Question about HP DesignJet 1050c InkJet Printer
HP DJ 1050C Error 08B003007A0462
What does this error msg point to? Printer is making a loud whining noise and will not go past initialization. Parts are scarce for the C8074A models do we scrap this and start anew?
    Scholar:
  • 96 Answers
System Error: 080001 (Non-Continuable)
Problem
Description:
PostScript Error.
Corrective Action: Refer to System Error Code 070100
System Error: 070100 XXXXXXXX (Non-Continuable)
Problem
Description:
Firmware Error.
Corrective Action: Power the Printer OFF and ON again to see if the System Error
disappears.
If the Error Code reappears, then report the error to the HP response
Center or the nearest HP Support Office, stating the following
information.
n Model and Serial Number of the printer.
n Which firmware revision the printer is using (See Note below).
Check firmware in Utilities / Statistics / Code rev.
n The complete error number (See Note below).
n The Service Configuration Print þ
n The Current configuration sheet.
n Which software application the customer is using (name, version, etc.).
NOTE When reporting the System Error Code, make sure that you
supply the full Error Code (including the last 8 numbers where
applicable) and the firmware version. Without this information,
HP Support Personnel cannot help you
Posted on Nov 30, 2009
What does system error 0b000d 0000001b mean on my hp 1050c
sounds like the service station siezed and the control circuit to the motor has burned out- common fault for this machine- unfortunately this means its cheaper to buy a new machine than it is to repair- sorry
Dec 14, 2013 | HP DesignJet Office Equipment & Supplies
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
System error on plotter screen
Follow-up to previous message... ended unexpectedly.
Enter the test mode and run the ELECTRONICS test. The plotter will tell you in plain English what the problem is. If it hangs up, power down.
Jul 06, 2010 | HP DesignJet 1050c plus InkJet Printer
What does this mean on an HP Plotter 1050c?
the electronics module is in the rear of the machine and controls the printer. you have had a catastrophic failure and your e-mod needs to be replaced. these parts are becoming harder to find. check for local service. if you intend to keep this printer it is worth the fix.
Oct 14, 2009 | HP DesignJet 1050c InkJet Printer
HP 1050C Plus shuts down prior to plotting
09Bxxx is an internal error. Probably a bad Hard Drive or Main PCA board. Hopefully it's that Hard Drive because the main PCA board is EXPENSIVE.
Try replacing the Hard Drive, check to see if that fixes your problem. If not, then try replacing the Main PCA.
Sorry, and Good Luck
Sep 22, 2009 | HP DesignJet 1050c plus InkJet Printer
Hp designjet 1050c printer displays a system error
Printhead failure this is.
Turn the printer on.
Following initialization,
use the Down Arrow key to scroll to the Ink system menu icon and press Enter.
NOTE:If the error code appears during initialization press the Enter
key to allow printer to complete the rest of the initialization process.
Scroll to Replace Printheads and press Enter.
The printer should now move the carriage to an accessible position.
Open the top cover.
Remove all four printheads.
Turn the printer off using the main power switch located on the back of the printer.
Following initialization, insert one printhead at a time, starting with the black printhead.
Determine whether or not the printer accepts the printhead.
Turn the printer off and repeat steps for each of the printhead.
Replace the failed printhead.
Hope this helps
Regards
Apr 17, 2009 | HP DesignJet 1050c InkJet Printer
Sysytem Error 009B002 007A046F
System Error: 09xxxx (Non-Continuable)
Problem
Description:
EIO Accessories (EIO Card/Hard Disk Drive) Error.
Corrective Action: Try the following:
n Switch the Printer OFF and ON again and wait for the initialization.
n If the Error code continues to appear, switch the Printer OFF.
Remove the EIO Card (if installed) and make sure that the Hard
Disk Drive is installed correctly by pushing it firmly inwards and
checking that the two installation screws are completely
tightened. Switch the Printer ON again. If the error codes 09Axxx
or 09Bxxx appear then replace the Hard Disk Drive.
n If the Error Code disappeared after removing the EIO Card, then
switch the Printer OFF and reinstall the EIO Card, making sure
that the two installation screws are completely tightened. Switch
the Printer ON again. If the Error Code reappears, then the EIO
Card could be faulty. Replace the EIO Card.
n If Error Code 09Cxxx appears after initialization, then replace the
Electronics Module
n Once the Error Code has been solved, print an Internal Demo
Print to make sure that the Hard Disk Drive is functioning
correctly. If the Error Code reappears, then use the above
information to troubleshoot the problem
Nov 21, 2008 | HP DesignJet 1050c InkJet Printer
ERROR CODE 04C400 - WHAT TO DO, WHAT IS IT
Pulled Harddrive and ethernet card, no error. Installed hard drive started machine, no error. Installed ethernet card, restarted machine got error. I am now replacing the ethernet card to resolve issue.
Jun 23, 2008 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050c InkJet Printer Logo
431 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
