carbine, or a $10-20,000 Special Order ...
    Winchester Model 94 32 Winchester Special. ' Gun Values Board
    www.gunvaluesboard.com/winchester-model-94-32-winchester-special.-... My question is why is there so much variance from site to site on this model gun. I have one with a serial number 115,814. According to most sites that serial ...
    Winchester Rifles Modern Lever Model 94 Pre 64 For Sale ...
    www.gunsamerica.com/Search.htm?C=767 108 Listings - This is a pre-64 model, serial number 14375xx, and features a straight grip .... Winchester Model 94 Top-Eject Lever Action Carbine .32 Win Special ...
    Winchester Model 94 - Gun Collections Online
    guncollectionsonline.com/winchestermodel94.htm Winchester Model 94, Winchester model 1894, 30-30 caliber, lever action ... The post-64 Winchester model 94 begin with serial number 2,700,000. ... .22 magnum, .38 Special/.357 Magnum, .44 Special/.44 Magnum, .45 Colt (or .45 Long Colt), ...
    www.savage99.com/winchester1894_dates.htm Our database contains values of serial numbers through 5103248 which ended the year 1982. Our sources disagree a bit, but this seems to be the best set of ...
    Winchester Model 94 (.32 Winchester Special) - YouTube
    2q==? 7:01 https://www.youtube.com/watch?v=fNRDe5H--S0 Nov 24, 2013 - Uploaded by 88zukcrawler Short video of my favorite gun....the Winchester 1894 (94). Mine is a post 64 model (1972 year by the serial ...
    Model 1894 ' Winchester Collector
    winchestercollector.org/models/model-1894/ .32-40 - introduced in 1894 ... .32 Winchester Special - introduced in 1901 ... As serial numbers approached the one-million mark, the official model designation ...
    Winchester Serial Numbers - ProofHouse.com
    www.proofhouse.com/win/index.html Model 1885 Single Shot · Model 1886 · Model 1892 · Model 1894 (Mod 94) · Model 1895 · Model 53 · Model 55 · Model 64 · Model 65 · Model 71 · Model 88
    Feb 29, 2016 | Optics
    Winchester model 74 serial # 11901, what year was that gun made
    My Internet at work doesn't like 'weapons'. These links will help you find the date.
    Model 74 - Winchester Dates of Manufacture
    oldguns.net/sn_php/windateslookup.php?file=winxx74.dat WINCHESTER DATES OF MANUFACTURE. Winchester Model 74: Covering numbers: 30890 - 406574. Please enter a serial number and click the submit ...
    oldguns.net/sn_php/winmods.htm WINCHESTER DATES OF MANUFACTURE. Lever Action Rifles. Henry Rifles · Model 1866 · Model 1873 · Model 1876 ... Model 1892 · Model 1894 (Mod 94)
    Winchester Model 74 .22 sr dating question ' The Firearms Forum
    www.thefirearmsforum.com/.../winchester-model-74-22-sr-dating-questi... Sep 8, 2010 - I have a Winchester model 74 .22 short rifle and am having a hard time looking up the serial number to date it. The serial is 22736. Winchester Model 74 22 Semi-auto Rifle 28 Mar 2014 Winchester Model 74 .22 Long Bore 6 Oct 2007 Winchester Model 74 3 Mar 2007 More results from www.thefirearmsforum.com
    Winchester Model 74 Value And Date ' Gun Values Board
    www.gunvaluesboard.com/winchester-model-74-value-and-date-158857... Nov 17, 2011 - Winchester model 74 value and date ... Posted on Winchester ... This is a barrel date of manufacture that is helpful in approximating the date of manufacture of ... Winchester 74 Serial Number 6694 Value 1 Jan 2016 1941 Winchester 22 LR Model 74 Serial Number 106978 15 Jul 2012 Winchester Model 74 22 Short 3 Jan 2011 More results from www.gunvaluesboard.com
    Jan 22, 2016 | Winchester Optics
    I need a users manual
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    MAKE AND MODEL
    Jan 09, 2016 | Cell Phones
    Evaperater fan making noise
    Bearings are shot on that motor. U can try a light weight oil on them but it appears that the best route is to just exchange the motor.
    Go to appliancepartspros.com and get the number for the part you need then check out ebay for that part - mucho cheaper that way.
    Apr 01, 2014 | GE Refrigerators
    Instructions for 2006Painted Imaganirum Table Table
    A.T., VIN model "C" (4x2), TH400, 6 cyl
    A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-305 (5.0L)
    }A}}400}466495" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-350 (5.7L)
    }A}}400}466496" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH400, 8 cyl, 8-379 (6.2L, diesel)
    E>}B}}400}466497" type="radio" name="userInterchange" />A.T., VIN model "C" (4x2), TH700, diesel
    A.T., VIN model "K" (4x4), TH400, 6 cyl
    B@}}}400}466499" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH400, 8 cyl, diesel
    A.T., VIN model "K" (4x4), TH400, 8 cyl, gasoline
    A.T., VIN model "K" (4x4), TH700, diesel
    FFC}B}}400}466502" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "C"
    FFC}A}}400}466503" type="radio" name="userInterchange" />M.T., 4 spd, 4x2, VIN model "R"
    ECB}B}}400}466504" type="radio" name="userInterchange" />M.T., 4 spd, 4x4, (VIN model "K")
    M.T., 5 spd, 4x2
    M.T., 5 spd, 4x4
    A.T., VIN model "C" (4x2), TH700, gasoline
    F=A}B}}400}466508" type="radio" name="userInterchange" />A.T., VIN model "K" (4x4), TH700, gasoline
    }B}}400}466509" type="radio" name="userInterchange" />A.T., VIN model "R" (4x2)
    Oct 20, 2012 | Cars & Trucks
    What year/model transmissions will fit a 1989 GMC sierra, 2500, 350 engine, 2-wheel drive? Thanks
    M.T., 5 spd, 4x2
    M.T., 5 spd, 4x4
    Jan 14, 2011 | 1989 GMC Sierra
    Can you give me a list of Kirby vacs models & the year they were released so that I know how old they are?
    1935 KIRBY Model R*
    19?? KIRBY Model 2R
    19?? KIRBY Model 3R
    19?? KIRBY Model 4R
    19?? KIRBY Model C
    1939 KIRBY Model 2C
    19?? KIRBY Model 3C
    19?? KIRBY Model 4C
    Model 505 - 1945
    Model 508 - 1948
    Model 509 - 1949
    Model 510 - 1950
    Model 511 - 1951
    Model 512 - 1952
    Model 513 - 1953
    Model 514 - 1954
    Model 515 - 1955
    Model 516 - 1956
    Model 517 - 1957
    Model 518 - 1958
    Model 519 – 1959
    Model 560 - 1960
    Model 561 - 1961
    Model 562 - 1962
    1963/64 Sanitronic VII (Sirocco)
    1965-67 Dual Sanitronic 50 (Sirocco)
    1967-70 Dual Sanitronic 80 (Avocado green)
    1970-73 Classic 1CR (Medium brown, gold bag)
    1973-76 Classic Omega 1CB (Dark brown, dark brown pinstriped bag)
    1976-79 Classic III 2CB (Candy-apple red, plaid bag)
    1979-81 Tradition (Dark blue; intro of paper bag)
    1981-84 Heritage (Gray/orange)
    1984-89 Heritage II Legend (Charcoal/gray/red)
    1989-90 Legend II (Dark rose-pink)
    1990-93 Generation 3 (Alabaster)
    1993-96 Generation 4 (Medium gray)
    1996-99 Generation 5 (Maroon)
    1999-01 Generation 6 (Black/Yellow)
    2002-05 Kirby Ultimate G
    2005-06 Kirby Ultimate G Diamond
    http://www.vacuumwizard.com/history-of-kirby-vacuum-cleaners.html
    Sep 12, 2010 | Kirby Generation 3 Bagged Upright Vacuum
    Refrigerators Logo
    122 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    dweatherby
